Thread started 26 Feb 2014 (Wednesday) 20:56
Photo "rendered less than 220 dpi"
bettyn
Feb 26, 2014 20:56 |  #1
Get this a lot when trying to print photos from Elements 11 with my Pixma Pro 9000II printer. How do I correct this problem? What's causing it?
Thanks.
My Gear: 6D, 7D, EOS-M w EF-M 22 f2 STM and EF-M 18-55 f3.5-5.6 IS STM, 17-40L f4, 24-70L f2.8, 100 f2.8 non-IS macro, 70-200L f/4 IS, 400L f5.6,, Canon 1.4x II TC, Canon Speedlite 430 EX II, Better Beamer. Manfrotto carbon fiber tripod, 2 monopods, Manfrotto ballhead and pistol grip tripod heads.
tonylong
...winded
Gallery: 60 photos
Feb 26, 2014 21:34 |  #2
I don't have the printer, but:
1) What size (in inches) are you trying to print?
2) What are the final pixel dimensions (after cropping) of the image before sending it to the printer?
Tony
Nogo
POTN record for # of posts during "Permanent Ban"
Gallery: 17 photos
Joined Dec 2013
Feb 26, 2014 21:47 |  #3
It is just warning you that the print is not optimal. If you print the photo anyway and it looks fine to you, don't worry about the message.
If it doesn't, there are ways to render the photo so the dpi is higher, but as far as I know Elements by itself will not do it. You will need another program in all likelihood.
Philip
Nogo
Gallery: 17 photos
Joined Dec 2013
Feb 26, 2014 21:57 |  #4
I did a search. It looks like you change the resolution in Elements similar to how you can do it in CS.
Never have tried it, but this may help. http://akvis.com …s/print-size-elements.php (external link)
Philip
tzalman
Fatal attraction.
Feb 27, 2014 03:36 |  #5
Your printer demands to be fed 300 ppi images - actually the number of pixels needed to make a print the size you are requesting with 300 pixels for each inch of paper. It is just a matter of determining who will do the resizing. If you do nothing but send through whatever you have, your OS, Mac or Windows, will do it. The other option is for you to do the resampling in PSE. Elements is giving you the information to make an informed decision. If you have already more than 200 ppi for that print size, it probably doesn't matter where the resampling is done. Between 150 - 200 ppi I would do it in PSE in order to see, control and sharpen the image before committing to the print. Starting at less than 150 ppi, I would definitely want to see it before deciding if it is worthwhile continuing.
Elie / אלי
bettyn
Feb 27, 2014 20:27 |  #6
Thanks, everyone.
3,626 views & 0 likes for this thread, 4 members have posted to it.
926 guests, 117 members online
