Thread started 28 Feb 2014 (Friday) 16:21
Fuji RAW @ high ISOs: jpegs better?
armis
Joined Jan 2012
Feb 28, 2014 16:21 |  #1
So as I was saying there, it feels like at ISO 6400 the jpegs that my X-E1 outputs are way better in terms of noise reduction than anything I can manage in ACR/LR. I already tapped someone here for help and he got me close, but not quite there yet.
Here's a full-res jpeg and RAW; if you feel like it, take a look and see if you can equal the cleanness of the jpeg?
RAW: https://www.hightail.c​om …ad/elNLT215Tk10​TW5tcXRVag (external link)
jpeg: https://www.hightail.c​om …ad/elNLT215Tk05​bEM5TE5Vag (external link)
Fuji X-T4, 18-55 and 55-200 zooms, Samyang 12
www.wtbphoto.com (external link)
tonylong
...winded
Gallery: 60 photos
Feb 28, 2014 22:32 |  #2
I'm not familiar with that camera. Also, I'm not a noise reduction "expert", I'll just toss out the fact that camera designers/developers/m​akers do put work into improving their products/technology. One area that we might see is the noise reduction that gets applied in-camera when producing a jpeg, and, at least with Canon, the High ISO noise reduction. Another that we've seen pop up has been Long Exposure Noise Reduction, in which the camera makes a second dark exposure and blends it with the normal exposure, but this setting is used in creating Raws as well a jpegs, at least with Canon cameras...
So, the question seems to be whether the noise reduction technology for at least some cameras when creating jpegs is "superior" to what Raw processors can achieve with Raw files?
My answer is, umm, I dunno! But because I'm a died-in-the-wool Raw shooter for concerns that go significantly beyond noise reduction, well, I can only suggest that I'd get the most out of Raw that you can. And then, there are many folks here who use "plug-ins" specifically for noise reduction, so that after Lightroom/ACR has done the "heavy lifting" these programs can take over the NR work on, say, a tiff...
Tony
tonylong
...winded
Gallery: 60 photos
Feb 28, 2014 22:33 |  #3
In other words, I don't see in-camera noise reduction as being a good reason to switch back to shooting jpegs! :)
Tony
chtgrubbs
Joined Jul 2003
Mar 01, 2014 17:06 |  #4
I also shoot RAW with an XE-1 and use LightRoom. But I have been reading the Fuji forum on DPReview, and many there think that the demosaicing algorithm that Adobe uses is not the best fit with the X-Trans sensor images. Many people there seem to prefer the SilkyPix converter which you can down load for free from the Fuji website. (http://www.fujifilmusa​.com …t=879787&sscuca​tid=664260 (external link))
Other Fuji users like the PhaseOne Capture One converter.
Dan ­ Marchant
Gallery: 19 photos
Joined Oct 2011
Mar 02, 2014 03:34 as a reply to  @ chtgrubbs's post |  #5
Had a quick go. Didn't spend enough time to get the colours exactly right, focused more on the NR...
Crop from the original jpeg above
IMAGE: https://lh6.googleusercontent.com/-abM60sM-1HM/UxLvkk49vJI/AAAAAAAAGps/Vm1BXP8x-P0/s800/DSCF3690original.jpg
and my version using LR
IMAGE: https://lh6.googleusercontent.com/-Ii4fwB9Tstk/UxLvibAOPeI/AAAAAAAAGpk/9BNHKaRY9ns/s800/DSCF3690edit.jpg
Full size Jpeg of my version at https://www.dropbox.co​m …p1g1o516jx9w/DS​CF3690.jpg (external link)
Dan Marchant
armis
Joined Jan 2012
Mar 02, 2014 05:17 |  #6
Was it that OOF? Sorry, should've picked a better one. Pretty great job there; could you please share your settings? :)
Dan ­ Marchant
Gallery: 19 photos
Joined Oct 2011
Mar 02, 2014 08:25 as a reply to  @ armis's post |  #7
First off dropped the highlights -55 and blacks -44 - dropping the black point to match the JPEG makes a big difference because pushing blacks/shadows really shows up noise.
Sharpening 51
Radius 1
Detail 25
Masking 77 - this removes a lot of noise in areas of solid colour.
Luminance Noise reduction 57 (detail and contrast at default)
Colour NR 20 (detail and smoothness at default)
I also did some messing with individual colour channels to get the purple areas behind the singer to be purple. It really needs some more fiddling to get the reds and blues to match but didn't have enough time.
Dan Marchant
1,704 views & 0 likes for this thread, 4 members have posted to it.
1456 guests, 128 members online
