if i have one on the camera to transmit
and one to receive on the flash end
can i use the one receiving 622c to fire 3 or 4 flashes that are together ?
(without needing one per flash?)
dynamitetony Goldmember 1,023 posts Likes: 30 Joined Sep 2007 Location: london UK More info | Mar 02, 2014 08:09 | #1 if i have one on the camera to transmit 5Dmk4 : 5Dmk3: Sigma 24mm F1.4 :Sigma 35mm F1.4 : Canon 50mm F1.4 : Canon 85mm F1.8 : Canon 100mm F2.8 Macro : Canon 24-105 F4 : Canon 70-200 F2.8L mkii : Flashes, lights & Stuff
Mar 02, 2014 09:04 | #3 oh thank you, having a read up on them now.. 5Dmk4 : 5Dmk3: Sigma 24mm F1.4 :Sigma 35mm F1.4 : Canon 50mm F1.4 : Canon 85mm F1.8 : Canon 100mm F2.8 Macro : Canon 24-105 F4 : Canon 70-200 F2.8L mkii : Flashes, lights & Stuff
Trailboy Senior Member 541 posts Likes: 8 Joined Jan 2009 More info | Mar 02, 2014 11:10 | #4 In ttl, no.
Whortleberry Goldmember 1,719 posts Likes: 53 Joined Dec 2011 Location: Yorkshire, England More info | Mar 02, 2014 12:25 | #5 I regularly trigger 2 Metz 45s from a single receiver (either Pixel King or Yongnuo 622C, depending solely on which bag I pick up first - no other reason). Obviously, these are used totally manually with all adjustment on the flash units. However, there's no reason why you couldn't string more units together by the same method. Image hosted by forum (678662) © Whortleberry [SHARE LINK] (Cables removed for clarity, the pic was originally for another purpose)THIS IS A LOW QUALITY PREVIEW. Please log in to see the good quality stuff. One unit as receiver, with a Pixel TF-321 adapter on top. One flash is plugged into the TF-321 socket and one into the PC socket on the side of the Rx unit. Both are then triggered reliably. All you'd need to do is add extra TF-321s in a stack on top of the Rx unit and couple up with cables. Obviously, there's going to be a finite limit to the number of times you can do this but your 3 or 4 should pose no problem. Be messy, with all the cables, but I'm sure it could be done. Phil ǁ Kershaw Soho Reflex: 4¼" Ross Xpres, 6½" Aldis, Super XX/ABC Pyro in 24 DDS, HP3/Meritol Metol in RFH, Johnson 'Scales' brand flash powder. Kodak Duo Six-20/Verichrome Pan. Other odd bits over the decades, simply to get the job done - not merely to polish and brag about cos I'm too mean to buy the polish!
grfft3r Senior Member 478 posts Likes: 4 Joined Mar 2012 Location: Phila, PA More info | Mar 02, 2014 12:33 | #6 How about 3 flashes with one receiver?
Mar 02, 2014 13:39 | #7 Only other problem is they are for a lastolite Ezybox ii octagon. And the bracket that goes on the back is quiet small in the way it holds the flashes. 5Dmk4 : 5Dmk3: Sigma 24mm F1.4 :Sigma 35mm F1.4 : Canon 50mm F1.4 : Canon 85mm F1.8 : Canon 100mm F2.8 Macro : Canon 24-105 F4 : Canon 70-200 F2.8L mkii : Flashes, lights & Stuff
Mar 02, 2014 13:46 | #8 5Dmk4 : 5Dmk3: Sigma 24mm F1.4 :Sigma 35mm F1.4 : Canon 50mm F1.4 : Canon 85mm F1.8 : Canon 100mm F2.8 Macro : Canon 24-105 F4 : Canon 70-200 F2.8L mkii : Flashes, lights & Stuff
Whortleberry Goldmember 1,719 posts Likes: 53 Joined Dec 2011 Location: Yorkshire, England More info | Mar 02, 2014 13:55 | #9 grfft3r wrote in post #16728935 How about 3 flashes with one receiver? http://scottrobertla.com …-sync-and-umbrella-mount/ Same principle as previously, vastly more expensive solution. There are much cheaper versions of the same thing and it's only a simple circuit after all. dynamitetony wrote in post #16729078 Only other problem is they are for a lastolite Ezybox ii octagon. And the bracket that goes on the back is quiet small in the way it holds the flashes. I'll try to get a photo Go on then - make life flippin' awkward! You need a bigger 'ole to get all the heads in action. Phil ǁ Kershaw Soho Reflex: 4¼" Ross Xpres, 6½" Aldis, Super XX/ABC Pyro in 24 DDS, HP3/Meritol Metol in RFH, Johnson 'Scales' brand flash powder. Kodak Duo Six-20/Verichrome Pan. Other odd bits over the decades, simply to get the job done - not merely to polish and brag about cos I'm too mean to buy the polish!
Trailboy Senior Member 541 posts Likes: 8 Joined Jan 2009 More info | Mar 02, 2014 14:01 | #10 grfft3r wrote in post #16728935 How about 3 flashes with one receiver? http://scottrobertla.com …-sync-and-umbrella-mount/ Looks like a lot of rebranded cheap end Yongnuo stuff, tbh.
Mar 03, 2014 11:56 | #11 update: 5Dmk4 : 5Dmk3: Sigma 24mm F1.4 :Sigma 35mm F1.4 : Canon 50mm F1.4 : Canon 85mm F1.8 : Canon 100mm F2.8 Macro : Canon 24-105 F4 : Canon 70-200 F2.8L mkii : Flashes, lights & Stuff
| Latest registered member is Niagara Wedding Photographer 1336 guests, 131 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
