Thread started 02 Mar 2014 (Sunday) 11:54
Wedding photos (size Editing)
Nick_Reading.UK
Joined Nov 2011
Mar 02, 2014 11:54 |  #1
wedding album and Photos on disc for the customer...
Does one keep the photos at the camera size..
Portrait 2:3 ratio
Landscape 3:2 ratio
Or does one change/crop to another ratio or letter size or something else?
EOS 5Dmk3 X2, 60D, EF24-70mm f2.8L mk2, EF70-200mm f2.8L IS mk2, EF85mm f1.8, EF50mm f1.4, EF50mm f1.8 mk1(350D with 18-55mm Sh"kit" lens).
Speedlite 600EX-RT, 430EX II Flash. manfrotto 190XDB tripod, Giottos GTMML 3290B Monopod, B+W 77mm 110 Single Coated filter, Hama 77mm Variable Neutral Density Filter.
tonylong
...winded
Gallery: 60 photos
Mar 02, 2014 14:30 |  #2
Well, to me the answer would be "It depends"...
If your customer is comfortable with doing some cropping to fit a certain print size, then leaving the images in their "native" aspect ratio can work, so that if the customer wants, say, an 8x10 print (4:5 aspect ratio) then the customer can crop away...
But, making that assumption about the skills and the comfort "zone" of a customer can be, well, "iffy". You may be better off making a "judgement call" about a given image and whether a change to the aspect ratio would best suit the composition!
Tony
tim
Light Bringer
Mar 02, 2014 15:12 |  #3
Always 3:2 unless you have a very special reason for otherwise. For example I took one photo at my last wedding knowing I had to crop something out and make it more like 16:9.
Never through away part of the image without good reason. If people want a 5x7" print they can come back to you or do it at a kiosk.
496 views & 0 likes for this thread
Latest registered member is JenWorleyPhoto
1845 guests, 311 members online
