Thread started 02 Mar 2014 (Sunday) 16:03
Syncing 580 EX II
tennfan1125
Mar 02, 2014 16:03 |  #1
Just got this new flash haven't really had time to play with it yet . But it seems that the timing is off between the flash and my 1d MIII. Is there a way to sync the two together. Any help would be appreciated...
canon 30d, canon 1d mkIII, 50mm 1.8, 18-55mm, canon 1.4 extender, canon 400mm f2.8 IS, canon 70-200 f2.8 IS II, Canon 16-35mm f2.8,Pocket Wizards,430 ex II, 580 ex II, Canon 430 EX, sigma SA-9, 70-300 5.6, 28-80mm(which I NEVER use)
JeremyKPhoto
Joined Apr 2012
Mar 02, 2014 16:05 |  #2
Are you shooting at a SS faster than 1/200 or 1/250? Might be going past the sync speed of your camera. Try setting the flash to HSS mode.
Are you shooting it on camera or off? Do you have a picture to post as an example of what you are experiencing?
5D Mark III / 70-200 2.8L IS II / 24-105L / 50 1.8 stm / Tamron 70-300 VC / Sigma 85mm 1.4 Art
digital ­ paradise
Awaiting the title ferry...
Gallery: 157 photos
Mar 02, 2014 17:06 |  #3
Can you describe what you think is out of sync? The flash fires after the first shutter opens and then the second curtain closes. The only thing you can change is set it to second curtain sync which causes the flash fire not to fire after the first curtain opens but just before the second curtain closes.
Then there is HSS like mentioned.
Set the shutter to 15 seconds and while in normal mode, not second curtain sync or HSS and take a shot and pay attention to the sequence.
Image Editing OK
Wilt
Mar 02, 2014 19:27 |  #4
digital paradise wrote in post #16729542 (external link)
I presuming '1/15 sec.', not '15 seconds', as I see no purpose served by having shutter open for 15 seconds! :confused:
To the OP, it would benefit us for you to post a photo showing what you think is going awry with your flash photo, and if the original EXIF data is not stripped off (not 'save for web') it would help us to diagnose.
digital ­ paradise
Gallery: 157 photos
Mar 02, 2014 19:41 |  #5
Good point. Even @ 1/15 it is pretty fast if you are not used to it. I agree 15 is a little on the long side. Just wanted to be sure the OP could follow the sequence. Somewhere in between and closer to 1/15.
Image Editing OK
847 views & 0 likes for this thread, 4 members have posted to it.
Syncing 580 EX II
1699 guests, 140 members online
