Thread started 02 Mar 2014 (Sunday) 18:00
2lenses only for a wedding shoot
Nick_Reading.UK
Joined Nov 2011
Mar 02, 2014 18:00 |  #1
If you had 5Dmk3 two bodies (knowing that you can bump up ISO if needed) and only had the choose of two lenses for a wedding shoot what would they be?
I am thinking that the 70-200 2.8 and the 24-70 2.8 should do the trick.. Anyone thinking/using the same or completely different?
EOS 5Dmk3 X2, 60D, EF24-70mm f2.8L mk2, EF70-200mm f2.8L IS mk2, EF85mm f1.8, EF50mm f1.4, EF50mm f1.8 mk1(350D with 18-55mm Sh"kit" lens).
Speedlite 600EX-RT, 430EX II Flash. manfrotto 190XDB tripod, Giottos GTMML 3290B Monopod, B+W 77mm 110 Single Coated filter, Hama 77mm Variable Neutral Density Filter.
maverick75
Joined May 2012
Mar 02, 2014 18:02 |  #2
I would do 16-35mm 70-200mm.
flaker
Joined Dec 2012
Mar 02, 2014 18:05 |  #3
24-70 2.8 and 85l
a7+batis 18
ig: @_flaker
jmikolich
Joined Feb 2013
Mar 02, 2014 18:22 |  #4
you chose......wisely.
as long as the f2.8 is non issue
-Jim
Canon 5D3,5D3,5D2,6D,24 f2.8 IS,35L,45 TS-E,50L,85 f1.8,70-200 f2.8L II,100L
Rokinon 14mm f2.8
kin2son
Joined May 2011
Mar 02, 2014 18:24 |  #5
I like challenges therefore I'd go primes.
35mm + 85mm.
Having said that the model answer for your question is 35mm (either the L or Sigma) + 70-200II.
5D3 Gripped / 17-40L / Σ35 / 40 Pancake / Zeiss 50 MP / Σ85 / 100L Macro / 70-200 f2.8L II IS / 430 EX II / 580 EX II / Canon 2xIII TC / Kenko Ext. Tubes
EOS M / EF-M 18-55 / EF-M 22f2 / Ricoh GR aka Ultimate street camera :p
Flickr (external link) | My Images on Getty®‎ (external link)
vengence
Joined Mar 2013
Mar 02, 2014 18:31 |  #6
14mm and 400mm 2.8. You can either brenzier or crop to get anything you want.
Seriously though, I think 24-70 2.8L + 70-200 2.8L is the most popular. There is no best as it's simply too subjective.
koolcreation
Gallery: 12 photos
Mar 02, 2014 18:36 |  #7
70-200mm 2.8L
50mm 1.2L
5DMKII | 50mm 1.4 | 24-105 f/4 | Speedlights - Strobes |
Instagram @KoolCreationPhoto (external link)
*Knowledge*
Gallery: 38 photos
Mar 02, 2014 18:40 |  #8
24L & 70-200L
I'm Preston & I pretend to know what I'm doing but I really just wing it.
rgs
Gallery: 147 photos
Mar 02, 2014 19:43 |  #9
I used to shoot weddings with a Pentax 67 and a 105 (long normal for that format). I had a 55 in case it was needed but avoided it if possible. I always thought changing lenses got in the way. You would be amazed at what can be done with one lens if you know it well.
That said, I would probably go for 24-70 and 70-200. But another interesting combination would be 24-105 and 16-35.
Canon 7d MkII, Canon 50D, Pentax 67, Canon 30D, Baker Custom 4x5, Canon EF 24-104mm f4, Canon EF 100mm f2.8 Macro, Canon EF-S 10-22mm f/3.5-4.5, 70-300mm f/4-5.6 Di VC
The Singular Image (external link)Richard Smith Photography (external link)
Richard Smith Real Estate Photography (external link)500PX (external link)
Fine Art America (external link)
kevinstinks
Mar 02, 2014 19:58 |  #10
*Knowledge* wrote in post #16729737 (external link)
24L & 70-200L
This is a fantastic suggestion.
5DIII, 24L f/1.4 II, 70-200L f/2.8 IS II, 
*Knowledge*
Gallery: 38 photos
Mar 02, 2014 20:18 |  #11
kevinstinks wrote in post #16729950 (external link)
Thanks, it's what I use.
deanedward
Gallery: 13 photos
Mar 02, 2014 20:52 |  #12
Really depends on your style and your assignment. Since I'm the assistant (#2), I'm usually in charge of taking the "standard" shots with a mix of some candid photos of the people as well. Currently, I'm using a 24-70 and a 100mm f/2 though I'm considering upgrading the 100mm f/2 to a 135mm f/2 or a 70-200 f/2.8.
If I were free-er (meaning I can be the #3 guy and just shoot the things the other two weren't covering), I might consider a 50mm + 135mm combo or the famed 35mm + 85mm combo as well...it's just that, I need one zoom at least...for now.
Make yourself heard
Canon EOS 6D Mark II, EF 24-70mm f/2.8L USM, EF 35mm f/2 IS USM, EF 50mm f/1.4 USM, EF 100mm f/2 USM, Speedlite 430EX
http://www.flickr.com/​photos/deanmejos/ (external link)
MFG
Mar 02, 2014 20:59 |  #13
Question for op is: why 2?
getting 2 of the 24-70? consider backup lenses? if you drop the 24-70? u seriously cannot take photo of people closer. I can see that you do have lots of lenses.
I learnt that different part of the wedding, slightly different lenses come into action.
learnt to know your gear and the amount of space available.
hope I am able to help with your thinking here.
here is my small blog post on the subject (similar).
http://scottgohphotogr​aphy.com.au …-for-wedding-photography/ (external link)
AIPP Accredited (Australia), WPJA
Professional Wedding, Newborn and Family Photographer
https://www.scottgohph​otography.com.au (external link)
https://www.facebook.c​om/ScottGohPhotography (external link)
https://www.scottgohph​otography.com.au/blog (external link)
https://www.scottgohph​otography.com.au/babie​s-and-children/ (external link)
CaliWalkabout
Mar 02, 2014 22:01 |  #14
I'm not a wedding photographer, but I couldn't imagine doing a wedding without a long enough lens to capture the ceremony at a respectful distance.
I would think the 24-70 and 70-200 would be about as good a pairing as one could achieve for events. If it were me, I'd still want one of the portrait primes for capturing the couple.
6D, 17-40L, 24L II, 50L, 100L, 70-300L.
kenwood33
Mar 02, 2014 22:19 |  #15
the answer would be dependent on which part of a wedding and what type of wedding but if those info are not available i would go with 16-35 and 100L
Gearlist
4,639 views & 0 likes for this thread
Latest registered member is ArielC
967 guests, 346 members online
