Thread started 03 Mar 2014 (Monday) 11:14
Bought a 5DmkIII - the level doesn't seem to be correct...
aparis99
Mar 03, 2014 11:14 |  #1
I use my cameras for real estate and architecture so the level is a key player to me. I took it on it's first real estate shoot and it just seemed like the level was not working right. Some poor quality cell phone pics but I'm not sure what to do about it...
http://imgur.com/a/nUS​ZS (external link)
My Site - www.apimagery.com (external link)
Canon R5 (x2), Canon RF 15-35 f/2.8L IS, Canon RF 24-70 f/2.8L, Canon RF 70-200 f/2.8L, Canon RF 100-500L, Sigma Art 35 f/1.4, Canon 85 f/1.8, Canon 100 f/2.8L Macro
gonzogolf
dumb remark memorialized
Gallery: 561 photos
Mar 03, 2014 11:16 |  #2
Buy a bubble level at a hardware store. Use the camera level, then set the bubble on top of the hotshoe.
aparis99
Mar 03, 2014 11:25 |  #3
gonzogolf wrote in post #16731374 (external link)
I've got a spirit level but can't use that and a flash or hot shoe wireless trigger at the same time :confused:
gonzogolf
Gallery: 561 photos
Mar 03, 2014 11:28 |  #4
aparis99 wrote in post #16731392 (external link)
You dont need a wireless trigger or a flash to check the accuracy of the level.
TeamSpeed
01010100 01010011
Gallery: 116 photos
Joined May 2002
Mar 03, 2014 11:30 as a reply to  @ gonzogolf's post |  #5
Also only 1 of the 3 shots seem to show where the camera thought you were level? Not sure if you noticed that or not. In any case, I would expect the door frame in the middle of the frame to be a bit more vertically level with that middle shot.
aparis99
Mar 03, 2014 11:32 |  #6
I could do that to check I suppose. Didn't think about it. I use the grid on LV and in the VF and you can see where the lines look like things are level, the camera doesn't think so. In the shot where the cam thinks things are level, you can see the verticals are no anywhere near level at all (shot #2)
tonyw36
Joined Aug 2013
Mar 03, 2014 14:13 |  #7
It looks to me as though the camera level is right but there is a lot of perspective distortion, which you would expect with internal shots like those. You need to correct these using the perspective transform in Photoshop. You can also rotate the picture to get the level right.
Charlie
Guess What! I'm Pregnant!
Mar 03, 2014 14:26 |  #8
either your dual axis is way off or you've got too much distortion to tell. Why dont you test on known good levels like kitchen countertops? Those should be very level (at least they are when the professionals install them).
Sony A7siii/A7iv/ZV-1 - FE 24/1.4 - SY 24/2.8 - FE 35/2.8 - FE 50/1.8 - FE 85/1.8 - F 600/5.6 - CZ 100-300 - Tamron 17-28/2.8 - 28-75/2.8 - 28-200 RXD
Panasonic GH6 - Laowa 7.5/2 - PL 15/1.7 - P 42.5/1.8 - OM 75/1.8 - PL 10-25/1.7 - P 12-32 - P 14-140
John ­ from ­ PA
Joined May 2003
Mar 03, 2014 14:31 |  #9
I see a Canon 10-22 in your profile. Is that what you used for these samples?
Somebloke
Joined Sep 2013
Mar 03, 2014 15:38 |  #10
The inbuilt level in my 5d3 is terrible, I reckon my iphone would do a better job. Ignore it and get a $3 bubble..
waterrockets
Joined Jun 2010
Mar 03, 2014 16:15 |  #11
Other threads indicate that this is not an unusual problem.
1D MkIV | 1D MkIII | 550D w/grip & ML| EF 70-200mm f2.8L| EF 24-105mm f4L IS | Canon EF 100-400mm f/4.5-5.6L IS | Samyang 14mm f/2.8 IF ED UMC | 430EXii | EF 50mm f1.8
gjl711
Mar 03, 2014 16:18 |  #12
If it's not right, send it back to Canon. I thought that the tolerance was +/- 3 degrees. I definitely would not put up with that on a $3500 camera.
Not sure why, but call me JJ.
::Flickr:: (external link)
::Gear::
Somebloke
Joined Sep 2013
Mar 03, 2014 16:38 |  #13
gjl711 wrote in post #16732086 (external link)
3 degrees is a lot? Alas I didnt even start using mine till well outside waranty period..perhaps there is/will be a firmware fix?
Nick5
Mar 03, 2014 16:44 |  #14
Lack of Viewfinder Grid Display was one of the reasons I did not buy a 5D mark II three years. Loving the Mark III with not only VF Grid Display but the nice chunky grip of the 7D as well.
Canon 5D Mark III (x2), BG-E11 Grips, Canon Lenses 16-35 f/4 L IS, 17-40 f/4 L, 24-70 f/4 L IS, 70-200 f/2.8 L IS II, 70-200 f/4 L IS, 70-200 f/4 L IS Version II, 100-400 f/4.5-5.6 L IS Version II, TS-E 24 f/3.5 L II, 100 f/2.8 L Macro IS, 10-22 f3.5-4.5, 17-55 f/2.8 L IS, 85 f/1.8, Canon 1.4 Extender III, 5 Canon 600 EX-RT, 2 Canon ST-E3 Transmitters, Canon PRO-300 Printer
gjl711
Mar 03, 2014 16:45 |  #15
Somebloke wrote in post #16732120 (external link)
I checked my 7D manual and the tolerance is +/- 1 degree so I'm assuming that the 5DIII is at least as good if not better.
::Gear::
5,424 views & 0 likes for this thread, 17 members have posted to it and it is followed by 2 members.
1458 guests, 137 members online
