I'm still toying with learning how to use this…and I find at times when I have it dialed up to the max end, that I get these uneven dark shades in my image.
What causes that…or what is happening when I get this?
thx
Mar 04, 2014 08:55 | #1 I'm still toying with learning how to use this…and I find at times when I have it dialed up to the max end, that I get these uneven dark shades in my image. Tony
Mar 04, 2014 09:35 | #2 Ive no experience in that but i guess it is just a cheap filter? Sony A7RII | Sony A7S
gonzogolf dumb remark memorialized More info | Mar 04, 2014 09:39 | #3 The variable ND filters achieve their effect by having two polarizing filters in front of each other. As you dial in the strength the filters reduce the light coming in on each axis, but if you go too far they begin crossing to the point of actually blocking light, hence the x's. A regular ND filter is just neutrally colored glass so you dont have such issues.
JohnfromPA Cream of the Crop 11,258 posts Likes: 1527 Joined May 2003 Location: Southeast Pennsylvania More info | Mar 04, 2014 10:26 | #4 CatchingUp wrote in post #16733498 I'm still toying with learning how to use this…and I find at times when I have it dialed up to the max end, that I get these uneven dark shades in my image. What causes that…or what is happening when I get this? thx Does this seem to occur with any particular lens focal length? Can you post an image for us to see?
Mar 04, 2014 10:46 | #5 if it's the X shape, that's just what they do to a degree. I have a cheap one and the Tiffen, the later is better. A test somewhere not too long ago, maybe in Advanced Photographer, rated the Tiffen highest, even better than the Singhray (spelling?) which costs a lot more. You just have to play with it, don't close all the way down. You can't see the effect in live view since the screen is too dark and it only shows up after long exposure. Sometimes it can be fixed in PP to some degree, but best to not fully close it down. Since it's polarizers, it might also be different depending on where the sun is. 40D, 5D3, a bunch of lenses and other things
Mar 04, 2014 16:44 | #6 The filter is a 'pro-master' variable ND It was the only one available when I was in Maine this past summer. I use it on my 17-40. I'm uploading two samples…rather extreme case but on the max setting. I paid about 85.00 for the filter. I've gotten good results on other occasions…but usually at a lower setting. Image hosted by forum (678843) © CatchingUp [SHARE LINK] THIS IS A LOW QUALITY PREVIEW. Please log in to see the good quality stuff. Image hosted by forum (678844) © CatchingUp [SHARE LINK] THIS IS A LOW QUALITY PREVIEW. Please log in to see the good quality stuff. Tony
dave63 Goldmember 1,269 posts Likes: 5 Joined Aug 2008 Location: In the ether between Denver and Boulder More info | Mar 04, 2014 17:21 | #7 wow.
Mar 04, 2014 18:46 | #8 I have had some positive results as well: IMG_0107 copy Image hosted by forum (678849) © CatchingUp [SHARE LINK] THIS IS A LOW QUALITY PREVIEW. Please log in to see the good quality stuff. Tony
Mar 05, 2014 03:45 | #9 CatchingUp wrote in post #16734590 The filter is a 'pro-master' variable ND It was the only one available when I was in Maine this past summer. I use it on my 17-40. I'm uploading two samples…rather extreme case but on the max setting. I paid about 85.00 for the filter. I've gotten good results on other occasions…but usually at a lower setting. This is one of the main reasons why I don't use VNDs. The dark X will start appearing at quite low densities when using a wide-angle lens. The price and quality of the VND doesn't make any difference. Frank Hollis - Retired mass spectroscopist
Sirrith Cream of the Crop More info | Mar 05, 2014 05:58 | #10 hollis_f wrote in post #16735580 This is one of the main reasons why I don't use VNDs. The dark X will start appearing at quite low densities when using a wide-angle lens. The price and quality of the VND doesn't make any difference. This is correct. I also don't use VNDs because of this. -Tom
| Latest registered member is semonsters 1017 guests, 107 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
