Thread started 05 Mar 2014 (Wednesday) 21:24
Slow Response from 60D
Larry ­ Johnson
Joined Sep 2011
Mar 05, 2014 21:24 |  #1
Does shooting RAW and/or increasing ISO way up (i.e. above 4000) reduce the response time of the 60D. Several times during a recent shoot I got a message from the camera that it was "waiting to process" or something to that effect. I only noticed it after the clouds rolled in and I bumped the ISO way up. I was shooting as many frames per second as possible. This was the first time I shot RAW as well, but didn't have a problem with the bright light in the morning. Thanks.
Ain't Nature Grand!
Shooting 7D2 with Canon 400mm, f/5.6.
60D, canon 18-135 EFS, and 1.4 extender in the bag.
Frodge
Joined Nov 2012
Mar 05, 2014 21:52 |  #2
Filled the buffer.
“It's kind of fun to do the impossible.” - Walt Disney.
Equipment: Tokina 12-24mm, Canon 40mm 2.8, Tamron 17-50 2.8 XR Di, Canon 18-55mm, Canon 50mm 1.8, Tamron 70-300VC / T3I and 60D
GaryD
Joined Feb 2014
Mar 05, 2014 21:57 |  #3
Sounds like High-ISO NR is set to MAXIMUM. Turn it down a notch.
MakisM1
Gallery: 50 photos
Joined Dec 2011
Mar 05, 2014 21:59 |  #4
Did you shoot RAW only, or RAW + JPEG?
What is your 'High ISO NR' setting?
Gerry
Preeb
Gallery: 151 photos
Joined Sep 2011
Mar 05, 2014 22:47 |  #5
Larry Johnson wrote in post #16737705 (external link)
The buffer will only hold so much. When you fill it, then it takes a bit to write it to the card. You can't just hold down the shutter release forever in burst mode. I think that you can improve it by changing to MRAW or SRAW (just an assumption as I've never done it), but it still isn't infinite.
Rick
6D Mark II - EF 17-40 f4 L -- EF 100mm f2.8 L IS Macro -- EF 70-200 f4 L IS w/1.4 II TC
MakisM1
Gallery: 50 photos
Joined Dec 2011
Mar 05, 2014 22:56 |  #6
Sorry I didn't notice that you were shooting continuous mode. Yes the buffer fills after 15 or so photos. In JPEG it takes over fifty before the buffer fills up. That's why you probably didn't notice.
If you choose a smaller jpeg format, you can probably shoot hundreds...
Gerry
John ­ from ­ PA
Joined May 2003
Mar 06, 2014 07:00 |  #7
MakisM1 wrote in post #16737783 (external link)
To check the High ISO NR setting see page 254 which I've attached.
You should also review pages 85, 86,87 of the manual.
If you are doing both RAW + the largest JPEG reduce or turn off the JPEG in situations demanding rapid data writes to the card. A full size JPEG is about 6 MB and can always be created from the RAW in post processing.
Kwirk
Mar 06, 2014 07:05 |  #8
The higher the ISO, the larger the file size. You may have a slower card, in combination with filling the buffer, and using a high ISO, would likely result in a slower response time.
Larry ­ Johnson
Joined Sep 2011
Mar 06, 2014 07:07 as a reply to  @ John from PA's post |  #9
Thanks for all the responses. I was shooting in both RAW and JPG with normal NR. I've eliminated the JPEG shooting and disabled NR. I don't see why I'd need JPEGs now that I have Lightroom to post process.
Ain't Nature Grand!
Frodge
Joined Nov 2012
Mar 06, 2014 07:21 |  #10
Larry Johnson wrote in post #16738340 (external link)
It's nice having the JPEG as well imho. I've filled the buffer a couple times with my 60d, bu it's rare. Maybe don't machine gun as much...
2,712 views & 0 likes for this thread, 7 members have posted to it.
1904 guests, 130 members online
