Thread started 05 Mar 2014 (Wednesday) 22:12
Easier Way to Evenly Space Layers
RandMan
Joined Mar 2012
Mar 05, 2014 22:12 |  #1
So I am playing around with more graphic design type stuff than usual in Photoshop. I started designing a camera viewfinder out of a bunch of vector shapes and you can see in the screenshot what I've got started.
How do I space things evenly across a certain area or layer? I am no stranger to guides and smart guides which I have used a lot, but here is the problem I'm experiencing now (I guess it's not really a "problem", but rather the way I'm doing it now feels unnecessarily tedious). Let's say I want the very left and the very right focus points to be exactly the same distance from the center focus point. Right now what I'm doing to achieve this is moving one focus point to the dead center of the middle circle, then using the move tool I am counting how many shift-arrow nudges I do out to the left or right. Then I will need to grab the other one, move it to the center, and shift-click that same number of times again. Then for the corner focus points, I would have to move each one to the center of the middle ring, then count how many times I go right or left, then up or down after that.
There has to be a much simpler way to do this, right?
IMAGE: https://photography-on-the.net/forum/images/hostedphotos_lq/2014/03/1/LQ_678952.jpg
Image hosted by forum (678952) © RandMan [SHARE LINK]
Canon eos7D | Canon 50mm 1.4 | Canon 17-55mm 2.8 | Sigma 70-200mm 2.8 | Yongnuo 565ex | Yongnuo yn-468 II | Canon ef28-135mm 3.5/5.6 | Canon ef-s 55-250mm 4.0/5.6
nathancarter
Gallery: 32 photos
Mar 05, 2014 22:30 |  #2
Once you have the Move tool selected, there are a bunch of buttons in the toolbar at the top, to evenly spread or space all selected layers. Might take a little bit of fiddling around to get it to do what you want - such as selecting the top five but NOT the bottom three points, spreading out the top five points, then manually moving the bottom three individually to line up.
You could place the first three points in the top left quadrant, then make three copies of those layers and flip them horizontally, vertically, and both.
Sometimes I will use guide lines and the ruler, pull out a calculator to figure out exactly where (in pixels) to put the guide lines, and align everything that way.
Scatterbrained
Gallery: 267 photos
Best ofs: 12
Mar 05, 2014 22:31 |  #3
Why not use the grid? View>show>grid
500px (external link)
1x (external link)
instagram (external link)
mattertea
Joined Dec 2012
Mar 05, 2014 22:50 |  #4
this is much easier to do in Illustrator
here is a tutorial for a "step and repeat pattern"
http://blog.smartpress​.com …r-step-and-repeat-banners (external link)
Sculpting Blog (external link)
Scatterbrained
Gallery: 267 photos
Best ofs: 12
Mar 05, 2014 22:57 |  #5
You can do "step and repeat" in Ps as well, but for what he's doing I don't know how useful that would be. He could also create one side. Duplicate it and flip it.
1x (external link)
-Douglas-
Beware of DOUG
Gallery: 151 photos
Mar 05, 2014 23:22 |  #6
Seems like you are making things hard on yourself when you already know about guides, ruler, grid, and snap-to funtions. Also, linking a particular set of layers can be moved as a group. Holding down the Cmd key(I think for Macs) + click on the objects will constrain movement horizontally or vertically.
Edit My Images- OK"Brain Fart" = an essential bodily function.
RandMan
Joined Mar 2012
Mar 05, 2014 23:29 as a reply to  @ -Douglas-'s post |  #7
Thanks for the help, peoples. I ended up making a few hollow, color-stroked rectangles and snapped them to the inside of the white area. Then used those to snap the focus points up against - it worked out really well. Got a bunch lined up and spaced evenly, now just need to create all the little icons for the bottom like the flash arrow, battery symbol etc. This is where I'm at now:
IMAGE: https://photography-on-the.net/forum/images/hostedphotos_lq/2014/03/1/LQ_678954.jpg
Image hosted by forum (678954) © RandMan [SHARE LINK]
1,191 views & 0 likes for this thread, 5 members have posted to it.
1061 guests, 102 members online
