Thread started 06 Mar 2014 (Thursday) 01:32
Lens, Camera or me?
Ghostwheel00
Joined Mar 2014
Mar 06, 2014 01:32 |  #1
I am a hobbyist. For many years I took incredible pictures with a Kodak Z612. Yes, it has a Schneider-Kreuznach lens, and I can adjust almost every setting on it known to DSLRs, but it's mostly a point and shoot. I decided to try a Canon T2i several years back. I only have the two lenses that came with it, an EFS 18-55 IS and an EFS 55-250 IS. I take mostly outdoor landscape shots. Many of the pictures have no depth. They are not always sharp, not like the Kodak pictures. People in the pictures don't pop out from the background. I can't catch a decent bird shot, even with shutter at 1/1000 and aperture at f8. Flowing water pictures don't have that misty quality. Since I know I am capable of taking those kinds of pictures, I'm trying to figure out if it's the lens, and if so what lens (or lenses) should I look into; if it is the camera (am I expecting too much from a consumer grade camera?); or if it is just me and the camera together that don't work. The weight isn't a problem, I know how adjust my settings for the situation, I only use the viewfinder, in burst mode I can usually get one photo that looks decent (out of 10), and sometimes the planets align correctly and I just get a great shot, but I'm not used to burning through 200 pictures to get 20 decent ones.
I know this is way too generic a question, but does anyone have any suggestions as to where I should start to figure out what is wrong with my picture taking ability and this camera?
1Tanker
Mar 06, 2014 01:47 |  #2
Are you post-processing the pictures from the T2i? That can make or break a photo, shooting digital (as well as with film).
Kel
Gear
Nick_Reading.UK
Joined Nov 2011
Mar 06, 2014 01:53 |  #3
Ghostwheel00 wrote in post #16738053 (external link)
Not knowing your budget I suggest upgrading to Full frame (Since going FF I hardly touch my 60D which is alittle more advanced than your T2i).. Get the 6D and get a good lens like the 24-70 F4 of F2.8 if there is still money in the bag.. ? otherwise start with a 50mm 1.4
EOS 5Dmk3 X2, 60D, EF24-70mm f2.8L mk2, EF70-200mm f2.8L IS mk2, EF85mm f1.8, EF50mm f1.4, EF50mm f1.8 mk1(350D with 18-55mm Sh"kit" lens).
Speedlite 600EX-RT, 430EX II Flash. manfrotto 190XDB tripod, Giottos GTMML 3290B Monopod, B+W 77mm 110 Single Coated filter, Hama 77mm Variable Neutral Density Filter.
DC ­ Fan
Mar 06, 2014 01:54 |  #4
There's nothing wrong with your lens or camera. You're not the first person to discover that DSLR's don't work exactly like consumer-grade compact point and shoot cameras.
Among other things, point-and-shoots have a reputation of over sharpening images.
You'll also learn that DSLR images may require more post-processing than point-and-shoot images.
Bird shots may require a longer lens or the ability and patience to stalk your subject until they're in frame-filling range.
Getting "people to pop out from the background" can require anything from a specific aperture to limit depth of field to control of lighting.
A "misty quality" for flowing water images may require a slow shutter speed.
You face several more years' learning how to get the best out of your equipment. With DSLR's technique is more important than equipment, and post-processing can be more important than technique. All this can be learned, but that takes time.
VirtualRain
Mar 06, 2014 01:55 as a reply to  @ 1Tanker's post |  #5
Post some photos.
Sony a7rII / 24-240 / Zeiss 25, 55, 85
Ghostwheel00
Joined Mar 2014
Mar 06, 2014 01:56 as a reply to  @ 1Tanker's post |  #6
I have done some post processing, and have managed to get some good pictures out of the original raw photos, but I never had to post process any of the old Kodak photos. It just took clear pictures. Sharp around the edges of flowers, soft focus in the background, perfect freeze just as the ATV hits air. I can't get those shots with the T2i, and I don't know why.
Scatterbrained
Gallery: 267 photos
Best ofs: 12
Mar 06, 2014 02:03 |  #7
Ghostwheel00 wrote in post #16738075 (external link)
http://www.amazon.com …ds=understandin​g+exposure (external link)
Buy this book. Read it. It will answer all your questions.
Also, if you have a UV filter on your lens, take it off. ;)
Beyond that, without seeing an image with full exif in tact it's going to be hard to say what your issues may be.
500px (external link)
1x (external link)
instagram (external link)
Scatterbrained
Gallery: 267 photos
Best ofs: 12
Mar 06, 2014 02:08 |  #8
Out of curiosity, are you comparing 100% views of the images? I ask because you're comparing a 6.1mp compact with an 18mp APS-C sensor. 6mp are going be a lot more forgiving.
1x (external link)
davidfarina
Gallery: 43 photos
Joined May 2013
Mar 06, 2014 02:09 |  #9
Had exactly the same problem when i started using a DSLR. I expected the images to blow away the point and shoot cameras. But they simply didnt. I knew what good image quality is since i bought my 135L. Honestly, the 18-55 kit lenses are a real waste for the money IMHO
Sony A7RII | Sony A7S
EF 40 | EF 70-300L | FD 35 Tilt-Shift
FE 16-35 | FE 28 | FE 90
CV 15 4.5 III | CV 40 1.4 MC | Summilux 50 ASPH
Website (external link) | 500px (external link)
rrblint
Gallery: 84 photos
Joined May 2012
Mar 06, 2014 02:46 as a reply to  @ davidfarina's post |  #10
Please post some photos with EXIF intact. Without these we are just guessing as to the nature of your problem.
Mark
DC ­ Fan
Mar 06, 2014 02:49 |  #11
This is a specific case where technique makes all the difference with a DSLR.
Examples:
IMAGE: http://i1174.photobucket.com/albums/r601/kevinlillard/03062014a/20120316a0764_zps834864d8.jpg
Camera Maker: Canon
Camera Model: Canon EOS 60D
Lens: 70-300mm
Image Date: 2012-03-16 12:33:17 (no TZ)
Focal Length: 300.0mm
Aperture: f/5.6
Exposure Time: 0.0025 s (1/400)
ISO equiv: 250
Exposure Bias: none
Metering Mode: Matrix
Exposure: aperture priority (semi-auto)
White Balance: Auto
Flash Fired: No (enforced)
Orientation: Normal
Color Space: sRGB
IMAGE: http://i1174.photobucket.com/albums/r601/kevinlillard/03062014a/20120316a0294_zps9b0d74fe.jpg
Camera Maker: Canon
Lens: 70-300mm
Image Date: 2012-03-16 12:03:50 (no TZ)
Focal Length: 200.0mm
Aperture: f/5.0
Exposure Time: 0.0040 s (1/250)
ISO equiv: 200
Exposure Bias: none
White Balance: Auto
Orientation: Normal
Color Space: sRGB
Long focal length, long distance to subject, long distance to background, largest possible aperture. That leads to a shallow depth of field that isolates subjects from background. The effect is even more pronounced with a faster lens.
Again, DSLR's don't work like point and shoot cameras. The above examples came from equipment that's comparable to your, but it was used in a fashion to isolate subjects from background as much as was possible under the situation available (greater subject isolation would have resulted from a f/2.8 lens).
As already mentioned, with DSLR's, it's not the equipment, it's how the equipment is used.
Sirrith
Gallery: 50 photos
Joined Nov 2010
Mar 06, 2014 03:40 |  #12
Nick_Reading.UK wrote in post #16738070 (external link)
No.
OP is not in need of FF, he is in need of learning how to use his current camera.
Read "Understanding Exposure" as suggested above for a start, and learn to PP. That will make a massive difference in your shots.
-Tom
cdifoto
Don't get pissy with me
Mar 06, 2014 04:19 |  #13
Really? I'd be happy with that keeper rate. :D
sjones
Mar 06, 2014 04:29 |  #14
cdifoto wrote in post #16738165 (external link)
Yeah, exactly, sounds like a good keeper rate to me.
May 2022-January 2023 (external link)
MalVeauX
"Looks rough and well used"
Gallery: 2135 photos
Joined Feb 2013
Mar 06, 2014 04:35 |  #15
Heya,
It's you.
Look at the 18-55 archive thread. People work magic with that lens. It's perfectly capable. And the T2i is perfectly capable.
You simply need to learn to use your tools.
Very best,
10,741 views & 0 likes for this thread, 32 members have posted to it and it is followed by 3 members.
Lens, Camera or me?
2251 guests, 136 members online
