Thread started 08 Feb 2006 (Wednesday) 17:07
USM - Settings - Whats yours?
ronosmena
Feb 08, 2006 17:07 |  #1
hi guys, as for USM in PS - what are you settings? is there a universal or a default that photographers normally use?
150
4
2
does that work? or 100 / 5 / 2?
I know it depends on the image or some use them differently and adjust according what satisfies them.
So what do you think? Thanks
-------------- R O N --------------
"The Only Way To Freeze Time"
www.ronosmena.com (external link)
Instagram (external link)
My Blog (external link)
tim
Light Bringer
Feb 08, 2006 17:36 |  #2
100/2/2 is my standard. The Scott Kelby book gives you start values for a variety of different situations.
Az2Africa
Feb 08, 2006 17:48 |  #3
Defog at 20, 60, 0, then process and final sharpen at 300-400, .3, 5 always works well for me.
"If you're not living on the edge. You're taking up too much room !"
My Gear Arizona's POTN Flickr Gallery (external link)
Tom ­ W
Canon Fanosapien
Joined Feb 2003
Feb 08, 2006 18:02 |  #4
Image dependent as well as DPP settings-dependent, but the usual I use is about 85/.3/0 with 1 or 2 setting on DPP (on a scale of 0-10). If there's a bit of softness, I'll resort to a 2 or 3 stage sharpening routine ranging from course to fine.
If there's noise, I'll set DPP to 0 and reduce noise before sharpening, or better yet, open the RAW files with ACR since it has noise-reduction at the RAW level rather than in the 8-bit JPG. Once noise is under control, I'll apply sharpening in a coarse-medium-fine progression.
Tom
5D IV, M5, RP, & various lenses
Desertraptor
Gallery: 212 photos
Feb 08, 2006 18:06 |  #5
What ever looks best.
Peter
Canon 6D|60D|40D
Lens 10-22mm f2.8|50mm f 1.8|100mm f2.8 Macro
24-70mm f2.8|L100-400mm f4.5-5.6L
Flash 430EX II
Telescope Skywatcher 600mm ED80 f7.5 GEM EQ3
subtle_spectre
Feb 08, 2006 18:20 |  #6
So far, it is clear that the respondents are all over the board with the settings. What about the Canon prescription...what is it....300/.3/0? In the end, imo it is a mtter of image contingency. A portrait will require different settings than, say, a landscape. I will be interested to see more suggestions.
Scott
Vista owner...and user  :p _______________
Gear
www.scottcphotography.​com (external link)
Hellashot
Joined Sep 2004
Feb 08, 2006 21:05 |  #7
Convert from RAW with zero sharpening.
For 4x6 prints:
iso100/200 450/0.5/0 or 1
iso400 400-425/0.4/1 or 2
iso800 350/0.4/2 or 3
5D, Drebel, EOS-3, K1000
lenses from 12mm-500mm
Tom ­ W
Canon Fanosapien
Joined Feb 2003
Feb 09, 2006 05:06 as a reply to  @ subtle_spectre's post |  #8
300/.3/0 is recommended for 1-series cameras with in-camera and RAW sharpening set to 0. The 1-series at "0" appears to have no sharpening at all, and thus is a candidate for the greatest amount of PP adjustment. By keeping sharpening low at the start, greater flexibility is given to post-processing. For example, sharpening accentuates image noise, so it is a good idea to control for noise before adding sharpening to an image.
If the in-camera sharpening is set above zero (as it is by default in the 20D, 10D, XT, and in some picture styles on the 5D and 1D IIn), less PP sharpening is necessary, but perhaps at the expense of flexibility later.
I shoot RAW so I have the ability to adjust sharpening in DPP before I convert to JPG. That allows me to make the decision as to whether to keep what the camera gives me or alter it while still in RAW. I generally like how the 5D does sharpening, so unless I've got a noisy image, I keep a modest amount of the in-camera sharpening on my images.
Tom
mickle
Joined Aug 2004
Feb 09, 2006 05:13 |  #9
If needed, on average 90/0.3/0
My Current Skype Status is:
IMAGE: http://mystatus.skype.com/smallclassic/mickleuk.png
IMAGE LINK: http://callto://mickle​uk  (external link)
Mike
Visit Mikes Scripts & Actions (external link) for:
Photoshop framing scripts for CS & CS2 & CS3
Framing Script for Photoshop 7 & CS
Dynamic Velvia script for CS & CS2
Framer Action Set for PS7
Framer Action Set for PS Elements
Mikes Framer thread
subtle_spectre
Feb 09, 2006 05:45 |  #10
Maybe there is further clarification needed...perhaps just in my head, but some useful global setting will depend on whther one shoots raw images or jpgs, yes? While I usually shoot in raw and don't apply any sharpening in conversion, higher settings would typically be needed in PS or other program. When I do shoot in jpg, I use the in-camera settings at a rate that gives me nearly useable images from the camera.
Scott
Gear
vjack
Feb 09, 2006 05:54 as a reply to  @ subtle_spectre's post |  #11
I find I get better results with Smart Sharpen. However, lately I've been using TLR's Professional Sharpening Toolkit and love the results. See http://www.thelightsri​ghtstudio.com …onalSharpeningT​oolkit.htm (external link)
Canon 20D
Canon EF-S 10-22mm f/3.5-4.5 USM
Sigma 18-125mm f/3.5-5.6 DC
Tamron 28-75mm f/2.8 XR Di LD
Canon EF 50mm f/1.8 II
Canon EF 70-200mm f/4L
Canon EF 100-400mm f/4.5-5.6
L IS
Canon Speedlite 430EX
Manfrotto 3021BPRO; Kirk BH-1 ballhead
Canon Pixma 4200
< see my gallery (external link) >
JMAS
Joined Mar 2004
Feb 09, 2006 10:01 |  #12
I shoot Raw, and do absolutely no sharpening in conversion (ACR).
In Photoshop:
If i do it manually:
- it depends if it is a portrait or a landscape and what ISO.
Also depends on wether I want to keep the bokeh smooth or not. Where the bokeh is important, I don't sharpen at all. I try to select the part of the image which I want to sharpen and leave the bokeh untoutched.
On regular conditions:
more or less 16/60/7 for contrast adjustment
then 300/0.3/0
then usually 50/0.3/7 for final adjustment when printing.
Otherwise I use the same settings, but using the smart sharpen filter in PS.
I'm nowadays trying out the Glen Mitchel TLR Sharpenning toolkit which he was kind enough to make available for all, and I think it is very powerful and really saving a lot of work, uses layers and allows to adjust the opacity of the sharpenning layer to much my content :), but I'm still getting used to it.
Cheers,
Jaime
______
Gear
Some photos (external link)
ScottCarlin
Joined Feb 2006
Feb 09, 2006 10:42 |  #13
For jpg:
I typically stay within a radius of about 1.7 to 2.0, and then mess with the percentage from there, usually ending up with between 40 and 80%.
I see a lot of people here using a very small radius, and cranking the percentage way up. I'll have to try that.
It is interesting to see that people's techniques are all over the board. In the end, I say do whatever looks best, but be sure not to oversharpen. There's nothing worse than an image with "USM halo's" around everything in the picture.
2,039 views & 0 likes for this thread, 11 members have posted to it.
2545 guests, 94 members online
