Thread started 06 Mar 2014 (Thursday) 11:48
Is this lens decentering? - Rokinon 14/2.8
Scrumhalf
Gallery: 158 photos
Joined Jul 2012
Mar 06, 2014 11:48 |  #1
I finally did a sharpness test and I am worried that my lens has decentering... this was a photo taken of my home library from about 6 feet away. Manual focus @ F2.8, on a tripod, leveled, etc. The UL and UR seem to be blurry relative to the center, LL and LR. All images are shot in RAW on a 6D, SOOC, no corrections whatsoever.
Does this look unusually bad? This is my first UWA but everything I have read is that the Rokinon 14/2.8 has very good sharpness across the entire field, so I am wondering if my copy is below average.
Should I exchange the lens for another? Thanks!
Full Frame:
IMAGE: http://farm3.staticflickr.com/2051/12971744333_75565c2854_b.jpg
IMAGE LINK: http://www.flickr.com …87114888@N07/12​971744333/  (external link)
IMG_0269 (external link) by Scrumhalf (external link), on Flickr
Center:
IMAGE: http://farm8.staticflickr.com/7387/12971741333_b4435feb89_b.jpg
IMAGE LINK: http://www.flickr.com …87114888@N07/12​971741333/  (external link)
IMG_0269-2 (external link) by Scrumhalf (external link), on Flickr
Upper Left:
IMAGE: http://farm8.staticflickr.com/7443/12971601115_f32898ee07_b.jpg
IMAGE LINK: http://www.flickr.com …87114888@N07/12​971601115/  (external link)
IMG_0269-3 (external link) by Scrumhalf (external link), on Flickr
Upper Right:
IMAGE: http://farm3.staticflickr.com/2036/12971743143_4c5cdfba38_b.jpg
IMAGE LINK: http://www.flickr.com …87114888@N07/12​971743143/  (external link)
IMG_0269-4 (external link) by Scrumhalf (external link), on Flickr
Lower Left:
IMAGE: http://farm8.staticflickr.com/7309/12971600385_236859029a_b.jpg
IMAGE LINK: http://www.flickr.com …87114888@N07/12​971600385/  (external link)
IMG_0269-5 (external link) by Scrumhalf (external link), on Flickr
Lower Right:
IMAGE: http://farm8.staticflickr.com/7349/12971742103_a3603f858c_b.jpg
IMAGE LINK: http://www.flickr.com …87114888@N07/12​971742103/  (external link)
IMG_0269-6 (external link) by Scrumhalf (external link), on Flickr
Sam
5D4 | R7 | 7D2 | Reasonably good glass
If I don't get the shots I want with the gear I have, the only optics I need to examine is the mirror on the bathroom wall. The root cause will be there.
Talley
Talley Whacker
Gallery: 46 photos
Joined Dec 2011
Mar 06, 2014 11:50 |  #2
By your main photo you are not square to the wall of books. Your focus is a tad off and not by much.
A7rIII | A7III | 12-24 F4 | 16-35 GM | 28-75 2.8 | 100-400 GM | 12mm 2.8 Fisheye | 35mm 2.8 | 85mm 1.8 | 35A | 85A | 200mm L F2 IS | MC-11
My Gear Archive
Scrumhalf
Gallery: 158 photos
Joined Jul 2012
Mar 06, 2014 11:53 |  #3
Hmmm.. I tried to align things as best as a could by eye.. maybe I need to measure the right side and left side of the camera to the wall using a tape measure. I'll try again tonight. Thanks for the suggestion.
While I want to make sure I have a good copy of a lens that appears to have significant copy to copy variation, sometimes I wonder if I should just crop the corners off and call it done. :)
Sam
mwsilver
Gallery: 54 photos
Joined Oct 2011
Mar 08, 2014 13:06 |  #4
Scrumhalf wrote in post #16738949 (external link)
Much of the light appears to be coming from the right side, based on the bright sheen I see on many of the books. See if you can shoot something with more even lighting across the whole image.
Mark
Nikon Z fc, Nikkor Z 16-50mm, Nikkor Z 40mm f/2, Nikkor Z 28mm f/2.8 (SE), Nikkor Z DX 18-140mm, Voigtlander 35mm f/1.2, Voigtlander 23mm f/1.2, DXO PhotoLab 5 Elite, DXO FilmPack 6 Elite, DXO ViewPoint 3
Adharr
Joined Mar 2014
Mar 15, 2014 01:44 |  #5
I agree with Talley. Your composition isn't perfect and using a tape measure isn't going to help you with the error you made in this photo. Look at the distance of the top shelf to the top of the image frame, and bottom shelf to the bottom of the image frame. Now look at the difference between the left and right sides. You took the picture at a slight angle to your bookcase. Shooting this at f/2.8 gave you the worst depth of field to determine if there is a focus problem. To test for decentering, put your lens out of focus and photograph points of light. If the bokeh of the points of light is asymmetrical like ovals or egg shapes, then you have a decentered lens. If it's like the aperture blades are supposed to make it, then there is no decentering problem.
Considering depth of field at f/2.8 I would guess your copy is fine actually. But let's make sure. Instead of taking a photograph at the aperture that is going to give you the worst depth of field, take another one at f/11 and then see if that overcomes error in composition if you can't align it perfectly in the viewfinder.
My Homepage (external link)
Scrumhalf
Gallery: 158 photos
Joined Jul 2012
Mar 15, 2014 02:12 |  #6
Thanks for the suggestions. I plan on doing some more shooting this weekend with it. I'll keep your inputs in mind!
Sam
2,760 views & 0 likes for this thread, 4 members have posted to it.
2264 guests, 138 members online
