Thread started 06 Mar 2014 (Thursday) 16:23
DOF difference between the 85mm 1.2 and the 50mm 1.2
Nick_Reading.UK
Joined Nov 2011
Mar 06, 2014 16:23 |  #1
Question.. If I am shooting with both lenses (I haven't got them yet ;-)a )
And I get exactly the same shot (let's say the ears are exactly in on the face with both cameras) which means I have to step back with the 85mm to get the exact shot..
My question is.. Because I have a greater distance to subject with the 85mm will my DOF be wider because I am further away?? I am thinking it must be.. Or am I incorrect ??
EOS 5Dmk3 X2, 60D, EF24-70mm f2.8L mk2, EF70-200mm f2.8L IS mk2, EF85mm f1.8, EF50mm f1.4, EF50mm f1.8 mk1(350D with 18-55mm Sh"kit" lens).
Speedlite 600EX-RT, 430EX II Flash. manfrotto 190XDB tripod, Giottos GTMML 3290B Monopod, B+W 77mm 110 Single Coated filter, Hama 77mm Variable Neutral Density Filter.
gonzogolf
dumb remark memorialized
Gallery: 14 photos
Mar 06, 2014 16:24 |  #2
http://www.dofmaster.c​om/dofjs.html (external link) Run your scenario here.
Copidosoma
Mar 06, 2014 16:29 as a reply to  @ gonzogolf's post |  #3
They will be the same.
Gear: 7DII | 6D | Fuji X100s |Sigma 24A, 50A, 150-600C |24-105L |Samyang 14 2.8|Tamron 90mm f2.8 |and some other stuff
http://www.shutterstoc​k.com/g/copidosoma (external link)
https://500px.com/chri​s_kolaczan (external link)
Nick_Reading.UK
Joined Nov 2011
Mar 06, 2014 16:33 |  #4
gonzogolf wrote in post #16739631 (external link)
The 85mm seems to have less DOF.. I am wondering why. Maybe I calculated incorrectly :o
Nick_Reading.UK
Joined Nov 2011
Mar 06, 2014 16:34 |  #5
Copidosoma wrote in post #16739640 (external link)
But the rule is the further away you are the greater the DOF increases.. Or not??
Nick_Reading.UK
Joined Nov 2011
Mar 06, 2014 16:38 |  #6
I calculated the 50mm at 5metres and the 85mm at 8 metres and the 85mm has less DOF.. Wow!!!
gasrocks
Mar 06, 2014 16:41 |  #7
Be honest with us and yourself, how often are you going to shoot either lens at 1.2?
Nick_Reading.UK
Joined Nov 2011
Mar 06, 2014 16:43 |  #8
gasrocks wrote in post #16739663 (external link)
I am trying to understand the concept of it, the same rules would apply to shooting at 1.8 or 2.2 with both lenses:)
sandpiper
Mar 06, 2014 16:43 |  #9
Nick_Reading.UK wrote in post #16739650 (external link)
Yes, and the longer your focal length the more your DOF decreases. In general, if you are framing your subject the same, the extra DOF you get from moving further back is cancelled by the shallower DOF you get from using a longer lens, so the DOF remains more or less the same with no significant shift either way.
Copidosoma
Mar 06, 2014 16:44 |  #10
With the same FL, yes, DOF increases with distance. Once you change the focal length it isn't so clear.
Careful with the DOF calculator (not only because of the assumptions on which it is based). You need to know the exact distance difference to get the same framing.
A quick look shows the 50mm with a FOV of 39.35 degrees, the 85 has 23.54 degrees. Proportion is 1.67. So assuming (not 100% sure this is correct) that the distance to subject with the same framing for the 85mm is 1.67x the distance for the 50mm, I get a DOF of 0.86 vs 0.83 (at 10ft and 16.7 feet). That would be a hard difference to demonstrate in an image.
sandpiper
Mar 06, 2014 16:45 |  #11
That is irrelevant, they would still have the same DOF at f/8, f/16 whatever.
Nick_Reading.UK
Joined Nov 2011
Mar 06, 2014 16:47 |  #12
sandpiper wrote in post #16739667 (external link)
Nice one.. Cheers, I didn't know that !!!! Next time I am in Mathew street I will invite you for a beer :-)
TeamSpeed
01010100 01010011
Gallery: 103 photos
Joined May 2002
Mar 06, 2014 19:00 |  #13
This is something I put together a long time ago, maybe it would be helpful here?
IMAGE: http://teamspeed.smugmug.com/Electronics/Reference-Material/i-VDMSFhL/0/O/DOF_combinedset2.jpg
For Sale: 7D Mark II
For Sale: Sigma USB Dock
For Sale: Ladies Thirty-One Camera Sling
Ladera
Mar 06, 2014 22:56 |  #14
TeamSpeed wrote in post #16739963 (external link)
This is great! Thanks.
5D Mark III / 35L / 24-105L / 600ex-rt
Nick_Reading.UK
Joined Nov 2011
Mar 06, 2014 23:51 |  #15
Ladera wrote in post #16740385 (external link)
+ 1 bw!
4,757 views & 0 likes for this thread
Latest registered member is HamPhoto
1038 guests, 317 members online
