Thread started 07 Mar 2014 (Friday) 04:39
issues using Backup to NAS
birderman
Joined Mar 2011
Mar 07, 2014 04:39 |  #1
this problem doesn't necessarily relate directly to photography but it is the system I currently use for backing up all my photos.
I have a NAS drive which I use for backups. I run backup software on desktop or other PC connected to the my home network...due to the large number of files that I need to backup the procedure can take several hours so I normally leave it running over night.
However, quite frequently I find that the backup has failed with error message similar to 'the network drive or file is not available'. This error seems to occur at different times for no discernible reason and when it does occur the backup software cancels the backup and removes any of the backup files it has created thus far. The most successful way to backup so far is to do it in smaller and time consuming chunks.
I believe this is a problem with Windows network configuration/options as I have had the same issues regardless of Windows version (XP, 7 and 8.1) or NAS drive (Buffalo, WD, or Seagate have been tried) or even the different backup software that has been tried. I have searched the internet for solution but just get bamboozled by the number of inaccurate search results or non-applicable suggestions. Hopefully someone on these forums has had similar issues or has experience enough to suggest a possible solution.
Thanks in advance for help.
Birderman
London, UK
my photos on Flickr (external link)
My Website (external link) or my Facebook - KishWphotos (external link)
PLLphotography
with the TF
Mar 07, 2014 06:08 |  #2
is your computer set to go to sleep at any point? how about your network connection? there's a checkbox that says to turn off the device to save power.
what model NAS do you have?
I use a standard USB 3.0 Single external drive for a local backup, and Crashplan for off-site backup of my files.
Phillip - phillipwardphotography​.com (external link) | Instagram (external link) | Donate to POTN
cagenuts
Joined Mar 2011
Mar 08, 2014 22:20 |  #3
birderman, I also think you need to check that setting on your nic.
The other change I would make is to amend your backup configuration to only copy incremental changes which should speed things up drastically.
...Ask me anything, I'm an ultracrepidarian.
Hilton
C A N O N | 6D | Σ f/1.4 | 24-70 f/4 | 70-200 f/2.8 II | Kenko Pro300 DGX 1.4 TC |
Tdragone
Joined Sep 2004
Mar 11, 2014 00:58 |  #4
Are you connected wirelessly or wired? our company has had issues with sustained large file transfers on some Lenovo laptop models, but hardwired to the same router everything is fine. Any chance you can connect with a lan cable to router to main pc/buffalo and try again?
-Tom Dragonetti
Spyder Holster + 1Dmk IV, 50D, G11
10-22, 16-35 2.8Lii, , 24-70 2.8Lii, 50mm 1.4,
70-200 2.8Lii IS, 100-400L IS
1.4x TC, 580EX ii, ST-E2
865 views & 0 likes for this thread
Latest registered member is VickyM
2253 guests, 346 members online
