Thread started 07 Mar 2014 (Friday) 21:03
how to correct panorama distortion created by UWA + parallax error?
the.forumer
Joined Oct 2011
Mar 07, 2014 21:03 |  #1
IMAGE: http://i.imgur.com/UrBsXkO.jpg
I understand that I should not have used a UWA (17-40L) without a proper pano head to get no-parallax.. but just curious - what's the possibility of correcting it after the fact? anywhere i can refer to for correcting the distortion seen above?
thanks!
kirkt
Mar 07, 2014 21:10 |  #2
Try using "Smartblend" to blend the images.
http://wiki.panotools.​org/SmartBlend (external link)
The image you posted is pretty small - to what specific parallax issues are you referring?
kirk
Kirk
the.forumer
Joined Oct 2011
Mar 07, 2014 22:11 |  #3
kirkt wrote in post #16742424 (external link)
kirk
using smartblend gives similar results.
notice in the image that the room should be linear (completely straight) instead of converging 'V' shaped lines.
the parallax issue is with regards to the lens/nodal point itself.
BigAl007
Gallery: 556 photos
Mar 08, 2014 06:45 |  #4
The only way that you could photograph that room without introducing the curved effect is to set the camera up on a long rail and take the pano by sliding the camera along the rail parallel to the wall behind you. Otherwise you will always be dealing with the problem that the far side ends of the room are always much further away than the center of the room directly in front of you. Getting further away from the "straight" line you are trying to photograph the less apparent distortion you will get, as the differences in distance are much reduced. This is why you tend to not notice this with landscape images, far fewer straight lines, and they are usually much further away. Even so anywhere where you have a wide pano and straight lines this becomes an issue.
For example in this just over 360 degree example I was positioned on a mound that ran parrallel to the right hand dirt track in the center of the image. That track then makes a 90 degree left turn next to the gate, and then runs away again. Even though the track takes a left turn almost right in front of me the fact that the turn is so much closer than the two parts of the track running away from me still ends up giving the effect of the tracks actually bending to the right. The only real way to correct this would be to print it out and mount it on a curved (concave) backing so that all of the components regain the correct appearance. With a 360 pano you would mount it in a circle and stand in the center
IMAGE: http://farm3.staticflickr.com/2825/11720107494_160d143434_o.jpg
IMAGE LINK: http://www.flickr.com …s/alan-evans/11720107494/  (external link)
Stickledown Panorama (external link) by alan-evans (external link), on Flickr
I suppose that you could try a similar effect in PS, but the problem is that you would need to map the image on to the inside of a sphere of the correct radius and then crop a rectangle from it. This would either need a very high resolution image (at least near the final Z axis) or lots of enlargement of the image at large distances from the Z axis. Not to mention finding just the right radius of sphere to do the projection with.
Alan
kirkt
Mar 08, 2014 17:40 |  #5
Oh - your issue is not parallax, it is the spherical projection of your image. You can use the adaptive wide angle tool in PS CC to straighten the curved lines that should be straight.
kirk
Kirk
the.forumer
Joined Oct 2011
Mar 09, 2014 00:20 |  #6
BigAl007 wrote in post #16742989 (external link)
Alan
yup, though that would be logistically tough to get the rail lined up properly throughout the length of the room.
kirk
i tried using that tool in PS CC but it seems to have no effect on straightening at all (tried all the available options @ dropdown).
kirkt
Mar 10, 2014 12:55 |  #7
^^ You have to actually lay down lines in the preview window and specify them to be straight - you can force them to be vertical or horizontal, too. The menu options give you control over what type of correction you are performing - if you assembled your pano in PS, then select Panorama (it should automatically be selected).
Google Adaptive Wide Angle filter in PS and watch a tutorial.
kirk
Kirk
nathancarter
Gallery: 32 photos
Mar 10, 2014 13:28 |  #8
I've done this method before, and it's not very "clean" either. Each individual image will have some perspective, and when you stitch them all together they don't line up. All those converging rows of chairs are going to make a huge mess.
Unless you slide along the whole length of the room, and take 30,000 1-pixel-wide images along the length of the slider...
kirkt
Mar 10, 2014 14:55 |  #9
nathancarter wrote in post #16748333 (external link)
Yes - I have done this approach for architectural shots of building fronts on a town street. You have to take a pretty sizable number of images and it will work, as long as there is not a lot of depth portrayed away from the plane with most of the detail. Then you have to be judicious in your masking in of the detail that does recede or protrude.
It sounds like the OP was maybe unaware that the curved lines effect is "normal" for such spherical panoramic images.
kirk
Kirk
StayFrosty
Joined Aug 2012
Mar 12, 2014 02:50 |  #10
Interesting thread, I've tried to do a "straight" panorama of a street of houses before and failed abysmally due not being able to fix the perspective changes between each shot.
I pretty much figured I needed to used a longer lens and get as far away as possible. I wasn't quite thinking 30,000 1 pixel wide images though! BTW wouldn't that technique essentially be the slit scan effect used in 2001:A Space Oddessy and at the finishing post of a horse race?
flickr (external link) Vimeo (external link)
nathancarter
Gallery: 32 photos
Mar 12, 2014 09:55 |  #11
Yep, the slit-scan effect is what I was thinking, but with a moving camera instead of moving subjects. For all practical purposes, it's impossible. Maybe if you poured thousands of dollars into specialized equipment, and dozens (hundreds?) of hours into developing a technique or process.
... and I think the end result would still be unsettling and not believable. NO perspective at all, is gonna be a little weird... like those old "folk art" paintings with the hilariously wrong perspective on people and houses and barns.
[edit] Actually - there's a thread around here somewhere, a guy developed software to read individual images from a movie file, and create a slit-scan effect. So you might be able to accomplish it by putting the camera on a really long slider, and taking a movie as you slide it along the rail. It'd take a little bit of math and experimentation to figure out the right combination of movie framerate and slider speed, but maybe it's do-able.
sarch99
Mar 12, 2014 10:50 |  #12
Watch this video by Serge Ramelli. He describes the Photoshop CC process very well. http://www.youtube.com …wQ&feature=em-uploademail (external link)
Believe in your heart that something wonderful is about to happen.
BigAl007
Gallery: 556 photos
Mar 12, 2014 15:27 |  #13
Nathan the hardware required is not really that difficult to build, could probably do it for around a couple of hundred bucks/quid. you have two options, shoot video and move the camera relatively quickly, or shoot JPEG and move the camera much more slowly. I think RAW would be out as the frame rate possible but the buffer will fill. There are plenty of cameras now though that will shoot continuous JPEGs at a decent rate without filling the buffer. For absolute accuracy you would want to do a step/shoot/step process. The big question then would be your "step" rate and also if you could get away with using more than a single column of pixels, if so how many?. This would actually be like having a giant camera with a very large focal plane shutter.
Alan
pwm2
"Sorry for being a noob"
Mar 12, 2014 15:34 |  #14
nathancarter wrote in post #16752964 (external link)
I have seen some inexpensive digital slit cameras.
They basically function the same as a normal scanner. Nothing too strange with the lens - it's just that the camera sensor isn't a square but a line and you move the camera at a constant speed while recording a "video" from that one-pixel wide sensor.
pwm2
Mar 12, 2014 15:37 |  #15
BigAl007 wrote in post #16753728 (external link)
Alan
A camera with video function and support for emitting raw video can be used without producing huge data volumes - the receiving end of the raw video can throw away most of the video data since all that is needed is a narrow band. If using a single pixel column, then the movement of the camera needs to match the expected horisontal resolution. In the end, it will be very hard to move the camera at so exact speed that the image gets square pixels - better to move too slowly and then rescale horisontally.
6,389 views & 0 likes for this thread, 7 members have posted to it.
1501 guests, 134 members online
