Thread started 09 Mar 2014 (Sunday) 20:55
ISO and picture sharpness - Canon EOS 70D
Brian5757
Joined Jan 2014
Mar 09, 2014 20:55 |  #1
When using a small aperture of f16 I am finding some things are not sharp in focus that should be sharp in focus. I was using ISO 400 at the time so I'm wondering if this could be the reason.
I don't think it would be camera shake as the shutter speed was above 1/125 sec and the object was not moving. The object was at a reasonable distance from the camera. I was using a single center focus point.
Canon EOS 70D
Kit Lens EF-S 18 - 135mm 3.5 - 5.6 IS STM
Kit Lens EF 50mm f1.8
jt354
Mar 09, 2014 21:06 |  #2
ISO 400 on the 70D should cause no noticeable softening of the image, even if noise reduction were enabled. It's more likely that you're just observing the effects of diffraction due to the stopped-down aperture. Not being a physics major, I won't attempt to explain this property of light, but as you stop down beyond f/11 or so on an APS-C camera the results will gradually begin to appear "softer." Hard to tell without seeing image samples
Zenfolio (external link)
Gear: Canon 60D / Canon G12 / Tamron 17-50 f/2.8 / Canon 35mm f/2 IS / Canon 85mm f/1.8 / Tamron SP 70-300mm f/4-5.6 / Speedlite 430 EXII / Slik 700DX legs / Cullmann MB6 head
xarqi
Mar 09, 2014 21:14 |  #3
Yup, sounds like diffraction softening to me. Test for yourself by shooting the same scene at various apertures.
seanp3
Joined Nov 2010
Mar 09, 2014 21:18 as a reply to  @ xarqi's post |  #4
What was your focal length?
1,006 views & 0 likes for this thread
Latest registered member is felixluci
905 guests, 250 members online
