Any recommended square ND filters for the 24mm TS-E? Or are the square ones low quality. I have some pricey 77mm Hoya round ones, but they don't fit, so I'm going square.
texshooter Senior Member 652 posts Likes: 26 Joined Jun 2009 More info | Mar 11, 2014 18:03 | #1 Any recommended square ND filters for the 24mm TS-E? Or are the square ones low quality. I have some pricey 77mm Hoya round ones, but they don't fit, so I'm going square.
bps Cream of the Crop 7,607 posts Likes: 406 Joined Mar 2007 Location: California More info | Mar 11, 2014 18:42 | #2 Singh-Ray make top-of-the-line glass filters, but they come at a top-of-the-line price.
DocFluty Goldmember 1,762 posts Likes: 37 Joined Jan 2010 Location: Gulfport, Ms More info | Mar 11, 2014 21:02 | #3 I use lee filters exclusively and am happy with all of them. My Facebook Fan Page
coogee Member 172 posts Likes: 20 Joined Sep 2013 More info | Mar 12, 2014 02:45 | #4 Does the Lee system work ok with vignetting with this lens? I like shift panoramas and wanted to check they don't inhibit the shift (or tilt) movements in any way. I'm guessing you definitely need the 82mm adapter ring (77mm would be more convenient.)
Paulowen Member 128 posts Likes: 18 Joined Dec 2012 Location: Wales, UK More info | I use a set of Cokin X Pro filters on my 24 TSE. The quality is every bit as good as Lee - I also have one of their SW150 ND grads and the results are identical - no quality loss or colour cast (to my eyes) I am able to mount two filters and employ full lens movements without any issues. Gear? Don't want my wife seeing how much kit I've got
Mar 12, 2014 13:20 | #6 |
coogee Member 172 posts Likes: 20 Joined Sep 2013 More info | Mar 12, 2014 16:37 | #7 Thank you both, Cokin Z Pro looks even more expensive than Lee (here in Australia) alas.
Mar 12, 2014 17:19 | #8 coogee wrote in post #16753897 Thank you both, Cokin Z Pro looks even more expensive than Lee (here in Australia) alas. Didn't mean to hijack the OP... Recommended square ND... you can try the ebay knockoff. That's what I'm doing to get my feet wet with square filters. Up until now, I've been doing HDR and it's been working ok. Sony A7siii/A7iv/ZV-1 - FE 24/1.4 - SY 24/2.8 - FE 35/2.8 - FE 50/1.8 - FE 85/1.8 - F 600/5.6 - CZ 100-300 - Tamron 17-28/2.8 - 28-75/2.8 - 28-200 RXD
lovemyram4x4 Goldmember More info | Mar 12, 2014 19:10 | #9 I use a 120mm(105mmthread)
MikeK Goldmember 1,637 posts Joined Apr 2001 Location: San Francisco area More info | Mar 12, 2014 23:38 | #10 What type of filters are referring to? Square ND filters, Very dense ND filters (10 stop), or Circular polarizer of square shape? While we are at it we might as well cover Grad Neutral density as they fit in the same type of 4"(10cm wide) holder and are the prinicple reason for the slotted filters over the circular. Forget the circular filters for ND or GND use, you can't vertically adjust the position of the transition with a circular GND. Canon 6D, 1DmkII, IR modified 5DII with lots of Canon L, TSE and Zeiss ZE lenses
| Latest registered member is semonsters 1034 guests, 109 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
