Need a reality check please. Sorry to be so long to explain...
Long time Canon user. Had a Rebel, 40D, 1D MK III, 5D II, G9, G12. Many pictures I am proud of.
I bought a 5D III and sold all my other cameras. Took the standard test shots, read the manual cover to cover (seriously) and set it up so that I was very comfortable with the camera. Perhaps the hardest setup issue was a picture style that represented the jpg close enough to the raw so I had a decent indication of what I was shooting.
I took this (now only DSLR) on a Caribbean cruise with family. Only looked at pictures on the LCD and saw some blown highlights which is not unusual and usually not as bad as on the LCD and fixable in Lightroom, but all looked ok. A few blue skies that went white, but did not raise a huge flag. When I got home I saw images on my calibrated monitor that amazed me. For example, bright sunny day, cloudy but blue sky, green water like the following:
![]() | Content warning: NOT AN IMAGE |
or...
I was blown away. What happened? Now I Googled for hours and hours and found others that have had similar 5D MK III issues and there is a ton of "learn the camera", "learn to meter", "it always exposes to 18% gray", etc. And that this is worst in evaluative due to the focus point bias. I read all that. No need for anyone to repeat or re-suggest it. I can tell you historically 90% of my images are shot evaluative and they would NEVER look like this on my other cameras. In fact, the G12 Evaluative is far better than what I get with the 5D III.
Now, not all images were like this from the trip, but way too many. I have maybe 15% keepers. And a number of images so far out I cannot get them acceptable with Lightroom.
Someone mentioned as a cure that they reinstalled the firmware even though it had the most current firmware. I did this and I swear it helped. Who knows. So after this I bought a Novoflex Zebra 18% gray card ( I know Canon is closer to 12-13%) and tested exposure. It shows a 1/3rd under, not unexpected. Actually shows pretty darn good results:
Then took standard pictures. Mostly OK though I swear my 5D II exposed a bit better. Tried eval as well as center weighted. And AI Focus which takes the bias off of eval focus point, etc. OK, but...
Then tried high contrast and the darks are too dark and the highlights too blown out. For example:
I have a ton of time into this now. I find I am lacking trust in the camera. And there are several possibilities:
___Its me and I do not yet understand this camera metering or exposure sufficiently.
___This particular 5D has an exposure issue.
___The 5D III and me are not a good match.
Opinions?
I have spent a number of hours with a great support rep at Canon that feels it is me. Maybe. He also says that the 5D III meters very differently than the 1D MK III and 5D II and this should be expected. And that the 1D X meters differently yet again. Maybe I need to bite that bullet. There are so many features of the 5D III I love like AF and two position AF Micro Adjust for zooms and on and on. And size. I would love to keep it but maybe its not the camera for me and the 1D X would be a better fit?
Anyone have similar issues? Advice?
Thoughts appreciated. And if you are silicon valley and have a 5D III, I would love to compare to know if it is my camera or if it performs as expected.
~Bob
