Thread started 11 Mar 2014 (Tuesday) 21:54
t5i couldn't focus Occasionally
johnj2803
Mar 11, 2014 21:54 |  #1
There are some instances that my camera would not focus. I have to turn it off then on again and sometimes I miss the shot. The scene would be well lit so I dont think light is a problem.
I am using it with a Tamron 17-50mm 2.8 non VC.
I am not sure if there is a problem with the camera or the lens. I cannot reproduce the malfunction on demand.
any ideas?
My flickr (external link)
groundloop
Joined Jun 2012
Mar 11, 2014 22:18 |  #2
Does it ever happen with a different lens? Seems like knowing that would narrow it down to a lens or camera problem (I'm guessing it's a lens problem, but that's just a hunch).
johnj2803
Mar 11, 2014 22:21 |  #3
groundloop wrote in post #16752091 (external link)
i have a 50mm 1.8 that focuses well. I can't be so sure tho because I don't know how to repeat the problem...
Frodge
Joined Nov 2012
Mar 11, 2014 22:27 |  #4
The lens is not being switched to manual focus in error, is it?
“It's kind of fun to do the impossible.” - Walt Disney.
Equipment: Tokina 12-24mm, Canon 40mm 2.8, Tamron 17-50 2.8 XR Di, Canon 18-55mm, Canon 50mm 1.8, Tamron 70-300VC / T3I and 60D
johnj2803
Mar 11, 2014 23:05 |  #5
Frodge wrote in post #16752108 (external link)
No, I make sure its always on AF
apersson850
Gallery: 35 photos
Mar 12, 2014 04:00 as a reply to  @ johnj2803's post |  #6
Often it's the "Lens drive when AF is impossible" setting that's set to OFF. It creates exactly the symptom you describe, if you don't know when to use it and when not to.
Anders
Lowner
"I'm the original idiot"
Mar 12, 2014 04:03 |  #7
Trying to focus extremely closely, inside the lenses designed range, can do it.
Richard
apersson850
Gallery: 35 photos
Mar 12, 2014 04:25 as a reply to  @ Lowner's post |  #8
In combination with the "Lens drive with AF impossible" being set to OFF, yes. Otherwise, the camera will send the lens for a focus hunt.
Of course, if you are aiming at something without any useful contrast, like a blue sky, you get the same thing.
Anders
rrblint
Gallery: 84 photos
Joined May 2012
Mar 12, 2014 07:57 as a reply to  @ apersson850's post |  #9
That's the first thing that I thought of too...Great minds think alike.:lol:
Unfortunately the T5i doesn't have that custom function. Lens drive when AF is impossible is therefore always on.
We need more information.
OP, does the lens hunt or just refuse to move at all? How close is your subject? Does this happen only with plain, single color, or non-contrasty subjects?
Mark
johnj2803
Mar 12, 2014 20:53 |  #10
the lens does not hunt at all. it doesn't move. There is also the absence of the red light in the focus points as if the lens is in Manual focus mode.
the subject is not too close or non contrasty. I can get a picture of the same subject after i turn off and then on the camera in the same distance. Sometimes turning it on and off multiple times for the focus to resume.
hope that helps...
thank you all for the responses!
Frodge
Joined Nov 2012
Mar 12, 2014 21:14 |  #11
At this point I would try a couple different lenses to see if the problem persists.
2,203 views & 0 likes for this thread, 6 members have posted to it.
1319 guests, 130 members online
