Thread started 13 Mar 2014 (Thursday) 15:25
what lens please
tjs42
Joined Nov 2012
Mar 13, 2014 15:25 |  #1
hi my son is into kickboxing and am looking for a not too expensive lens to be able to use at his tournaments. i used a 50mm lens on my canon 1100d on his last one. with help from members on here i captured some good shots ( for me ). i need a lens to be able to zoom in with in case i cant get close to the fights. hopefully something that wont break the bank as i'm not a serious photographer and am new to this. sorry for the long winded explanation :D
many thanks
JeremyKPhoto
Joined Apr 2012
Mar 13, 2014 15:31 |  #2
If you still want to be able to shoot at 1.8, then a zoom is not going to be able to offer that (with the exception of the sigma 18-35). With a zoom, you will be looking at something more along the lines of f/2.8 which is just over a stop slower. So take whatever ISO you were shooting at and imaging shooting at double that. If that is ok with you, then you will be fine, if not however, then you may want to look into another prime. Something like the 85mm 1.8 would be good. But, you will be changing lenses every time you want to "zoom".
5D Mark III / 70-200 2.8L IS II / 24-105L / 50 1.8 stm / Tamron 70-300 VC / Sigma 85mm 1.4 Art
gonzogolf
dumb remark memorialized
Gallery: 561 photos
Mar 13, 2014 15:34 |  #3
As mentioned above most zoom lenses are only f2.8 wide open. So you need good light, and your camera isnt the best at high ISO. the 85 1.8 is good, the 100 f2 is also. If your budget were higher the 135L is sterling.
tjs42
Joined Nov 2012
Mar 13, 2014 15:41 as a reply to  @ gonzogolf's post |  #4
thanks for the info guys. will have a look at the lenses mentioned and price ranges.
gonzogolf
Gallery: 561 photos
Mar 13, 2014 15:42 |  #5
tjs42 wrote in post #16756313 (external link)
$300ish used for the first two. $800 used for the last.
MalVeauX
"Looks rough and well used"
Gallery: 2135 photos
Joined Feb 2013
Mar 13, 2014 15:44 |  #6
tjs42 wrote in post #16756267 (external link)
many thanks
Heya,
What's your actual budget?
I would think a 70-200 variation lens would be a good start.
But depending on budget, maybe one of the 55-250's or a 7X-300 lens would work.
Primes will work better in low light with wider max apertures, but you won't have the zoom option. You will have to change lenses if you need a different field of view, assuming you can't move from where you're at. If 50mm was fine, and you just want some more length for when you're further away, then you could look at an 85mm prime which would be cheap and have fast aperture, or maybe even a 100mm prime with again, wider aperture (F2 and F2.8). After that it gets costly to have a prime. Then again, you could look at something like a mid-range zoom with F2.8 to F4, with IS or equivalent.
You will need to shoot at higher ISO values to keep shutter speed high enough to freeze the action and not get a blurry mess. But you get a lot of noise with this obviously. That's a limitation of the camera.
Zoom options without knowing your budget:
Canon EF-S 55-250 IS STM
Canon EF-S 18-200 IS
Tamron 70-300 VC
Canon EF 24-105 F4L
Canon EF-S 18-135 IS STM
Tamron 28-75 F2.8
Ideal: Tamron 70-200 F2.8 (external link)
Very best,
tjs42
Joined Nov 2012
Mar 13, 2014 15:49 |  #7
MalVeauX wrote in post #16756325 (external link)
Heya,
Tamron 70-300 VC
Canon EF 24-105 F4L
Tamron 28-75 F2.8
Very best,
no real budget limitations as yet. just don't want to get in too deep too fast....
majix
Joined Aug 2013
Mar 13, 2014 15:56 |  #8
+ TAMRON 17-50
Majid flickr (external link)
Facebook (external link)
http://www.mjdpic.com (external link)
gonzogolf
Gallery: 561 photos
Mar 13, 2014 15:59 |  #9
majix wrote in post #16756358 (external link)
+ TAMRON 17-50
So his 50 is too short, and you suggest a 17-50?
MalVeauX
Joined Feb 2013
Mar 13, 2014 16:14 |  #10
tjs42 wrote in post #16756339 (external link)
Heya,
You better set a budget. Otherwise, a $2.5k lens will get recommended.
I would really look to the Tamron 70-200 F2.8 VC at the $1.5k mark. Try to get it used or with a rebate maybe. Ultimately those focal lengths, that aperture, etc, will be super useful in the long run and cover tons of things in one single very good lens.
Very best,
tjs42
Joined Nov 2012
Mar 13, 2014 16:33 as a reply to  @ MalVeauX's post |  #11
thanks for the info guys. i will look at new and used before i make any firm decisions
supremeguyx
Mar 14, 2014 02:16 |  #12
or the 24-105L. Yeah you're using a crop body, but regardless, it's a good lens
EverydayGetaway
Gallery: 11 photos
Joined Oct 2012
Mar 14, 2014 10:14 |  #13
A cheaper alternative would be to pickup an 85/1.8, 100/2 or 135/2.8 SF (last one can only be bought used) to use in conjunction with your 50/1.8.
Fuji X-T3 // Fuji X-Pro2 (Full Spectrum) // Fuji X-H1 // Fuji X-T1
flickr (external link) // Instagram (external link)www.LucasGPhoto.com (external link)
gonzogolf
Gallery: 561 photos
Mar 14, 2014 10:16 |  #14
supremeguyx wrote in post #16757424 (external link)
For low light indoor sports work?
majix
Joined Aug 2013
Mar 16, 2014 07:38 |  #15
gonzogolf wrote in post #16756363 (external link)
I mean above lenses + tamron
5,684 views & 0 likes for this thread, 16 members have posted to it and it is followed by 4 members.
what lens please
1030 guests, 178 members online
