Thread started 13 Mar 2014 (Thursday) 15:45
Birds?
hrblaine
Mar 13, 2014 15:45 |  #1
What's the best hand holdable lens for birds? (on a full frame Canon)
nellyle
Joined Jan 2012
Mar 13, 2014 15:56 |  #2
Version 2 600 or 500.
5D3, 7D2, 1D3, 40D, 14 f2.8 Samyang, 17-40 L, 28-80 L, 70-200 2.8ii L, 200 2.8ii L, 200-400 L, 1.4 ii,
http://chris-stamp.smugmug.com/ (external link)
fogboundturtle
Mar 13, 2014 15:57 |  #3
nellyle wrote in post #16756357 (external link)
he said hand holdable. you must be a strong man. 400mm F5.6 or 100-400L is your best choice.
Canon 5D Mark III, Canon 70D, Canon EF 24-105L, Tamron 150-600mm, Tamron 70-200 F2.8 DI VC USD, Sony A7r, Sony FE 55mm F1.8
howiewu
Mar 13, 2014 16:00 |  #4
400 DO
5DII, 70D
17-40mm f/4 USM L, 24-70mm f/4 IS USM L, 100-400mm f/4.5-5.6 IS USM L, 24mm f/3.5 TS-E L, 35mm f/2, 50mm f/1.4 USM, 100mm f/2.8 IS USM L, 300mm f/2.8 IS USM II L, 430 EX II, 270 EX II, 1.4x TC III, 2x TC III, Kenko Pro 300 1.4x TC
Home Page: http://www.travelerath​ome.com (external link), Blog: http://travelerathome.​wordpress.com (external link)
Tapeman
Sliced Bread
Joined Jan 2004
Mar 13, 2014 16:06 |  #5
I hand hold my 500mm f/4L IS II a lot.
I do however, also use a tripod or monopod sometimes.
Canon G1X II, 1D MKIV, 5DSR, 5DIV, 5D MKII, 16-35/2.8L II, 24-70/2.8L II, 70-200/2.8L IS II, IS, 100-400/4.5-5.6 L IS II, 500/4 L IS II, 24-105/4 IS, 50/2.5 macro, 1.4x MKII, 1.4X MKIII, 2X MKIII,580EX II, 550EXs(2), ST-E2.
Gitzo 1228, 1275, 1558, Lensbaby 3G. Epson 3880, Bags that match my shoes.:)
MalVeauX
"Looks rough and well used"
Gallery: 2135 photos
Joined Feb 2013
Mar 13, 2014 16:10 |  #6
hrblaine wrote in post #16756332 (external link)
Heya,
Price range?
Full frame means you're going to need serious reach to really do it. 400mm would be the starting point in my opinion here. The 100-400L and 400L (prime) are the two starting points in that regard, from Canon. From there, you can start to venture to third party for things like the 500mm Sigma or 600mm Tamron at the same price points. Otherwise, truly "best" means going to the super telephotos by Canon with apertures F2.8 and F4. But we're talking $4k~10k price tags depending on focal length. So again, need a price range to work with, and a lot of those, are hard to hold handheld due to size and weight.
Very best,
badams
Mar 13, 2014 16:14 |  #7
I handhold my 500L version 1 all the time. I will say after 4 straight days in High Island, TX during spring migration last year, I was gave out. But that was literally handholding/carrying it for 7+ miles a day from 7/8am - 5/6pm.
Everyday use: 7D2, 1.4x v3 Canon TC (sometimes the 2x v2 Canon TC), Canon 500mm f4 L IS USM; 6D, 24-105L
http://www.southernokp​hotography.com (external link)
nellyle
Joined Jan 2012
Mar 13, 2014 16:17 |  #8
Yep, it's not too bad once you get used to it, especially if you can brace yourself against something!
gasrocks
Mar 13, 2014 16:28 |  #9
The new long lenses are indeed lighter. Hand holding the 500 and 600 is doable. Yes, monopod helps. Save some $ and buy a 7D then you might be able to get by with shorter lenses.
2loose
Gallery: 227 photos
Joined Apr 2011
Mar 13, 2014 17:24 |  #10
Since you didn't mention about your budget, I would suggest 300mm f2.8L II with 1.4X TC III or 2X TC III. They perform very very well and I use 5D3. That's my birding walk around set up
Body:Canon EOS-5D Mark IV, Fuji X-T3, Samsung Galaxy S21 Ultra.
Lenses: Canon 24mm TS-E f3.5L II, Canon EF 400mm f/4 DO IS II USM, Canon TC 1.4X III, FUJINON XF50-140mmF2.8.
horobosu
Joined Dec 2012
Mar 13, 2014 18:24 |  #11
2loose wrote in post #16756549 (external link)
That's my setup as well, works awesome.
1D4 / 24-70 II / 70-200 II / 100L / 300L II / 1.4xIII / 2.0xIII
watt100
Mar 13, 2014 18:27 |  #12
depends on your budget but the starting point for birds is the 400mm 5.6
http://www.birdforum.n​et (external link)
JeffreyG
Gallery: 42 photos
Mar 13, 2014 20:50 |  #13
The latest supertelephotos are really a lot lighter. The latest 500/4 strikes me as a lens that would be considered reasonable for handholding by some folks as it is 3.1kg.
The 600/4 is 3.9 kg
The 800/5.6 is 4.5 kg.
Those are both (IMO) beyond what most folks can manage without support.
hrblaine
Mar 13, 2014 21:46 |  #14
I've been useing a 70-300 with a 1.4 extender on a 40D. I'm retired so a $10,000.00 lens just isn't doable. Over the years, I've got as primes, a 35 and a 50 plus a Sigma 105 macro. Zooms are the above mentioned 70-300, a 24-105 and a 70-200 f4. Maybe I'll stick with what I have for a bit and suffer along with the 70-300 + 1.4 extender. <g>
1Tanker
Mar 13, 2014 22:17 |  #15
hrblaine wrote in post #16757070 (external link)
In this case, i would definitely suggest the Tamron 150-600VC. While it's far from perfect, great shots can be taken with it. It's got the reach, decent weight (for that reach), and best of all... price... to fill your needs. Keep in mind, there are always compromises, and price (1st) and weight (2nd) are generally the biggest.
Stock is pretty-much non-existent right now, but new batches should be coming out within a month.
Check out the Image-sample thread, to see what it's capable of.
Kel
Gear
3,107 views & 0 likes for this thread, 14 members have posted to it and it is followed by 2 members.
Birds?
1047 guests, 105 members online
