Thread started 13 Mar 2014 (Thursday) 17:42
Which digital cameras use leaf shutters?
Aressem
Gallery: 39 photos
Mar 13, 2014 17:42 |  #1
A friend of mine was nice enough to lend me his X100 for a snowboard photoshoot this weekend. I took it home and did a couple test shots with my Elinchrom Ranger at 1/1000. I'm really impressed with how even the light is across the entire frame, which is exactly what I was hoping for. I'm now majorly considering buying another body for this sole reason alone. I know some of you are probably thinking, WHY?! The ranger has a very short flash duration when used with the Freelite A head. Right. It does, however, it's not enough and I also want to kill more ambient. I hate filters - I find focusing becomes more difficult. So with that said, I'm curious what other cameras are out there that can help me achieve the same result. Fast shutter speeds that also sync with my flash.
I was about to pull the trigger on a local used X100S yesterday but someone beat me to it. Now I'm thinking perhaps I should do a little more research and see what my options are. I am not looking to spend more than $1500 at the absolute most. Ideally, I would like to spend closer to $1000-$1200 (willing to buy used). This means I am NOT interested in medium format :P.
Thanks in advance!
Ryan
Ryan Mackay WEBSITE (external link) | FACEBOOK (external link) | GEAR LIST | Buy & Sell Feedback: 1, 2, 3, 4, 5
msowsun
"approx 8mm"
Gallery: 18 photos
Mar 13, 2014 22:01 |  #2
The G1x and G1x II have leaf shutters. I am not sure of any others.
flowrider
Gallery: 127 photos
Mar 13, 2014 23:11 |  #3
loved leaf shutters when I shot old medium and large format. Nothing like not having to worry about shutter speed with flash.
~Steve~
~ My Website-stevelowephoto.com (external link) ~ Facebook (external link)
Feedback Feedback Feedback
kin2son
Joined May 2011
Mar 13, 2014 23:13 |  #4
My GR uses leaf shutter too :)
5D3 Gripped / 17-40L / Σ35 / 40 Pancake / Zeiss 50 MP / Σ85 / 100L Macro / 70-200 f2.8L II IS / 430 EX II / 580 EX II / Canon 2xIII TC / Kenko Ext. Tubes
EOS M / EF-M 18-55 / EF-M 22f2 / Ricoh GR aka Ultimate street camera :p
Flickr (external link) | My Images on Getty®‎ (external link)
rrblint
Gallery: 84 photos
Joined May 2012
Mar 13, 2014 23:59 as a reply to  @ kin2son's post |  #5
They're oh so quiet too!
Mark
msowsun
"approx 8mm"
Gallery: 18 photos
Mar 14, 2014 00:09 |  #6
I haven't used flash much with my G1x but I can get right up to the max 1/4000 using radio triggers with external flash, external flash in the hotshoe, and also with the built-in flash.
EDIT: Upon closer inspection, it appears that I was wrong about 1/4000. In some modes even though 1/4000 is selected, it will default to a slower speed and/or the light from the flash will not reach the subject. Even at close range. The usable max seems to be about 1/2000 for external flash, but the built-in flash is usable right up to 1/4000.
The only problem with this type of shutter is the max speed is limited by the aperture with or without flash. It has something to due with the way the shutter is actually part of the aperture I think. :confused:
http://en.wikipedia.or​g/wiki/Shutter_(photog​raphy (external link))
"As speeds approach their maximum the shutter is far from fully open for a significant part of the exposure time. Effectively the shutter acts as an additional aperture, and may, for example, cause vignetting or increase depth of field, undesirable if shallow focus is being used creatively."
These are the max speeds on the G1x.
f/2.8 gives you max 1/1600
f/4.0 gives you max 1/2000
f/5.6 gives you max 1/2500
f/8.0 gives you max 1/3200
f/11.0 gives you max 1/4000
felixshmak
Joined Jun 2013
Mar 14, 2014 08:50 |  #7
I think all medium format DSLR has leaf shutter lense, but the shutter speed is caoped at 1/500th sec most of the time.
msowsun
"approx 8mm"
Gallery: 18 photos
Mar 14, 2014 09:21 |  #8
Some people like to use flash outdoors to overpower the sun. If you want to use a fast shutter speed and large aperture for shallow depth of field, you need to remember that the G1x has a variable aperture 28-112 lens that can make it difficult to get shallow depth of field.
IMAGE: http://i2.photobucket.com/albums/y17/msowsun/photo%20stuff/Photo14/_G1x.jpg~original
Aressem
Gallery: 39 photos
Mar 14, 2014 12:42 |  #9
So guys...
To get back on topic, if you know of any cameras with leaf shutters, please, list them! Thanks in advance :)
msowsun
"approx 8mm"
Gallery: 18 photos
Mar 14, 2014 14:51 |  #10
My guess is that only the higher end point and shoots with fixed lenses have them.
Canon G15, G1x, etc
Fuji X100
With the camera switched off, the X100's in-lens shutter is clearly visible. It makes the camera exceptionally quiet in use, and allows flash sync at high speeds - up to 1/2000 sec.
Nikon Coolpix A It has a 7-bladed diaphragm and a lens shutter that work together for essentially silent operation. The in-lens shutter allows the camera to flash sync all the way up to its maximum shutter speed (1/2000th of a second)
Sony Cyber-shot DSC-RX1 The lens, which is designated as a Carl Zeiss Sonnar T*, features a leaf shutter for essentially silent operation (though you can engage a sound effect if you wish). This design means the camera can sync with flashes all the way up to its 1/2000th maximum shutter speed, as well as allowing the lens to reach closer to the front of the sensor.
Leica ??
Any digital camera with a removable lens would not have a leaf shutter.
Nikon V1 ??
EverydayGetaway
Gallery: 11 photos
Joined Oct 2012
Mar 14, 2014 14:57 |  #11
msowsun wrote in post #16757899 (external link)
Yes, but the G1X mark 2's lens is f/2-3.9, should give you plenty of DOF control :cool:
Fuji X-T3 // Fuji X-Pro2 (Full Spectrum) // Fuji X-H1 // Fuji X-T1
flickr (external link) // Instagram (external link)www.LucasGPhoto.com (external link)
gonzogolf
dumb remark memorialized
Gallery: 559 photos
Mar 14, 2014 15:00 |  #12
I dont think he's wanting to go shallow DOF as much as freeze skiers without sacrificing the ambient like you would have to do using ND filters.
16,425 views & 0 likes for this thread, 8 members have posted to it and it is followed by 4 members.
673 guests, 122 members online
