Thread started 14 Mar 2014 (Friday) 23:47
Lens for my 60d
rohitsajeev
Joined Jan 2014
Mar 14, 2014 23:47 |  #1
Currently I've 60D + 50mm 1.8 ..I am planning to buy a zoom lens with good image quality
Help me to choose one.. My budget is 550$ .
one more question , Tamron 28-75mm f/2.8 - Does this lens have Image Stebilization ?
I not using tripod much...
1Tanker
Mar 14, 2014 23:49 |  #2
What would you be shooting with this lens?
No, the Tamron 28-75 doesn't have IS (just as the Canon 24-70/2.8 doesn't).
Kel
Gear
SqueekyBoy
Joined Mar 2014
Mar 14, 2014 23:58 |  #3
You should be able to find a used 18-55 for about $125. If you want to spend more, the 15-85 is a big leap in every way. It runs about $400- $450, used.
No, the 28-75 does not have IS.
flowrider
Gallery: 127 photos
Mar 15, 2014 00:06 |  #4
It really depends on what you shoot but you could do the Tamron 17-50 non VC easily in your budget and it's a great lens. Or with that budget maybe a used Canon 24-105L but it's f/4 and 24mm isn't very wide on a crop camera.
~Steve~
~ My Website-stevelowephoto.com (external link) ~ Facebook (external link)
Feedback Feedback Feedback
slookx24
Joined Jan 2014
Mar 15, 2014 00:07 |  #5
bannedPermanently
Canon 17-55 f2.8
Sigma 17-50 f2.8
Sigma 17-70 f2.8-4
rohitsajeev
Joined Jan 2014
Mar 15, 2014 00:49 |  #6
I want it for landscapes, and as a walkaround lens
1Tanker
Mar 15, 2014 00:56 as a reply to  @ rohitsajeev's post |  #7
For those uses, i would pick the EF-s 15-85 IS over the various 17-5x/2.8 lenses. It has the wider end for landscapes, as well as a greater focal-range for walkaround use.
You should be able to pick one up used or refurbished, for around $500.
Edit: It's excellent IS also comes in handy for walkaround. :)
I would seriously consider trying a tripod for landscape shots, though.
Kel
Gear
rohitsajeev
Joined Jan 2014
Mar 15, 2014 01:25 |  #8
How Important is IS , Can we get good results without tripod in non-IS Lenses?
1Tanker
Mar 15, 2014 01:42 |  #9
rohitsajeev wrote in post #16759825 (external link)
Part of that depends on you. How "steady" you are.
For landscapes, a lot of them are taken at dawn/dusk(sunrise/suns​et), where light may be low and IS or a tripod really helps. You can always bump up the ISO to compensate, but at some point you start introducing unwanted noise into the shot.
For walking around, the faster lenses (17-5x/2.8) can be used without IS, due to the wider aperture, letting in more light= faster shutter speeds. But, that's only if you shoot them at the wider apertures, where depth of field (getting everything you want in sharp focus) can become an issue. As soon as you stop-down that lens, you lose the advantage of the wider aperture, and IS could be a help.
Another thing is, the wider the lens, the less shutter speed needed to keep camera shake at bay. The general rule of thumb is, 1/focal length; so, 100mm=1/100. 24mm= 1/25 (that's for full frame.. with a crop camera, multiply the shutter speed by 1.6 =1/160, 1/40, etc.)
Also, IS only helps with static images, as soon as you're trying to capture a moving image, a faster/wider aperture is needed.. vs, IS.
Kel
Gear
MalVeauX
"Looks rough and well used"
Gallery: 2135 photos
Joined Feb 2013
Mar 15, 2014 04:57 |  #10
Heya,
Canon EF-S 15-85 (used) (external link)
Canon EF-S 17-85 (used) (external link)
You need a tripod for landscape.
You don't need a tripod, nor IS, for walk-around. IS is helpful, but it's not the end-all-be-all. I find it helps with really long focal lengths, and with lower shutter speeds.
Very best,
rohitsajeev
Joined Jan 2014
Mar 15, 2014 05:31 |  #11
Thank you for your replies, But i am from India and second hand lenses are really hard to find . :(
How about sigma 10-20 as walkaround ?
Frodge
Joined Nov 2012
Mar 15, 2014 07:20 |  #12
I pretty happy with the tamron 17-50 non vc I bought about a month or two ago. It's great.
“It's kind of fun to do the impossible.” - Walt Disney.
Equipment: Tokina 12-24mm, Canon 40mm 2.8, Tamron 17-50 2.8 XR Di, Canon 18-55mm, Canon 50mm 1.8, Tamron 70-300VC / T3I and 60D
ct1co2
Gallery: 111 photos
Mar 15, 2014 07:30 |  #13
MalVeauX wrote in post #16759978 (external link)
Not necessarily. Having a tripod for the times it is appropriate is a good idea, but not a requirement for landscape.
OP, a 10-20 would likely be much to wide for a walkaround IMO. Something along the lines of a 15-85 or 17-5x would be a better choice giving you more flexibility.
R6 | R7 | 15-85is | Rokinon 14 2.8 | RF 16 2.8 | 16-35 F4is L | RF 24-105 F4is L | RF 70-200 F4is L | 100-400 II L | Σ150-600 C | 1.4X III | 2X III | 430ex |
1Tanker
Mar 15, 2014 11:31 as a reply to  @ ct1co2's post |  #14
Yeah, 10-20 would most likely be too wide for a walkaround. Some do it, and like it... but not many.
I mean, you have to be conscious of not getting your feet in your shots at the wide end! :)
Kel
Gear
PH68
Joined Jun 2013
Mar 15, 2014 12:30 |  #15
Get a Canon 18-55 IS.
It cost less than £100 new.
Better still, get the new STM version.
It won't break your wallet either.
It's perfectly fine for landscapes and walkaround.
5Diii | 35/2 | 100/2.8L | 300/4L
1,756 views & 0 likes for this thread, 10 members have posted to it.
Lens for my 60d
2264 guests, 138 members online
