Wilt wrote in post #16772535
Have you EVER noticed that the actual dpi of any printer has NOTHING TO DO with the EXIF value embedded in the photo?!
Isn't that what I said?
In spite of that fact, the inherent printer software
DPI is meaningless, because I can take a file from a camera which might have '72 dip' embedded within the EXIF information, and I can make a 4x6" print or an 8x10" print on a Canon printer or a 4x6" print or an 8x10" print on the
Epson printer, and I have previously done NOTHING to change the embedded EXIF value from the camera default '72
dpi', and even though the Canon claims a different
DPI value from
Epson in the print driver software that they provide!
You are getting dpi and ppi mixed up.
Images are made of pixels. The size of a print is amended by adjusting the ppi of the image (the dpi is set inthe printer driver)
Your camera does not "embed" any ppi or dpi setting to your images. ppi figures are set at the time you hit print. The dpi is set when you adjust it in the printer driver.
PPI is a variable figure - not embeded.
When you send trhe image to the printer the ppi controls the size of the print. Nothing else and you can freely change that without affecting the digital image in any way.
dpi' does have a meaning in OFFSET PRESS printing (brochure, magazine, etc. printed material) but NOT in 'photographic' printing; 'ppi' is meaningful in photographic printing
Actually dpi is a throwover from old printing presses of a year gone by. Nowadays they actually use pixels (anything you see on your screen is pixels) and the printer itself uses dpi but these are unrelated. Perople do use dpi incorrectly but it's so engrained now it's almost impossible to change people's views
Yip 9600dpi sounds likje a very high resolution printer! In reality an inkjet printer has to place more than one dot of ink to create the colour of a single pixel so althouygh these numbers sound high the reality is the effective resolution is much lower - Like 300dpi or 360dpi and the like.
the one thing though is that dpi controls the actual quality of the printed image. DPI is known as the quality setting ion ytour printer driver for a reason. Printing at lowest quality (whatever that may be) will result in a pretty useless print. Printing at the highest quality - 9600x24800dpi will result in a high quality print (so long as the image being printed is also decent).
I'm proving my point Wilt and I'm sure plenty would agree - Your arguments are incorrect.
Printers have a matrix of dots, such as 4800x2400, based upon the print head and the incremental movement of the paper feed. But printers also have an inherent
DPI assumption in software, and Canon uses different
DPI assumption in its software than
Epson does.
lol OK Yes printers have a resolution showing something like 4800 x 2400 or 2880x1440 or the like. When you break that down (see above) these are not actually the effective resolution. But we still discussing DPI here - i.e. dots placed on a page pof paper./ The dpi has no effect on the digital image. Only the quality of the print itself.
The
DPI value is mapped by the software into printer instructions which drive the 4800x2400 print head and feed increment.
You set the dpi in the printer driver (if that is the software you mean)?
No direct/fixed relationship betweeen [4800x2400 in the print head] with [360 or 300ppi assumed by software] nor [72dpi/ppi vs. 300dpi/ppi vs. 1000dpi/ppi] embedded in the EXIF data!
The ppi number in the exif data is just a tag and means nothing. It does not affect the image in any way. It can be amended without changing he image in any way - PPI changes the print size.
Again, wrong! I can print three versions of the same JPG, one with '72' , one with '150' and one with '300' embedded in the file versions, and the printed end result -- or the viewed end result on monitor -- will be identical! Try it yourself. I have...using an EXIF editor to alter the values, or using LR parameters in Output to control the creation of JPG files from RAW.
Wait a minute here you are still getting all mixed up. The ppi value iteself does not change the digital image so will appear on your MONITOR as the exact same image (because it is).
BUT if you printing the three images they will each have a different physical print size. The 72ppi image will be slightly smaller then half the size of the 150ppi image and that will be half the size of the 300ppi image (no matter the dpi setting)
Very easy to work out too.
Print Size = Pixels/PPI
So lets take your image above. 4000x6000pixel image
@1000ppi
Print size = 4000/1000 = 4"
Print size = 6000/1000 = 6"
@300ppi
4000/300 = 13.333"
6000/300 = 20"
@100ppi
4000/100 = 40"
6000/100 = 60"
So ppi has only changed the PRINT SIZE - Nothing else is changed.
Go to Image size in Photoshop and switch off the resample button.
Now change the ppi setting (to anything). The number of pixels will not change but the print size does.
It's really very simple and you are getting dpi and ppi mixed up Wilt.
Watch that video a few posts back.
On that point I agree. For the offset press, but NOT at all as a parameter within the EXIF file which affects inkjet printing in any visible way!
Forget offset press.... That means nothing to what we are discussing here - The same principals apply in ALL cases.
You cannot ember dpi or ppi to an image. You can tag the ppi value but you can easily change that without changing the image - The ppi value is not "embedded". It's meaningless until you actually hit the print button and that assigns the print size of the image
Yes, you can affect ink density in the driver software, but not as an input file effect upon quality.
DPI is an OUTPUT value. It's how many dots the printer will place on the paper - that is controlled in the printer driver and yes it changed the densitry of the ink placed on the page.
More ink will equal smoother gradients and a higher quality image (so long as you have a suitable paper).
