Sling camera strap which one do I get
Lone-eagle Senior Member 269 posts Likes: 2 Joined Oct 2007 More info | Mar 15, 2014 11:19 | #1 Sling camera strap which one do I get Dale
Mar 15, 2014 13:35 | #2 Permanent banI favour this one 'The success of the second-rate is deplorable in itself; but it is more deplorable in that it very often obscures the genuine masterpiece. If the crowd runs after the false, it must neglect the true.' —Arthur Machen
JeremyKPhoto Goldmember 1,634 posts Likes: 46 Joined Apr 2012 More info | Mar 15, 2014 13:39 | #3 Alveric, that is not a sling strap. That is for wearing around one's neck. 5D Mark III / 70-200 2.8L IS II / 24-105L / 50 1.8 stm / Tamron 70-300 VC / Sigma 85mm 1.4 Art
Mar 15, 2014 13:47 | #4 Permanent banOoops. Well, I'd use the Upstrap as a sling one. Is there a strict definition for 'neck strap' and 'sling strap'? Not trying to be argumentative, just don't want to provide bad recommendations. 'The success of the second-rate is deplorable in itself; but it is more deplorable in that it very often obscures the genuine masterpiece. If the crowd runs after the false, it must neglect the true.' —Arthur Machen
JeremyKPhoto Goldmember 1,634 posts Likes: 46 Joined Apr 2012 More info | Mar 15, 2014 14:11 | #5 Alveric wrote in post #16760683 Ooops. Well, I'd use the Upstrap as a sling one. Is there a strict definition for 'neck strap' and 'sling strap'? Not trying to be argumentative, just don't want to provide bad recommendations. ![]() I know you are not trying to start an argument :P. Yes, a sling strap is designed to go across the body and point the lens either to the side or down. If you try to use a neck strap as a sling, your lens will be pointing straight out. 5D Mark III / 70-200 2.8L IS II / 24-105L / 50 1.8 stm / Tamron 70-300 VC / Sigma 85mm 1.4 Art
Mar 15, 2014 14:28 | #6 Permanent banGotcha. Thanks. 'The success of the second-rate is deplorable in itself; but it is more deplorable in that it very often obscures the genuine masterpiece. If the crowd runs after the false, it must neglect the true.' —Arthur Machen
mark48 Senior Member More info | Mar 16, 2014 18:18 | #7 I love my BosStrap, http://www.amazon.com …rds=bosstrap+camera+strap
v35skyline Goldmember 3,572 posts Likes: 16 Joined Apr 2007 Location: San Diego, CA More info | Mar 16, 2014 18:49 | #8 Luma Cinch. X100s | X-Pro1 | X-T1 | XF 14 | XF 18 | XF 35 | XF 56 | XF 60 | XF 10-24
MotorOn Senior Member 941 posts Likes: 52 Joined Feb 2007 More info | Mar 16, 2014 18:59 | #9 I use two of these for the cameras http://www.bhphotovideo.com …QcArg&is=REG&Q=&A=details Website
| Latest registered member is MWCarlsson 603 guests, 122 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
