Thread started 15 Mar 2014 (Saturday) 14:25
DIY gliding camera strap with quick release plate
wallace1837
Joined Sep 2011
Mar 15, 2014 14:25 |  #1
Hi,
Is there a reason why I should not use my tripod quick release plate to built this gliding strap?
The plate: e.g. http://www.amazon.com …ting-4-Inch/dp/B001A1RMXG (external link)
The gliding strap: http://howto.cnet.com …$10-gliding-camera-strap/ (external link)
Primes:
Bower 14mm 2.8, Takumar 28.mm 3.5, Bower 35mm 1.4, Takumar 50mm 1.4, Canon 50mm 1.8, mamiya 55mm 1.8, Samyang 85mm 1.4, Meyer-optik 135 2.8, Mamiya 135mm 2.8, Takumar 135mm 3.5, Mamiya 400mm 6.3
Zooms:
Canon 28-105mm 3.5-4.5, Canon 100-300mm 5.6L.
single_track
Mar 15, 2014 14:47 |  #2
wallace1837 wrote in post #16760742 (external link)
Hi,
I would not trust it with my gear, especially the key ring. I bought a bosstrap. Reasonable and I believe much more secure.
I always want C&C on my shots.
Gear list: 70d, 5d & 40d | 70-200L/f4 IS | 24-70L | 17-40L | Sigmalux | 17-85 IS | Opteka 6.5mm fisheye | 580exII
Flickr: https://www.flickr.com​/photos/120400139@N03/ (external link)
Canajun
Mar 15, 2014 15:18 |  #3
Hi,
That 1/4" eye bolt does look a little out of place. I can't see any reason why you cannot use the release plate. With the release plate at least you can still set your camera standing right up. As a matter of fact I used that plate on my paracord wrist strap DIY.
I think there was a discussion here at POTN of the pros & cons of hanging something heavy on that screw hole.
Jun.Roberto.Dizon.Greg​orio
My Photographic Gears.
I Like Shooting Animals Than People.
mark48
Joined Jun 2011
Mar 15, 2014 15:59 |  #4
single_track wrote in post #16760782 (external link)
+1 for the BosStrap. I feel much better supporting my camera from the lugs that were designed to support the camera. I never heard of a lug giving way or coming loose.
C ­ Scott ­ IV
I should keep some things to myself!
Gallery: 766 photos
Best ofs: 9
Mar 15, 2014 17:25 |  #5
The weakest link here is the key ring. A normal key ring (without the hinge) would resolve that.
The next weakest link in the video is the 1/4 inch eye bolt. Not that it is weak but using a wrench could strip the threads in camera. Or the eye bolt could rotate and eventually loosen up if not checked regularly.
You could replace the 1/4 eye bolt with a QR plate that won't rotate and has some sort of loop for the strap connector. The D loop on the quick release plate you linked to is less suitable as a connection point than the eye bolt.
There are much safer options out there and some are very affordable. Good luck.
Charles
www.CScott4.com (external link) | Instagram (external link) | Facebook (external link) | Gear | Image Editing OK and critique welcome.
1,910 views & 0 likes for this thread, 5 members have posted to it.
1249 guests, 116 members online
