Thread started 16 Mar 2014 (Sunday) 14:41
Photos come out blurry on Av Mode on my 600D
larabrileva
Joined Mar 2014
Mar 16, 2014 14:41 |  #1
Hello everyone,
I have recently started using the Av setting on my Canon 600D, I played around a bit on the settings but now my photos come out blurry if I slightly shake the camera when taking.
Unless I'm taking a photo on a table it will just blur.
Can someone help me? Maybe change my Av settings. (I'm shooting in normal daylight)
JeremyKPhoto
Joined Apr 2012
Mar 16, 2014 14:44 |  #2
In AV mode, you decide the aperture and the camera will determine the shutter speed. If you do not have the ISO set high enough, it is possible the camera will select a slow shutter speed to obtain a good exposure. This is likely where your blur is coming from.
5D Mark III / 70-200 2.8L IS II / 24-105L / 50 1.8 stm / Tamron 70-300 VC / Sigma 85mm 1.4 Art
watt100
Mar 16, 2014 14:44 |  #3
larabrileva wrote in post #16762812 (external link)
Hello everyone,
you're probably experiencing a slow shutter speed.
Post a pic with the EXIF data
try increasing the ISO so the shutter speed is increased in AV mode
trewyn15
Joined Dec 2012
Mar 16, 2014 14:45 |  #4
Try something along the lines of:
ISO 1600
F5.6
1/300 Shutter Speed
Better results?
Mitch
Canon T3 - Canon 60D - Canon Rebel 2000
Canon EOS M - Canon PowerShot SD1100IS
Gear/Feedback
larabrileva
Joined Mar 2014
Mar 16, 2014 14:48 |  #5
watt100 wrote in post #16762818 (external link)
xqantw (external link)
Click the link
Here you are, sorry I'm new to photography so I'm not sure what settings I should do.
MalVeauX
"Looks rough and well used"
Gallery: 2135 photos
Joined Feb 2013
Mar 16, 2014 14:49 |  #6
Hello everyone,
Heya,
AV allows for variable shutter. It will meter the light and determine it based on that. If it drops too low, it will blur if you move. Try setting ISO to AUTO with a cap at 1600. Do it again, it will likely have a higher shutter speed, at the cost of ISO noise.
When in low light, don't use automodes. Use manual and figure the exposure yourself. The camera has an internal meter that will give you an idea of where you are exposure wise. Use it.
Very best,
apersson850
Obviously it's a good thing
Gallery: 35 photos
Mar 16, 2014 14:50 as a reply to  @ larabrileva's post |  #7
When using Av mode, you must keep an eye on the shutter speed (displayed in the viewfinder). If it's too long, you have to open up the aperture and/or increase the ISO.
Are you using a stabilized lens (IS) or not?
Anders
MsKutispwet
Joined Oct 2012
Mar 16, 2014 14:51 |  #8
larabrileva wrote in post #16762830 (external link)
HTTP response: NOT FOUND | Content warning: script
be mindful of the shutter speed - if you're confused then Google for the "exposure triangle " ie ISO+ShutterSpeed+Apert​ure.
do your homework and you'll be fine - get back here again for more guidance
EDIT: set your "Auto-Focus Mode" to One-Shot (and not AI Focus) and shoot around f5.6 Av/Aperture or below(instead of f9.0) you got to try it :-)
Dan ­ Marchant
Gallery: 19 photos
Joined Oct 2011
Mar 16, 2014 15:02 |  #9
Unfortunately we can offer guidance but there is no one set of settings that are correct. It varies from shot to shot depending on what you are shooting and what the lighting is like. Blur is usually due to a slow shutter speed combined with either...
  • your camera moving/shaking (because you are hand-holding) or
  • your subject moving.
There is a rough rule of thumb to help with the first one - known as "the reciprocal rule". It states that your shutter speed (in 100ths of a second should be equal or greater than the reciprocal of your effective focal length. In other words, if your focal length is 200mm you need to have a shutter speed of at least 1/200th, if your focal length is 85mm then 1/100th (because the next one would be 1/80th which would break the rule). If your system has image stabilisation this will allow you to further reduce the shutter speed.
Dan Marchant
tonylong
...winded
Gallery: 60 photos
Mar 16, 2014 15:16 |  #10
Here's a good quick read as to the exposure "triangle":
https://photography-on-the.net/forum/showthre​ad.php?t=414088
Tony
rrblint
Gallery: 84 photos
Joined May 2012
Mar 16, 2014 23:21 |  #11
MsKutispwet wrote in post #16762843 (external link)
...set your "Auto-Focus Mode" to One-Shot (and not AI Focus) and shoot around f5.6 Av/Aperture or below(instead of f9.0) you got to try it :-)
^^^^THIS.
Mark
mwsilver
Gallery: 54 photos
Joined Oct 2011
Mar 17, 2014 01:28 |  #12
Click the link
Your link does not show the shutter speed. If you half depress the shutter button, the shutter speed will show up in the blank box just to the left of the aperture. That shutter speed number will change in AV mode depending on the available light. Like the others, I suspect that that the shutter speed is way too low. You also might not have the image stabilization switch on your lens turned on. If you were shooting in low light with an aperture of f/9 it's very possible your shutter speed was way too low in order to compensate. We need an image to see what was going on.
Mark
Nikon Z fc, Nikkor Z 16-50mm, Nikkor Z 40mm f/2, Nikkor Z 28mm f/2.8 (SE), Nikkor Z DX 18-140mm, Voigtlander 35mm f/1.2, Voigtlander 23mm f/1.2, DXO PhotoLab 5 Elite, DXO FilmPack 6 Elite, DXO ViewPoint 3
melcat
Joined Nov 2010
Mar 17, 2014 04:13 |  #13
Dan Marchant wrote in post #16762872 (external link)
The rule applies to "full frame" 24mm x 36mm. On a Canon APS-C camera like the OP's, you need to shoot 1.6x faster, i.e. 1/320s @200mm.
I have no idea what auto-ISO does on the OP's camera, but setting the ISO to 400 instead might yield usable speeds at f/9 in many situations. Easier, though, to put the camera back in full auto.
NewCreation
Gallery: 47 photos
Joined Jan 2013
Mar 17, 2014 04:51 as a reply to  @ melcat's post |  #14
All of the above posts should help. I also recommend getting "Understanding Exposure" by Bryan Peterson. It'll help greatly and it's easy to read.http://www.amazon.com …ds=understandin​g+exposure (external link).
My name is Brenda ~Saved by grace, walking by faith
http://brendahoffmanph​otography.com (external link)
Facebook (external link)
mwsilver
Gallery: 54 photos
Joined Oct 2011
Mar 17, 2014 09:04 |  #15
NewCreation wrote in post #16764133 (external link)
While that book can be very useful, it appears that the OP also doesn't seem to understand how at least some of the basic controls of his camera work.
Mark
7,029 views & 0 likes for this thread, 15 members have posted to it.
2269 guests, 133 members online
