Thread started 17 Mar 2014 (Monday) 08:55
The 6D vs the 60D focus system
giballi
Joined Feb 2014
Mar 17, 2014 08:55 |  #1
Not looking to start a full frame versus crop debate or anything other than just these two camera system's focus systems.
So I picked up a 6D this weekend. My inital impression was disappointment, not with IQ but the focus points on the 6D. I was in my living room and while it wasn't the best lighting, it was far from dark, it seemed that the outter points just don't lock as fast or reliably as the 60D. I get that they aren't double cross-type like the 60D but is there a way to better utlize or familiarze myself with the camera's system? I don't like to just use the center point for composition reasons, what focus modes should I be using for most reliablility. Someone also told me that I should try and focus on a dark contrasty part of the subject to lock on.
I don't need it to be perfect, because I didn't spend as much as I would have on a 5DMKIII but I've seen a lot of great pictures on a 6D so I know it's possible. I guess coming from the 60D to the 6D kind of spoiled me on focus points. I tried out the 6D at Nebraska Furnature Mart and didn't notice it struggling too much with focus. On another note, my brother's 6D he recieved has major trouble locking focus with even the center point (he uses a nifty fifty) so he is exchanging it for a non-faulty one. Even mine doesn't seem as locked in as the one at the store.
What are the best outter points on the 6D and which scenarios should I use them in? The first pics I've taken with the 6D have def done better in low light but my rate that have been in focus haven't been as high as on the 60D, so I'm trying to increase my knowelege and understanding here.
Seriously, lets please limit responses to the focus system and how to better use it, I have the 6D and want to work within it's capabilities. I clearly understand it's not a 5DMKIII. I also want to get constructive help. Thanks in advance.
zosobao5150
Mar 17, 2014 08:57 |  #2
I don't own a 6d, but my knowledge is that the center point is the most sensitive in low light and can focus extremely well. Don't use the outer points in low-light.
Canon 7D, Canon 50mm 1.8, Tamron 17-50 non stabilized, Canon 70-200mm 2.8L IS II, Canon 100mm 2.8, Canon 2x Extender MK III, Canon 580EX Flash
mickeyb105
Gallery: 397 photos
Joined Dec 2011
Mar 17, 2014 09:00 |  #3
Is there a "popping popcorn" emoticon?
Sony A7RIII, Tamron 28mm 2.8 Di III OSD M1:2, Sonnar T* FE 55mm f/1.8 ZA, Canon 200mm 2.8L ii, Sigma MC-11, HVL-F43M
Frodge
Joined Nov 2012
Mar 17, 2014 09:05 |  #4
My 60d nails focus most of the time. The rest of the time it's my fault.
“It's kind of fun to do the impossible.” - Walt Disney.
Equipment: Tokina 12-24mm, Canon 40mm 2.8, Tamron 17-50 2.8 XR Di, Canon 18-55mm, Canon 50mm 1.8, Tamron 70-300VC / T3I and 60D
Keyan
Joined Mar 2011
Mar 17, 2014 09:25 as a reply to  @ Frodge's post |  #5
The Center point on the 6D is more sensitive in low light than the 60D. The outer points are not as sensitive and are not cross type as you mentioned.
The 6D is very much a center point centric camera and from what I have seen it does a good job when center point is used. The outer points are better used in bright or studio lighting situations and their effectiveness drops off in lower light. Lens apertures would also probably come into play with the outer points as well, with wider aperture lenses being able to feed more light to those outer points.
Cameras: 7D2, S100
Lenses: 17-55 f/2.8 IS USM, 18-135 STM, 24-70 f/4L IS USM, 50 f/1.4 USM,70-300L IS USM
Other Stuff: 430 EX II, Luma Labs Loop 3, CamRanger
mclaren777
Joined May 2012
Mar 17, 2014 09:33 |  #6
I own both cameras (though the 60D is literally collecting dust) and I simply use the center point on the 6D at least 90% of the time (back-button focusing) and then recompose.
A simple comparison of sensor technology: Nikon vs. Canon (external link)
A technical comparison of sensor technology: Exposure Latitude (external link)
SqueekyBoy
Joined Mar 2014
Mar 17, 2014 09:39 |  #7
I have a 6D and a 60D. Certainly the AF systems are different. I am used to my 60D just working with any point I choose. The peripheral points of my 6D are OK as long as there is plenty of light and contrast. I bought my 6D for its low-light high-ISO goodness, and at that it excels. I keep vacillating on keeping/selling my 60D because I do, from time to time, shoot moving targets. I think I'm going to work with the 6D a bit more before I decide about the 60D.
I had a 50 1.8. I think your brother's problem is the lens, not the camera.
giballi
Joined Feb 2014
Mar 17, 2014 09:40 |  #8
mclaren777 wrote in post #16764490 (external link)
So you've adjusted to the 6D it sounds like. How accurate is this back-button focusing when using wide apertures. I assume at 1.4 or so it would be difficult or does it nail focus?
HazemG
Joined Jan 2014
Mar 17, 2014 09:48 |  #9
I am going to try switching to back button focus when I get my 6D tomorrow. How hard is it to focus recompose on fast primes without changing the focal plane?? Any tips? Also, do the outer points work fine for outdoor portrait photography with natural light?
And in studio, will I have to turn on a light to focus then turn it off if I am using off camera flash? I do nut run strobes so I don't have continuous model lights.
GoHokiesGo
Gallery: 6 photos
Mar 17, 2014 09:58 |  #10
Ugh - I've been contemplating upgrading from my 60D to a 6D and threads like these make me wonder if I need to bite the bullet on a 5D3 instead. I've never had issues with the autofocus on my 60D, which is the reason that I decided not to go with a 7D from the start. I figured the 6D would be about equal to the 60D autofocus, and that the 5D3 was closer to the 7D.
I usually shoot one of the off-center points as well, instead of dead center. Is the 6D autofocus worse than both the 7D and 60D? I had always assumed it was about equal to the 60D, which made me think that it'd be perfectly fine for me.
~Jason
Canon R6 -¤- Canon 6D -¤- Canon 60D
Canon RF50/1.2L -¤- Canon 135/2L
Canon16-35/4LIS -¤- Canon 24-105/4LIS -¤- Canon 70-200/4L
Canon 50/1.8 STM -¤- Samyang 14/2.8
Travel Website - Jason Peacott Photography (external link)
mclaren777
Joined May 2012
Mar 17, 2014 10:17 |  #11
giballi wrote in post #16764508 (external link)
I usually shoot at 2.0 instead of 1.4, but if you frequently shoot at really low aperture values, you could get an Eg-S focusing screen to help ensure accurate focus.
HazemG wrote in post #16764529 (external link)
No, the center point on the 6D might as well have night vision. I'm constantly amazed by its ability to focus in the dark.
apersson850
Gallery: 35 photos
Mar 17, 2014 10:18 as a reply to  @ GoHokiesGo's post |  #12
If a linear focus point can't find a contrast to measure, simply tilting the camera a bit can sometimes help, as it will rotate the AF sensor as well.
Anders
mclaren777
Joined May 2012
Mar 17, 2014 10:25 |  #13
GoHokiesGo wrote in post #16764551 (external link)
Is the 6D autofocus worse than the 60D? I had always assumed it was about equal to the 60D, which made me think that it'd be perfectly fine for me.
On paper, yes, the 60D locks focus better than the 6D (unless it's dark –– 0EV can't match -3EV). That being said, the 6D tracks and maintains focus really well once it acquires lock. I rarely feel limited by the center point, but I'm primarily a portrait/wedding photographer so take that for what you will.
HTTP response: NOT FOUND | MIME changed to 'image%2fjpeg'
IMAGE: http://i.minus.com/ibjd1XxkPfmfFo.jpg
SqueekyBoy
Joined Mar 2014
Mar 17, 2014 10:36 |  #14
mclaren777 wrote in post #16764633 (external link)
Not my experience. Though I admit my lack of experience with AI-Servo may be an issue, the 60D works better for me. I own both.
HazemG
Joined Jan 2014
Mar 17, 2014 10:37 |  #15
mclaren777 wrote in post #16764603 (external link)
Ok great. And you can focus/recompose in the dark and stay on the same focal plane? Thanks.
Also, how much is a eg-s focus screen?
11,886 views & 0 likes for this thread, 17 members have posted to it.
1106 guests, 164 members online
