Thread started 17 Mar 2014 (Monday) 18:48
EFS 18-200 lens
MJ ­ Cormier
1 post
Joined Mar 2014
Mar 17, 2014 18:48 |  #1
Why does my lens fall into total zoom, when the lens is pointed to the ground? Is this normal? I realize the weight of the lens makes the camera lean forward when it's on the strap, but should the lens open like that?
MakisM1
Gallery: 50 photos
Joined Dec 2011
Mar 17, 2014 18:58 |  #2
It's called lens creep and happens to a number of zoom lenses in varying degrees. The 18-200 has a lock you can use when it it at the 18 mm position, so that it will not creep while you are walking.
Some people put a rubber band at the edge of the zoom ring to increase the friction, so it doesn't creep. I didn't bother, the lock is adequate for me.
Gerry
Keyan
Joined Mar 2011
Mar 17, 2014 20:12 |  #3
Yep that is normal...and why they put the lock on it. Every time you take a step there is a significant momentum shift when your next foot catches you from essentially falling forward, and the front element, which is the heaviest element in the camera, is on extending part of the zoom and it pulls the zoom out. As long as it is not so loose that you can't use the lens on a tripod at an angle without the zoom shifting then it is pretty much within the normal tolerances.
Cameras: 7D2, S100
Lenses: 17-55 f/2.8 IS USM, 18-135 STM, 24-70 f/4L IS USM, 50 f/1.4 USM,70-300L IS USM
Other Stuff: 430 EX II, Luma Labs Loop 3, CamRanger
Abu ­ Mahendra
Joined Aug 2013
Mar 17, 2014 20:43 |  #4
I handled the 18-200 the other day. Before that I had only read about zoom creep until then. It is awful.
No, it is not normal for well-made, quality zoom lenses to zoom creep.
MakisM1
Gallery: 50 photos
Joined Dec 2011
Mar 17, 2014 20:49 |  #5
Abu Mahendra wrote in post #16766114 (external link)
Yeah, my EF 24-70 MkII is a cheap little piece of junk that shares the exact same design... :rolleyes:
Gerry
Abu ­ Mahendra
Joined Aug 2013
Mar 17, 2014 21:12 |  #6
No less awful. Perhaps even more awful and unpardonable given the price tag. After all, two wrongs still don't make a right.
MakisM1
Gallery: 50 photos
Joined Dec 2011
Mar 17, 2014 22:20 |  #7
It's part of the design which utilizes an extending front element. The only way to eliminate creep for such a design is more friction and I don't want more friction. All it will do is lead to wear and trouble.
I bought the lens(es) (I have both) for their optical characteristics, not using lens creep as a criterion. If you can find creepless lenses, buy them...
Gerry
SqueekyBoy
Joined Mar 2014
Mar 17, 2014 22:46 |  #8
Any lens with an external zoom/focus mechanism is going to develop zoom-creep at some point. It is not a design or materials flaw. It is physics. If two parts fit together so tightly that they cannot move, then by definition they cannot move, which would make zooming or focusing pretty difficult. The only zoom I own that does NOT do this is my 15-85. Eventually, it will.
PH68
Joined Jun 2013
Mar 18, 2014 11:59 |  #9
As above any external zooming will eventually produce lens creep.
And some lenses creep more than others.
Even expensive L lenses are prone to creep.
5Diii | 35/2 | 100/2.8L | 300/4L
jqworle
Joined Dec 2013
Mar 18, 2014 14:45 |  #10
Yes it can be a pain but if wandering around with the lens either lock it or keep a finger on the barrel to stop,it moving, I have had some great images with this lens as it is really handy as a walk around city lens.
Canon EOS650D,EFS17-55,EFS18-200,EF100-400,Mieke battery grip.
mwsilver
Gallery: 54 photos
Joined Oct 2011
Mar 18, 2014 16:35 |  #11
Actually it is normal. Every super zoom creeps to one degree or another and that includes Canon, Nikon, Sigma and Tamron! That's why all the latest versions include zoom locks. Even many standard zooms develop some creep including, as examples, the Canon 28-135, the Canon 15-85, the Canon 17-55, and occasionally even the Canon 24-105. They are all quality zooms. However, of all the lenses I'm familiar with, my copy of the Canon 18-200 has by far the worst creep. It collapses from around 150mm to around 20mm in a heart beat when pointed straight up or straight down, Luckily the closer to horizontal you get the less creep you get.
Mark
Nikon Z fc, Nikkor Z 16-50mm, Nikkor Z 40mm f/2, Nikkor Z 28mm f/2.8 (SE), Nikkor Z DX 18-140mm, Voigtlander 35mm f/1.2, Voigtlander 23mm f/1.2, DXO PhotoLab 5 Elite, DXO FilmPack 6 Elite, DXO ViewPoint 3
SqueekyBoy
Joined Mar 2014
Mar 18, 2014 16:48 |  #12
jqworle wrote in post #16768035 (external link)
Any office supply store will sell you a bag of rubber (elastic) bands for a few pennies. Put one over the lens where the zoom ring meets the barrel. No more zoom creep. But you will have a weird looking lens.
Lbsimon
...never exercised in my life
Gallery: 19 photos
Mar 18, 2014 17:36 |  #13
SqueekyBoy wrote in post #16768354 (external link)
No, just use a red band, and all of a sudden you have an L lens! :-)
jqworle
Joined Dec 2013
Mar 19, 2014 08:16 |  #14
Lbsimon wrote in post #16768472 (external link)
:D like it .a red band it shall be.
2,364 views & 0 likes for this thread, 9 members have posted to it.
EFS 18-200 lens
2269 guests, 138 members online
