Thread started 18 Mar 2014 (Tuesday) 23:11
ai servo, continuous shooting, 5d2
kenwood33
Mar 18, 2014 23:11 |  #1
I was shooting people running towards the camera with the following settings:
ai servo, continuous shooting, small jpeg
av mode, f4, shutter speed between 1/1000 to 1/2000
5d2, 70200 f4 (IS off) on a monopod
I track the runner using the center focusing point, hold the shutter button for 2 sec. 4 out of 5 shots are out of focus, sometimes all are oof. It seems that the ai servo is not focusing continuously - there maybe a 1 sec lag in between. Is that true? If so how to get perfectly focus shots? I used the same setting on the 40d before, and i can get at least 50% of the shots in focus.
Gearlist
MakisM1
Gallery: 50 photos
Joined Dec 2011
Mar 18, 2014 23:26 |  #2
Can you do any better with the other camera?
Gerry
rrblint
Gallery: 84 photos
Joined May 2012
Mar 18, 2014 23:51 |  #3
kenwood33 wrote in post #16769202 (external link)
...It seems that the ai servo is not focusing continuously - there maybe a 1 sec lag in between. Is that true?.
No, it should be focusing continuously in AI Servo. There is no 1-sec lag. There's got to be something else going on here.
Mark
Snowyman
Gallery: 682 photos
Joined Oct 2011
Mar 19, 2014 04:29 |  #4
Post the series of photos with EXIF so we can see what is going on.
Perhaps the area you are focusing on doesn't have enough texture or contrast.
Snowy's Gear
Deviant Art (external link)
500px (external link)
kenwood33
Mar 19, 2014 09:15 |  #5
i don't have the photos as i was shooting for someone else
most of the runners have their bibs in front and i put the middle focusing point to the bib
it happens for about 10 runners
i end up switching to single shot and no longer have out of focus issues
Gearlist
jmikolich
Joined Feb 2013
Mar 19, 2014 09:44 |  #6
Using back button focus?
-Jim
Canon 5D3,5D3,5D2,6D,24 f2.8 IS,35L,45 TS-E,50L,85 f1.8,70-200 f2.8L II,100L
Rokinon 14mm f2.8
apersson850
Obviously it's a good thing
Gallery: 35 photos
Mar 19, 2014 10:34 as a reply to  @ jmikolich's post |  #7
Do you literally mean single shot (as oppsoite to continuous drive mode) or do you mean one shot AF?
Anders
Lowner
"I'm the original idiot"
Mar 19, 2014 10:40 |  #8
Its not an issue I've ever had and that's shooting F1 and MotoGP bikes which are travelling a lot faster than humans running.
I've also never held the shutter button down. Maybe that's where the problem lies?
Richard
Nalauk
Joined Sep 2012
Mar 19, 2014 11:50 |  #9
Did you have the extra (invisible and non-selectable) focus assist points enabled within the custom functions?
There are a further 6 focus points available when using ai servo on the 5D MkII, 3 above and 3 below the centre point to help with tracking. They are disabled normally I believe.
cristphoto
Mar 19, 2014 11:55 |  #10
Look at the shots on the cameras screen or review them in DPP. That will show the image with the selected AF spot. You may have been missing the body of the runner on those shots. Switching to single shot AF mode for runners coming at you should lower your keeper rate even more. Stick with servo AF. You may have a custom function set wrong or there might be a defect in the body. Does it do this with other lenses too? Perhaps try cleaning the contacts on the lens and body.
1DX MK II, 5D MKIV x2, 24L II, 35L II, 50L, 85LIS, 100LIS Macro, 135L, 16-35LIS, 24-105LIS II, 70-200LIS, 100-400LIS II
lovemyram4x4
Gallery: 97 photos
Joined Mar 2013
Mar 19, 2014 13:30 |  #11
One thing I found during the short time I had my 5DII was it tracked much better in Ai Servo if you had the hidden expansion points mentioned above enabled.
Another thing is you might have had priority set to shutter instead of AF(I'm pretty the 5DII also has the setting) so if anything about the scene made tracking hard for the camera it wouldn't slow down to try and get AF.
1,893 views & 0 likes for this thread, 10 members have posted to it.
1680 guests, 138 members online
