FORUMS Photography Talk by Genre Critique Corner
Thread started 20 Mar 2014 (Thursday) 04:24
changed the dull sky
mmahmood
Joined Oct 2012
Mar 20, 2014 04:24 |  #1
Hi,
this is my first sky swap edit, i used CS5 for it, basically i selected the sky with magic wand tool and then inverted my selection and pasted the selection over the new sky, all went well i think, but when we take a look at the edges of the building that touches the sky it clearly have a distinct cut line and sky and buildings just dont blend in as they should, this phenomenon is more visible when seen full size image,
how to tackle this situation?
IMAGE: http://farm4.staticflickr.com/3731/13280190785_61c7f17991_b.jpg
IMAGE LINK: http://www.flickr.com …mmad-mahmood/13280190785/  (external link)
deevan-e-khass (external link) by muhammad mahmood (external link), on Flickr
PixelMagic
Mar 20, 2014 05:10 |  #2
You're using the wrong selection tool. Photoshop contains several selection tools ranging from the Magic Wand to Channels and Masks; the Magic Wand is the most basic of these tools. I'd suggest using the Quick Selection tool in conjunction with the Refine Edge command, or the Color Range command, or use a Channel to create a luminosity selection of the original sky.
Perhaps if you linked to the original unedited image someone will demonstrate how to make an accurate selection.
tmoore323
Mar 20, 2014 10:50 |  #3
Have a look at this:
http://www.photoshopes​sentials.com/photo-editing/replace-sky/ (external link)
mmahmood
Joined Oct 2012
Mar 21, 2014 03:53 |  #4
PixelMagic wrote in post #16772175 (external link)
thanks for reply, i will sure try more appropriate tools as you mentioned, will post back here in couple of days with both original and edit
mmahmood
Joined Oct 2012
Mar 21, 2014 03:59 |  #5
sure i will, thanks for replying
768 views & 0 likes for this thread
Latest registered member is radzinski
961 guests, 216 members online
