When testing, we have noticed that playing back footage, if there is any motion, like panning, the video seems a bit jumpy, rather than smooth.
Any recommendations for the ideal settings to achieve really smooth footage, even when doing a slow pan?
Mar 20, 2014 18:33 | #1 When testing, we have noticed that playing back footage, if there is any motion, like panning, the video seems a bit jumpy, rather than smooth. Sony A7r2|24-70 f/4 FE|85 1.8 FE|28 f/2 FE|Venus Laowa 15mm f/2|Habakkuk 2:2
artyman Sleepless in Hampshire More info | Mar 20, 2014 18:58 | #2 I shoot mostly at 1/50 and 24fps and haven't noticed any jumpiness on my 7D. You do have to be careful of the 'jello' effect if panning to fast. Are you using a tripod with a video head or hand held? Art that takes you there. http://www.artyman.co.uk
Mar 20, 2014 21:53 | #3 It'll probably be handheld using a rig... I'll give that a try, thank you! Sony A7r2|24-70 f/4 FE|85 1.8 FE|28 f/2 FE|Venus Laowa 15mm f/2|Habakkuk 2:2
sspellman Goldmember 1,731 posts Likes: 30 Joined Dec 2006 Location: Detroit, Michigan More info | Mar 21, 2014 14:47 | #4 It is a challenge for all DSLRs to deliver smooth motion due to the rolling shutter effect. You will see some improvement if you use 30 or 60FPS and increase your shutter speed to 1/60 or /120. ScottSpellmanMedia.com [photography]
Holliewood Mostly Lurking 13 posts Joined Mar 2014 More info | Mar 22, 2014 23:27 | #5 I agree with artyman, 24fps and a shutter speed of 1/50 is pretty much ideal here imo!
Mar 23, 2014 07:17 | #6 Holliewood wrote in post #16778679 I agree with artyman, 24fps and a shutter speed of 1/50 is pretty much ideal here imo! Although, at this setting, if you're shooting with a wide aperture, you might find it difficult to control the amount of light you're letting in. This is where a ND filter comes in handy! Also, are you using auto or manual focus? I suggest trying to make the switch to manual if possible. Definitely manual! Thanks Sony A7r2|24-70 f/4 FE|85 1.8 FE|28 f/2 FE|Venus Laowa 15mm f/2|Habakkuk 2:2
JonKline Member More info | Mar 23, 2014 20:41 | #7 If smoothness is your only goal, 60fps is the way to go. But to reduced the perceived stuttery motion, use longer shutter speeds, image stabilizing lenses, and stable camera support where possible. Cinematographer Chicago
Holliewood Mostly Lurking 13 posts Joined Mar 2014 More info | Mar 23, 2014 22:39 | #8 I should also add that the settings I recommended are for a more cinema look, which are smooth in it's own way. If you're looking to capture footage that looks more like real life, or what some might describe as a soap opera look, definitely go for a higher fps, like 60. Don't forget to adjust your shutter speed accordingly!
Mar 26, 2014 18:38 | #9 I agree with the settings everyone stated. 5DMKII | 50mm 1.4 | 24-105 f/4 | Speedlights - Strobes |
| Latest registered member is semonsters 1029 guests, 109 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
