Thread started 23 Mar 2014 (Sunday) 04:53
Recommendations needed for tripod and ballhead upgrade
the.forumer
Joined Oct 2011
Mar 23, 2014 04:53 |  #1
Hi guys,
I'm looking to upgrade my tripod+ballhead, with the following criteria:
Tripod
- Vibration dampening is most important factor
- Fast to deploy - 2nd most important factor! (makes me want to use the tripod more frequently)
- preferably under 2.5kg/travel friendly/compact when collapsed
- under $220
- 3 or 4 section
- no preference for twist/lever lock
- must have flexible centre column (reversible + 90 degree horizontal)
- hook on column is a huge plus
- sufficient to hold 6D + 70-200 f2.8L IS [But would be used with 17-40L or 100L IS most of the time]
Ballhead
- should not creep after locking into position ( my current one creeps slightly when using liveview 10x)
- lightweight a plus, without compromising too much on stability (so that it can be shared with my gorillapod)
- separate knob for locking vs panning
- big plus if the combo allows me to do single/multi-row panoramas easily
- under $100
I've been flipping through a lot of guides and reviews and have narrowed down to the Manfrotto 190XPRO3, or the Vanguard Alta series. Currently leaning towards the Vanguard as it is cheaper, has a more flexible centre column and features a spring loaded hook for extra stability. I understand Manfrotto is a trusted brand but just curious - how far away is the quality of alternative manufacturers compared to them?
Would be more than happy to accept alternative brands/models that meet the criteria too.
Thanks in advance for your help!
Boone13
Joined Dec 2013
Mar 23, 2014 05:06 |  #2
I have Benro A2970F legs with a Manfrotto 322RC2 head, ~$300 for both and I love the set up. Many folks recommended the Manfrotto comparable on the legs but I went with Benro due to the better versatility of the center column. Have had it for about 3 months now and it's been a rock solid setup. No hook on center column, but I'd recommend these legs.
Some moments are too amazing to be ruined with words.
Sirrith
Gallery: 50 photos
Joined Nov 2010
Mar 23, 2014 05:11 |  #3
Take a look at the Benro C2680TB1.
Stay away from Manfrotto heads, they sag/droop.
-Tom
Whortleberry
Joined Dec 2011
Mar 23, 2014 06:45 |  #4
Sirrith wrote in post #16779000 (external link)
Don't we all :lol:
Phil ǁ Kershaw Soho Reflex: 4¼" Ross Xpres, 6½" Aldis, Super XX/ABC Pyro in 24 DDS, HP3/Meritol Metol in RFH, Johnson 'Scales' brand flash powder. Kodak Duo Six-20/Verichrome Pan. Other odd bits over the decades, simply to get the job done - not merely to polish and brag about cos I'm too mean to buy the polish!
FlickR (external link) ◄► "The Other Yongnuo User Guide v4.12" by Clive Bolton (external link) ◄► UK Railway Photographs 1906-79 (external link)
Sirrith
Gallery: 50 photos
Joined Nov 2010
Mar 23, 2014 06:54 |  #5
Whortleberry wrote in post #16779098 (external link)
Don't we all :lol:
Some more than others ;)
-Tom
the.forumer
Joined Oct 2011
Mar 23, 2014 09:09 |  #6
Don't we all :lol:
always thought Manfrotto is trusted for both legs and head - for example the 498RC2.
what other solid contenders do we have currently? :cool:
the.forumer
Joined Oct 2011
Mar 23, 2014 09:11 |  #7
thanks for the advice. would likely head for alu options as I can't stomach the cost of CF :(
rick_reno
Mar 23, 2014 09:46 |  #8
The only ballhead I have found that doesn't creep is rrs bh-55, and I bought and sold a lot of them before trying it.
the.forumer
Joined Oct 2011
Mar 23, 2014 09:48 |  #9
rick_reno wrote in post #16779436 (external link)
that's almost 5x my budget for a ballhead - any alternative affordable option please? :D
jtmiv
Gallery: 17 photos
Joined Jan 2013
Mar 23, 2014 10:36 |  #10
Dear the.former,
Take a look at the Triopo RS3 ballhead. You can buy it along with a clamp that is compatible with both Arca-Swiss and Manfrotto quick release plates for under $ 100.00. I believe you will need a Desmond DBA01 clamp?
You'll need to convert the clamp yourself but there are videos out there that explain the process. Take a look at the review below and look at the other video on converting the top mount from a threaded connection to a QR compatible clamp.
http://www.scvphotoide​as.com …s-3-ball-head-review.html (external link)
Regards,
Tim Murphy :D
"Then the coal company came with the world's largest shovel
And they tortured the timber and stripped all the land
Well, they dug for their coal till the land was forsaken
Then they wrote it all down as the progress of man"
hawkan
Mar 23, 2014 11:58 |  #11
If you expand your budget just a little bit you can start looking at the Sunwayfoto brand of ball heads. I borrowed one (a *36 model) and I was quite impressed with it. An FB-36 with an Arca-swiss clamp is $146 at B&H, larger sizes (which you should consider) is a little more.
I suggest you try to go the "right" way from the start and don't make the same mistake I did - I got the Manfrotto quick release system some years ago and replacing it all with the more versatile (and in my opinion superior) Arca-Swiss style quick releases was an expensive affair.
jtmiv
Gallery: 17 photos
Joined Jan 2013
Mar 23, 2014 13:09 |  #12
Dear Hawkan,
That's the whole point of the Desmond clamp. You can get a dual purpose clamp and use both Arca-Swiss and Manfrotto plates until you settle on one style without having to go through the expense of switching everything over at one time.
http://www.amazon.com …A-01-Tripod/dp/B008G394U0 (external link)
Regards,
Tim Murphy :D
hawkan
Mar 23, 2014 14:21 |  #13
jtmiv wrote in post #16779881 (external link)
Dear Hawkan,
Thanks Tim, I'll check it out. I haven't been impressed with the one Desmond brand product I have ever handled, a nodal rail. It appeared to differ some in dimensions so it wouldn't fit without adjustment to my RRS clamps (Sunwayfoto and Hejnar appeared to work better). I wasn't too impressed with it but this at least looks inventive!
Sirrith
Gallery: 50 photos
Joined Nov 2010
Mar 23, 2014 18:50 |  #14
the.forumer wrote in post #16779376 (external link)
Your budget is $320, the C2680 is $350 ;)
http://www.holgacamera​.com …-carbon-fiber-tripod-kit/ (external link)
And Manfrotto heads aren't known for being rock solid. They're known for not being that great, actually.
-Tom
jbrackjr
Joined Dec 2011
Mar 23, 2014 19:16 |  #15
Another vote for the A2970F. It meets and exceeds (in some cases) your specs. I've had mine for more than 2 years and it can do the job required with ease. Because it is a 3 section pod, it is very sturdy but is about 26 inches in length (collapsed).
Did I mention it is only $154. Also comes in CF but is $200 more.
Check this out: https://www.youtube.co​m/watch?v=OiqD7v9mKPY (external link)
Jim
4,102 views & 0 likes for this thread, 9 members have posted to it.
1501 guests, 134 members online
