I have a couple of spots I have noticed on my 1D3, there are quite a few kits available, any pros/cons or recommendation?
Mar 23, 2014 13:54 | #1 I have a couple of spots I have noticed on my 1D3, there are quite a few kits available, any pros/cons or recommendation? Sony A7r2|24-70 f/4 FE|85 1.8 FE|28 f/2 FE|Venus Laowa 15mm f/2|Habakkuk 2:2
mesakid Senior Member 364 posts Likes: 17 Joined Dec 2010 More info | Mar 23, 2014 14:04 | #2 My brother cleaned my 1D Mark III with the Sensor Gel Stick. It's simple and easy to use. Look it up. Prior to that product, the thought of having to clean the sensor seemed rather scary, but with that product it makes it very easy and less stressful of damaging the sensor. https://www.youtube.com/that1cameraguy
numbersix fully entitled to be jealous 8,964 posts Likes: 109 Joined May 2007 Location: SF Bay Area More info | Mar 23, 2014 15:24 | #3 Here's a good introduction to sensor cleaning: "Be seeing you."
Mar 24, 2014 05:11 | #4 Not sure what you mean by (Type 2 camera). If you're referring to the belief that some sensors are damaged by Eclipse cleaning fluid then that was all a storm in a teacup. Eclipse is safe with all sensors. Frank Hollis - Retired mass spectroscopist
NicholasR. Senior Member 455 posts Joined Jan 2005 More info | Mar 24, 2014 10:22 | #5 javapop wrote in post #16780009 I have a couple of spots I have noticed on my 1D3, there are quite a few kits available, any pros/cons or recommendation? David,
Mar 24, 2014 22:17 | #6 @Nicholas: What's your company's website? I'm in the market for one (not urgently, since my 1Ds was just professionally cleaned), but certainly soon. Felipe G
watt100 Cream of the Crop 14,021 posts Likes: 34 Joined Jun 2008 More info | Mar 25, 2014 05:11 | #7 I use swabs and eclipse fluid from Amazon
NicholasR. Senior Member 455 posts Joined Jan 2005 More info | Mar 25, 2014 06:17 | #8 garciarf wrote in post #16784009 @Nicholas: What's your company's website? I'm in the market for one (not urgently, since my 1Ds was just professionally cleaned), but certainly soon. I do not recommend the Sensor Swabs, as they have a terrible resistance to bending, which in my experience has led to Eclipse fluid residue being left on the sensor. The CopperHill tool is much more rigid and in my opinion works significantly better than the Sensor Swabs, and it uses the same Eclipse fluid. Here you go:
Ontheloose Junior Member 21 posts Joined Jan 2014 More info | The key to using swabs is to dampen them, not wet them. The main cause of problems is fluid drying on the front filter that sits in front of the sensor, or worse seeping into the pack in front of the sensor.
Mar 25, 2014 19:46 | #10
Felipe G
NicholasR. Senior Member 455 posts Joined Jan 2005 More info | Mar 25, 2014 21:26 | #11 garciarf wrote in post #16786268 Didn't realize you were with Copperhill, as I had no recollection of them selling those gel sticks. Thanks for the heads up, I'll order one soon. Felipe,
BluePhoton Member 52 posts Joined Mar 2014 More info | Mar 25, 2014 21:30 | #12 Permanent banI honestly just use Qtips. Had no problems.
Mar 27, 2014 23:27 | #13 Nicholas R. wrote in post #16786495 A couple of things to be aware of - There is a gel with a white tip being sold for a few dollars, try to save a buck and you will probably get that aforementioned residue on your sensor. The Eyelead Gel Stick will work on almost every sensor except for the latest SONY models which are listed on our product page. People who shoot the original 5D can use it except for bodies with serial numbers starting with a 0 (zero). This is the batch that had defective coatings, not all units in that run were affected, but you don't want to risk it. Like I said above, this is a great adjunct to a wet-cleaning kit and it's very simple to use. The reaction from our customers has been outstanding and confirms our decision to carry it. The manufacturer states that the gel will last approximately 3 years making it a good bang-for-the-buck. Regards, Nicholas The white one... no thanks. I wouldn't want to go cheap on something that will touch the sensor. Considering that I just paid $25 for a professional sensor cleaning, the gel stick will pay itself off after cleaning 2 sensors. BluePhoton wrote in post #16786505 I honestly just use Qtips. Had no problems. Did that once, and I then had to fish all these cotton hairs out of my camera. Will never do that again. Felipe G
Mar 28, 2014 06:22 | #14 Nicholas R. wrote in post #16786495 Felipe, We've been in business for almost 12 years and people here who know of our company know that we rarely recommend sensor cleaning products other than our own. But the Gel Stick is the real deal for two reasons: 1) the adhesive is stronger than any previous product enabling it to pick up almost all dust and debris, and 2) when used according to the directions it will leave no residue. A couple of things to be aware of - There is a gel with a white tip being sold for a few dollars, try to save a buck and you will probably get that aforementioned residue on your sensor. The Eyelead Gel Stick will work on almost every sensor except for the latest SONY models which are listed on our product page. People who shoot the original 5D can use it except for bodies with serial numbers starting with a 0 (zero). This is the batch that had defective coatings, not all units in that run were affected, but you don't want to risk it. Like I said above, this is a great adjunct to a wet-cleaning kit and it's very simple to use. The reaction from our customers has been outstanding and confirms our decision to carry it. The manufacturer states that the gel will last approximately 3 years making it a good bang-for-the-buck. Regards, Nicholas Nicholas do they have kits for the 1/3rd crop cameras? Sony A7r2|24-70 f/4 FE|85 1.8 FE|28 f/2 FE|Venus Laowa 15mm f/2|Habakkuk 2:2
NicholasR. Senior Member 455 posts Joined Jan 2005 More info | Mar 28, 2014 06:42 | #15 javapop wrote in post #16792241 Nicholas do they have kits for the 1/3rd crop cameras? David,
| Latest registered member is semonsters 1029 guests, 109 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
