FORUMS Post Processing, Marketing & Presenting Photos The Business of Photography
Thread started 23 Mar 2014 (Sunday) 15:21
metadata help pls
abbypanda
Joined Nov 2011
Mar 23, 2014 15:21 |  #1
I have a job coming up and I have to include metadata in the photo.
I'll be honest I never messed with it before. I do have the copyright info set in my 5diii with my name. I thought that was enough. Today I used a metadata viewer and it did not show any data. So I went in lightroom and set the metadata in a picture, to try it out.
Then I went back online to try to "see". It did show me everything: everything but the copyright info I had set. For some reason it's only showing my name as owner. Also when I open the photo up in PS, and go to metadata info there is none.
Pls help, what do I need to do to set this right?
TIA
NCHANT
Joined Jul 2012
Mar 23, 2014 16:44 |  #2
I usually put these into my shots in LR:
Keywords
Title
Caption
Exposure metadate
Then just export with all metadata?
Or are they just after the exposure strings, copyright etc?
6D x 2 | TM SP 35mm ƒ1.4 | 50mm ƒ1.8 | 85mm ƒ1.8 | 24-105mm ƒ4L USM | 135mm ƒ2L | 200mm ƒ2.8L II | 17-40mm ƒ4L | Sy 24mm ƒ1.4 | Sy XP 14mm ƒ2.4 Flickr (external link) | Facebook (external link)
abbypanda
Joined Nov 2011
Mar 23, 2014 16:48 |  #3
I have to put my copyright info, name and job description
the problem is on the copyright line, that's whats not showing up on the metadata viewer. and when i hit export I hit export "all" metadata
PhotosGuy
Cream of the Crop, R.I.P.
Joined Feb 2004
Mar 26, 2014 22:33 |  #4
Could you be using "Save for web"? That will strip the exif info out.
D ­ Thompson
Mar 27, 2014 00:15 |  #5
PhotosGuy wrote in post #16789377 (external link)
Not necessarily, depends on your version of PS. Starting with at least CS5 there are several options of saving metadata or not using "Save for Web".
Dennis
Canon 5D Mk III 5D 20D
I have not yet begun to procrastinate!
drvnbysound
Mar 27, 2014 07:28 |  #6
Have you tried to export via Lr?
BTW: You don't have to upload to the web to see if the metadata is there. If you are on a PC, you can simply view the properties of the file; right-click the image, go to Properties, then view the Details tab. If the metadata is listed there, but isn't after you upload... then whoever you are using for image hosting is likely stripping the metadata.
I use manual exposure settings on the copy machine
..::Gear Listing::.. --==Feedback==--
...A few umbrella brackets I own...
Tom ­ Reichner
"That's what I do."
Gallery: 213 photos
Location: from Pennsylvania, USA, now in Washington state, USA, road trip back and forth a lot
Mar 27, 2014 11:29 |  #7
abbypanda wrote in post #16780407 (external link)
There's an easy way to work around this. For example, under "NAME", instead of writing:
Abby Panda
write:
copyright Abby Panda
Thus, you can "claim" copyright, or show it in your metadata, even if you can't get it to show up in the space specifically designated for the copyright info.
abbypanda
Joined Nov 2011
Mar 27, 2014 17:57 |  #8
Thanks so much everyone. I ended up figuring it out but now it's been a day and I don't remember what I did to fix it. It was something off: wasn't the save for web but something with the way I was exporting it I think from lr. I do remember that in the process of getting the fix I went to LR under "library" and set it there. Before I had been setting it under "develop" using the menu tabs at the very top. Maybe that wasn't working. but the last batch it was all there when I viewed it in photoshop. Thanks all
CAPhotog
Joined May 2012
Mar 28, 2014 09:42 |  #9
When you export from LR there is a checkbox setting for the metadata. However, it is at the bottom and you may need to scroll the window down in order to see it.
1,737 views & 0 likes for this thread, 7 members have posted to it.
metadata help pls
884 guests, 129 members online
