Thread started 23 Mar 2014 (Sunday) 16:52
Quick guide to shooting on location
king.
Joined Oct 2013
Mar 23, 2014 16:52 |  #1
Shooting on location with strobes is probably one of the most challenging, yet rewarding aspects about photography. Every so often I receive a handful of messages regarding how I shot a certain shot on location and what my setup was. I figured that I could make a run and gun type guide to how I shoot on location.
One of the most important aspects about strobing on location is to mix the flash with the ambient so that there is no evidence a flash was used. A handful of things has to come together in order to achieve this. Camera settings, time of day, light output, modifiers, and the overall look you want to achieve. When I first started, I really sought after the lit subject and dark background look. This can be nice in some situations, but I find that balancing the strobe and ambient can lead to a far stronger image.
The absolute basics of shooting on location is: shutter speed controls ambient and aperture controls the flash. ISO acts as a global adjustment. The higher you bump up your iso, the greater the ambient AND flash output. Then there is also the giant profoto D1 sitting in the sky that you can't forget about either. A tool that I use to help control all of these aspects is my variable ND filter (external link). I use this on 90% of my shoots. It allows me to control the sun and also shoot at a shallow DOF. To anyone just starting strobing outdoors, I would recommend shooting without an ND as it is another variable that can be somewhat tricky to master.
Step 1: Know your equipment!
I think this is one of the most valuable skills to any photographer. Knowing how much light your lights produce and the light output of your modifiers helps immensely in the field. It'll save you from being "that guy" with fumbling around with your lights and leaving your model feel like you have no idea what you're doing.
This was from a shoot with a Fortune 500 company's CEO. The holy grail of every second counts. Although it's somewhat evident I used a flash, I'm using this as an example of knowing your gear. I had a 47" octabox cam right at 1/2 power (AB800). I knew that shooting at 1/100 @ 2.8 ISO (400-640) would yield me with a ballpark exposure. I had to make a small adjustment to my light output, and I was ready to shoot away.
1/100 ƒ/2.8 ISO 500 90 mm cut 2 stops of light with ND filter
IMAGE: https://farm3.staticflickr.com/2851/13362017433_a950447830_z.jpg
IMAGE LINK: https://www.flickr.com …ahaohmichael/13​362017433/  (external link)
CEO 2 (external link) by Michael Fornataro (external link), on Flickr
Step 2: Mimic the sun
Your light placement is a huge factor in the overall image. I try to mimic the light the sun would produce in the real world.
In this image, I had my light placed too high and downward. It's immediately evident that I used a flash here. The background rock wall is too dark compared to the rest of the scene as with the shadow of the model. My shutter speed was also too fast for the ambient and amount of light I was cutting from the ND filter.
1/160 ƒ/2 ISO 100 50 mm cut roughly 5 stops of light with ND filter
IMAGE: https://farm8.staticflickr.com/7325/10128327286_ed9376217d_z.jpg
IMAGE LINK: https://www.flickr.com …ahaohmichael/10​128327286/  (external link)
Andrea 6 (external link) by Michael Fornataro (external link), on Flickr
To correct for the shadow and light falloff, I brought my light closer to the front of the model and shot up at her. I also had her look in the direction of the light. This allowed for no hard shadows and a more believable shot.
1/60 ƒ/2 ISO 100 50 mm cut roughly 4 stops of light with ND
IMAGE: https://farm6.staticflickr.com/5513/10128387043_a8a2289fb9_z.jpg
IMAGE LINK: https://www.flickr.com …ahaohmichael/10​128387043/  (external link)
Andrea 10 (external link) by Michael Fornataro (external link), on Flickr
When shooting indoors, I try to motivate the light. By this I mean have a reason for there being light in the first place. Don't just aim a light at your subject and ignore the surroundings or let the scene go completely black.
For this I imagined a light that could be seen in a sound booth. Illuminating the mic and stand in front of him to see his music/lyrics.
1/60 ƒ/2.5 ISO 200 50 mm
IMAGE: http://farm6.staticflickr.com/5502/11635213715_9b5c48d989_z.jpg
IMAGE LINK: http://www.flickr.com …ahaohmichael/11​635213715/  (external link)
Nick 3 (external link) by Michael Fornataro (external link), on Flickr
Here I had to create a "false ambient." The bar wasn't terribly dark inside. It was well lit, except I would have had to shoot at a very slow shutter speed/high iso to soak up all the ambient I could get. Instead of trying to handhold a gripped 5dmk3 with a 70-200 2.8 at 1/15th, I created a false ambient. Basically filling the room with light as if the bar lights were creating the light. It also allowed me to shoot at a low iso as well.
1/50 ƒ/2.8 ISO 50 70 mm cutting 2 stops of light with ND
IMAGE: http://farm8.staticflickr.com/7307/11847139626_4aa0417e85_z.jpg
IMAGE LINK: http://www.flickr.com …ahaohmichael/11​847139626/  (external link)
Perle 1 (external link) by Michael Fornataro (external link), on Flickr
IMAGE: http://i58.tinypic.com/24q3hom.jpg
Although I'm a sucker for big, soft light, shooting through a standard bowl reflector can also be beneficial. In this image, I wanted something hard and dramatic. This was shooting at a little past noon on a cloudless sunny day. A subject with two shadows is a dead give away that a flash was used, and used incorrectly. Since I wanted to make this shot still believable, I used my light as basically a fill light. I allowed the sun to create the shadows and rim light, and simply filled in the shadows with my flash. Overpowering the sun here was tricky, and I knew that shooting with the standard 7" bowl was going to the the only way to overpower the sun.
1/100 ƒ/13 ISO 100 16 mm
IMAGE: https://farm6.staticflickr.com/5449/9346517055_1f300a8090_z.jpg
IMAGE LINK: https://www.flickr.com …hahaohmichael/9​346517055/  (external link)
Nick (external link) by Michael Fornataro (external link), on Flickr
Shooting food is a different story, and can be a whole guide in itself. When I shoot food, I always have my light (octabox) at the rear 3/4 of the frame and fill in my shadows from the front/sides. I've found that having your light placed behind the food is the most important technical part of the shot. it creates a beautiful rim, and gives that feeling of it being shot in natural light.
1/30 ƒ/2.5 ISO 50 cutting 3 stops of light with my ND filter.
IMAGE: http://farm3.staticflickr.com/2815/13360091364_8ffac2e7a4_z.jpg
IMAGE LINK: http://www.flickr.com …ahaohmichael/13​360091364/  (external link)
Sorbet (external link) by Michael Fornataro (external link), on Flickr
Step 3: Get Frustrated
A lot of people will say "don't get frustrated, stay calm, breathe, yadayadayada" I disagree. Get mad at yourself. Hate your pictures. Cuss yourself out (just not in front of your models) It's only going to make you want to get better. Once you've got the trick down to balancing strobes with ambient, introduce an ND filter. This will allow you to shoot at whatever aperture your heart desires, and create some stunning images. You may be wondering from the exif why I cut so much light with my ND. Simply put, it's the easiest way (for me) to balance everything. Instead of constantly getting out of position to change the power of the lights, I can just turn the filter and compensate with my camera settings.
I know this isn't the most in-depth or technical guide out there. This is just an insight on how I shoot on location, and hopefully it can help some people who are put in similar situations. Feel free to share your images or any other information I may have left out!
5Dmk3 with a couple red rings
Website (external link)
Instagram (external link)
tonebag
Mar 23, 2014 18:54 |  #2
Hey Mike,
Thanks for taking the time to share your lighting tips. Much appreciated. Just waiting for the weather to warm up so I can try them out.
sancho1983
Mar 24, 2014 16:50 |  #3
That's some great information. Thanks for that.
I tried to do this the other weekend with mixed results.
Here the subject was completely in shadow. I used one speedlite to illuminate her and one for the background.
IMAGE: http://farm8.staticflickr.com/7360/13013056093_6a785385f6.jpg
IMAGE LINK: http://www.flickr.com/​photos/thesancho/13013​056093/  (external link)
PrioryLib-46 (external link) by the sancho (external link), on Flickr
I was reasonably pleased with the light - what would you have done differently?
This shot I wanted it to look like the sun, but failed
IMAGE: http://farm8.staticflickr.com/7303/13013038924_82b9fd7113.jpg
IMAGE LINK: http://www.flickr.com/​photos/thesancho/13013​038924/  (external link)
Priory Portrait (external link) by the sancho (external link), on Flickr
I'm still pleased with the image but I wanted more ambient and a shallower depth of field - I'm guessing that's where the ND filter would come in?
Any comments you have would be great, your pictures are awesome!
Https://bgsweddings.co​.uk (external link)
EveryMilesAMemory
Gallery: 17 photos
Mar 25, 2014 12:30 |  #4
Great tutorial! Thanks for taking the time to post this
Pat Bonish
www.everymilesamemory.​com (external link)
www.patbonishphotograp​hy.com (external link)
http://www.instagram.c​om/bonish_photo/[/URL (external link)
MDJAK
Mar 25, 2014 14:15 |  #5
EveryMilesAMemory wrote in post #16785211 (external link)
Absolutely agree. Excellent post.
One question: When you say ISO is a global adjustment, I understand that. But you said the higher the ISO, the greater the ambient, which I agree with, but it doesn't affect the power of the strobe, or does it? Or does it amplify what's coming out of the strobe? That part I am not understanding.
Mark
enuff4life
Mar 25, 2014 18:49 |  #6
subscribing
king.
Joined Oct 2013
Mar 25, 2014 18:54 |  #7
Thanks everyone! Glad some found this useful.
sancho1983 wrote in post #16783265 (external link)
You did a great job with the first image. The only give away is the flash on the background. The circled area is a hot spot compared to the rest of the background. I'm not sure what the the rest of the scene looked like. But diffusing the background light or bouncing it would eliminate that direct spot on the door/wall.
IMAGE: http://i60.tinypic.com/ei5cgo.jpg
The second image would also benefit from diffused light. You've blended the ambient nicely, the flash just looks somewhat harsh and direct. Also, yes the ND filter would help with achieving a shallower DOF, the only problem would be your light output. I see you have a 430exII, I'm not sure how much light you'll be able to produce on full power shooting through a ND.
MDJAK wrote in post #16785471 (external link)
Mark
ISO increases the ENTIRE exposure, both flash and ambient.
I just shot this for the sake of demonstration.
1/10 f/8 ISO 100
IMAGE: http://i61.tinypic.com/33mooz4.jpg
1/10 f/8 ISO 400
IMAGE: http://i58.tinypic.com/28mhjp.jpg
1/10 f/8 ISO 800
IMAGE: http://i61.tinypic.com/16k5kbt.jpg
jmikolich
Joined Feb 2013
Mar 26, 2014 11:41 |  #8
Mark
ISO = sensitivity to light, doesnt matter where the light comes from, whether its the ambient light or light from a strobe the sensor is "acting" more sensitive to the light that exists thus shifting the whole histogram to the right.
Great post OP.
-Jim
Canon 5D3,5D3,5D2,6D,24 f2.8 IS,35L,45 TS-E,50L,85 f1.8,70-200 f2.8L II,100L
Rokinon 14mm f2.8
sancho1983
Mar 26, 2014 13:43 |  #9
king. wrote in post #16786158 (external link)
Thanks. In the first shot it was quite dark, but 'covered', I think I could have probably upped the power and bounced it off the ceiling.
I see what you mean about the second one. The ambient probably is right, but the flash is harsh, I shot through an umbrella and it was literally just off camera.
king.
Joined Oct 2013
Mar 26, 2014 16:50 |  #10
sancho1983 wrote in post #16788189 (external link)
How close was the flash to the subject? A shoot through should produce a nice soft, wrapping light.
sancho1983
Mar 26, 2014 17:08 |  #11
king. wrote in post #16788653 (external link)
Maybe 4-5 feet.
king.
Joined Oct 2013
Mar 26, 2014 17:29 |  #12
sancho1983 wrote in post #16788688 (external link)
Maybe 4-5 feet.
I try to bring my lights as close to the subject as possible. The farther away the harsher the light.
sancho1983
Mar 26, 2014 17:38 |  #13
Is there an easy way to get them out of the shot? Or do you just go as close as you can without being in the shot?
Sorry if it's a stupid question.
koolcreation
Gallery: 20 photos
Mar 26, 2014 17:56 |  #14
Good tutorial! I recently purchased some ND filters, will give this a try soon.
5DMKII | 50mm 1.4 | 24-105 f/4 | Speedlights - Strobes |
Instagram @KoolCreationPhoto (external link)
king.
Joined Oct 2013
Mar 26, 2014 19:39 |  #15
sancho1983 wrote in post #16788774 (external link)
I usually have my lights placed just barely out of the frame. Or you can use a boom arm to have your light extend close to the subject without have the lightstand in the frame.
koolcreation wrote in post #16788811 (external link)
Thanks! Be sure to post the finished results!
3,925 views & 0 likes for this thread, 10 members have posted to it.
852 guests, 162 members online
