Thread started 25 Mar 2014 (Tuesday) 09:33
So i can? use Cokin filter adaptor on my 77mm 70-200?
digitalduck
Joined Aug 2013
Mar 25, 2014 09:33 |  #1
Basic question.. I have seen people, especially Karl Taylor using what looks like Cokin square filters, but wanted to confirm that the adaptor system can be used wiht my 70-200 77mm lens?
I could get round filters, but i like the apparent versatility of a square set.. thoughts?
Thank you!
gonzogolf
dumb remark memorialized
Gallery: 40 photos
Mar 25, 2014 09:43 |  #2
There are two types of the cokin filters, one is too small for a 77mm lens. I cant remember the letter designations. What filters are you thinking of getting? Square is good for graduated ND filters, fine for landscape work. Perhaps a bit awkward for some other purposes.
digitalduck
Joined Aug 2013
Mar 25, 2014 09:49 |  #3
Morniong Gonzo.. lol I was thinking about a CPL and split ND or graduated.. unsure of strenght or amount but will have to experiment..
gonzogolf
Gallery: 40 photos
Mar 25, 2014 10:10 |  #4
digitalduck wrote in post #16784816 (external link)
I'd stick with round for the CPL personally.
sawsedge
Joined Dec 2011
Mar 25, 2014 10:55 |  #5
I think the Cokin P-series adapter will fit a 77mm filter. Cokin has a round CPL that fits in the first slot of the holder.
- John
Jon
Joined Jun 2004
Mar 25, 2014 17:52 |  #6
The Cokin P will just fit a 77 mm threaded lens, but you may experience vignetting with wide angle lenses that are at that 77 mm limit. The filters are 84-85 mm. Better, if you have or expect to have a lens that takes 77 mm filters to get the 4"/100 mm holders from Lee (or Cokin's Z-Pro) and use the larger filters.
Jon
Cocker Spaniels
Maxdave
Gallery: 49 photos
Mar 26, 2014 07:14 |  #7
sawsedge wrote in post #16784942 (external link)
I use the P series with my 77mm lenses ... but if the focal length is less than 25mm or so, you have vignetting (or at least the possibility).
Maxdave
5D3,1D4,S90,6S&Moment Lenses,Hero4Silver,GPS​-E2,2x580EX,430EX,90EX,​EF16-35L f/4 IS,Samy SYTS24-C 24TS,EF24-105L IS,EF50 f/1.4,EF70-200 f/4L IS,EF300 f/4L IS,EF100-400L I IS,Kenko DGX 1.4X,Canon 2X TC Mk II, RRS&Pro-Media L-Brackets,Manfrotto MHXPRO-3WG & Roller 50,Sirui 306&K-20,Giottos MT-7371&MH-3300,Velbon ElCarmagne 530,CamRanger,Phottix&​Canon Remotes,Lowepro Backpack,ThinkTank Retro 20&Modular System,OpTech straps,Lexar/San Disk Cards
digitalduck
Joined Aug 2013
Mar 26, 2014 08:50 |  #8
After reading more and questioning which filter I see that, for example, Karl Taylor uses lee filters and I've read mixed reviews of Cokins. However, would they be good filters to start with and if I happen to get that Great Wall worthy shot will it still produce good enough results and can't the vignetting be removed in LR?
Also I'd be using my 17-50 2.8
gonzogolf
Gallery: 40 photos
Mar 26, 2014 09:41 |  #9
digitalduck wrote in post #16787440 (external link)
Vignetting will be less of an issue with a crop body, but if you go full frame it becomes huge on the ultrawide lenses.
digitalduck
Joined Aug 2013
Mar 26, 2014 09:48 |  #10
Thanks Gonzo, so, would the Cokin be good filters to start with and if I happen to get that Great Wall worthy shot will it still produce good enough results. I mean ebay has a set, with filter adaptor and one Split ND filter for 8.99... seems worth a shot.
gonzogolf
Gallery: 40 photos
Mar 26, 2014 09:51 |  #11
digitalduck wrote in post #16787568 (external link)
For $9 bucks it might be worth a shot. I just reread one post and I think we should make something clear. When you talk about filters vignetting its not just darker to the edge like you get with a zoom. Its the mount of the filter system sticking into the camera's view. The only fix for that is a crop.
digitalduck
Joined Aug 2013
Mar 26, 2014 09:56 |  #12
LOL..aww yeah, that is very different thanks for cleaning that up Gonzo, ive never had to deal wiht that before..ok, crop (sensor) it is then :)
digitalduck
Joined Aug 2013
Mar 26, 2014 13:49 |  #13
So im seeing a lot of different circular CPL filters from Cokin. Do I need to be looking for a certain one that it will fit into the holder?
gonzogolf
Gallery: 40 photos
Mar 26, 2014 14:03 |  #14
They should be listed as fitting a particular series, identified by letter.
2,152 views & 0 likes for this thread
Latest registered member is Ezra Praveen
965 guests, 239 members online
