Still pretty clueless as to what constitutes a good black and white conversion, anyways, here's one:
edit: having posted it, looks a bit too sharp, thoughts?
Mar 25, 2014 14:37 | #1 Still pretty clueless as to what constitutes a good black and white conversion, anyways, here's one: edit: having posted it, looks a bit too sharp, thoughts? 6D | EF 35 f2 IS | EF 50 f1.4 | EF 85 f1.8 | EF 135 f2.0
GlynT Member 71 posts Joined Nov 2012 More info | Mar 25, 2014 16:18 | #2 Looks pretty good to me and not too sharp. I think your B&W works well - generally I think that you need an image where the different elements can be separated by their tone rather than their colour to make B&W work.... GT-Images.net
Woodworker Goldmember 2,176 posts Joined Aug 2009 Location: East Midlands, England More info | Mar 25, 2014 16:34 | #3 Maybe you're right - It might be just a little too sharp but I love the way you've captured the bond between granddad (?) and child. The expression on her face is priceless David
MartinDixon Slit-scan project master More info | Mar 25, 2014 16:44 | #4 Nicely done. I like the composition, tones and textures. flickr
Mar 25, 2014 19:26 | #5 GlynT wrote in post #16785786 Looks pretty good to me and not too sharp. I think your B&W works well - generally I think that you need an image where the different elements can be separated by their tone rather than their colour to make B&W work.... Thanks! Woodworker wrote in post #16785832 Maybe you're right - It might be just a little too sharp but I love the way you've captured the bond between granddad (?) and child. The expression on her face is priceless ![]() Yep, GREAT Granddad. Thank you! Martin Dixon wrote in post #16785854 Nicely done. I like the composition, tones and textures. It looks as if you shot looking downwards, which often does not work, but here it seems just fine. The over-sharpening seems bad on the edges of the elder nose - I assume this was just sharpening for posting on reduced size for this forum. Thanks! Yes it was a sharpen for export default setting, I don't usually use it but figured I'd try it. I was shooting down your right, I just was snapping away as they interacted, which didn't yield too many keepers, but I did like this one a bit. 6D | EF 35 f2 IS | EF 50 f1.4 | EF 85 f1.8 | EF 135 f2.0
| Latest registered member is semonsters 1093 guests, 117 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
