Haha, this is bound to start arguements, with people saying XYZ lens had bad bokeh and then offended owners defending their lenses.
Anyways....
Nathan wrote in post #16787863
What constitutes bad or distracting bokeh?
Bad / Dristracting bokeh to me has repeating paterns, hard lines, a seenig double effect, hard edges to blurs, weird artifacts like onion bokeh in light sources, etc etc etc. There's lots of ways bokeh can be bad.
What lenses render less than pleasing bokeh?
The sigma 35 Art produces less than ideal bokeh in the right (or wrong!) circumstances very easily. And yes, I own this lens.
The sigma 85 in generally looks very good from the samples I've seen, but every now and then produces some very strongly textured bokeh that I really don't like. I bought he 85L instead. Lot and lots of lenses have onion bokeh and other odd effects - even some of the best like the 24-70 f2.8 II and the 35L (both have onions). nice bokeh overal on both though.
What factors in the foreground or background should we aware of that might create busy bokeh?
Busy bokeh tends to be worse with lots of small sharp lines or egdes -- things like tree branches, leaves, bark chippings, etc tend to give harsh bokeh on a lens that's prone to it.
Quick example from the Siggy 35 Art @f1.4. It makes makes my eyes hurt to look at this:
What are composition considerations when it comes to bokeh?
I try to look for backgrounds that will make good bokeh. That depends on what lens you're using;
With the Siggy 35 i try to get the background far away / subject near enough to me to blur strongly enough to take the harshness out of it if I'm outdoors, but I hardly ever use it outside anyway, so it's not so much of an issue.
The 85L will soften most things, and I like to try to get some bright points in there for it to play with, so I'm normally looking for a high contrast background with small(ish) hard bright points, eg a side lit bush with some leaves catching the light strongly (see below). I considder the 85L to have basically perfect bokeh... however you can over do it and have 'boring bokeh'; it can destroy a background to such an extent it's just a coloured smear and this can look quite boring and bland, esp if it's nutural colours like concrete etc.
85L @ f2.5 :
when it actually makes your eyes hurt to look at it
