Thread started 26 Mar 2014 (Wednesday) 14:50
Impending shutter failure?
raptor3x
Joined Aug 2011
Mar 26, 2014 14:50 |  #1
Just noticed my 1ds3 start to do this at high shutter speeds. There's a bright region near the top of the frame. I'm guessing this means an impending shutter failure but wanted to check and see if anyone else had seen this before.
IMAGE: http://i.imgur.com/bfoC3Vm.jpg
Bodies: X-T1, E-M1ii, G9 Lenses: µ.Z 7-14 2.8, µ.Z 12-40 2.8, µ.Z 25 1.2, X 18-55 2.8-4, µ.Z 40-150 2.8, µ.Z 45 1.2, µ.Z 60 2.8, µ.Z 75 1.8, PL 200 2.8
Virto
Joined Nov 2010
Mar 26, 2014 15:26 |  #2
Does look like a blade isn't making it out of the way, entirely. Same result at all high speeds?
Kelly - EOS 5D - EOS 40D - Rebel XS - EOS 10D - EOS 1D - SX230 - AE-1 - OM-1n - Minolta Himatic7 - EOS-1N
ABR800 - Several flashes, remote triggers, stands, too many and yet not enough lenses
raptor3x
Joined Aug 2011
Mar 26, 2014 15:59 |  #3
Virto wrote in post #16788479 (external link)
The width of the affected band gets smaller until ~ 1/1600th of a second where it's no longer visible.
Virto
Joined Nov 2010
Mar 26, 2014 16:18 |  #4
At what point is it largest? Higher speeds or slower speeds? Every pre-failing shutter I've seen is worst at higher speeds.
It's not black across the image, just dark, which tells me it's still traveling, just not as quickly as it should. Typically there will be a dramatically dark or even black bar across an image, depending on shot settings.
I'd still assume it's about ready for a trip to the service center.
raptor3x
Joined Aug 2011
Mar 26, 2014 18:47 |  #5
Yeah, it gets worse with higher shutter speed. Not really noticeable below 1/1600th, but very obvious at 1/8000th as seen above.
1,886 views & 0 likes for this thread, 2 members have posted to it.
910 guests, 119 members online
