In a nutshell? Its for assigning the AE lock button to BBF button. Im beginning to learn how to use BBF, to focus first then recompose. I dont get function 2 and 3. AF/AF lock, No AE Lock and AE/AF, No AE lock.
Ev0d3vil Member 87 posts Joined Dec 2013 Location: Singapore More info | Mar 28, 2014 10:39 | #1 In a nutshell? Its for assigning the AE lock button to BBF button. Im beginning to learn how to use BBF, to focus first then recompose. I dont get function 2 and 3. AF/AF lock, No AE Lock and AE/AF, No AE lock.
gonzogolf dumb remark memorialized More info | Mar 28, 2014 10:47 | #2 I dont have a t21, but the slash indicates which function is as assigned to which button. Anything before the slash is assigned to the shutter button, and anything after the slash is assigned to the back button.
apersson850 Cream of the Crop More info | Before the slash is half-press of the shutter button, just in case it's not obvious. Anders
Mar 28, 2014 11:04 | #4 For the full explanation, check out the manual, page 195. http://www.erc.ndhu.edu.tw …eosrt2i-eos550d-im-en.pdf 1D MkIV | 1D MkIII | 550D w/grip & ML| EF 70-200mm f2.8L| EF 24-105mm f4L IS | Canon EF 100-400mm f/4.5-5.6L IS | Samyang 14mm f/2.8 IF ED UMC | 430EXii | EF 50mm f1.8
| Latest registered member is MWCarlsson 1006 guests, 186 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
