Thread started 03 Apr 2014 (Thursday) 16:50
DotTune on my 100-400
Nascar ­ Nut
Joined Feb 2004
Apr 03, 2014 16:50 |  #1
I have my camera (7d) on a tripod at about 30 feet from this focus chart (external link) . I have a 500 watt halogen light pointed at it to try and get enough light on it. My iso is set to 200 and my shutter speed is only 100. I set my micro adjustment to 0 and then use live view to focus on the target using my remote shutter release. I then turn off AF on my lens and start making micro adjustments. First negative and then back to the positive till I find the two furthest points each way and then set it in the middle. I did it 4 different times and got a different result each time. Do I need more light on the focus chart? Also I noticed that the area on the chart that my camera was focusing on in live view was a little bit lower then when I look through the camera. Thanks for any help you can give me.
Adharr
Joined Mar 2014
Apr 03, 2014 16:55 |  #2
Yes, try increasing the light you're throwing in your chart. I would increase the shutter speed up from 1/100 a bit too.
My Homepage (external link)
hollis_f
Apr 04, 2014 05:31 |  #3
Nascar Nut wrote in post #16807712 (external link)
One of us is confused. Are you saying that you test the results of changing MFA values with AF switched off?
Frank Hollis - Retired mass spectroscopist
Give a man a fish and he'll eat for a day. Teach a man to fish and he'll complain about the withdrawal of his free fish entitlement.
Gear Website (external link)
pulsar123
Gallery: 82 photos
Apr 04, 2014 08:29 |  #4
^ I think that's what you have to do when doing dot-tune. You turn AF off, then keep changing MFA and half-pressing the shutter looking for the focus confirmation light.
OP: it does look your light is not sufficient for reliable AF tuning. I believe I had to get to 1/100s or less at 100 ISO to start seeing convergence of my MFA numbers.
A question: you mentioned that you do remote live view AF - right? I don't think my 50D can do that - perhaps this is something 7D specific? In 50D, live view AF is hard-wired to the back AF button (you cannot use the shutter for that). Perhaps 7D has an option to re-assign it to the shutter button?
6D (normal), 6D (full spectrum), Tamron 24-70 f2.8 VC, 135L, 70-200 f4L, 50mm f1.8 STM, Samyang 8mm fisheye, home studio, Fast Stacker
Lbsimon
...never exercised in my life
Gallery: 19 photos
Apr 04, 2014 08:40 |  #5
Do you mean to say that you cannot use the remote shutter release for focusing in LV? When I do the LV AF on the 70D, I use the remote shutter release button. Perhaps this is what the OP is talking about.
Nascar ­ Nut
Joined Feb 2004
Apr 04, 2014 12:42 |  #6
I turned up the iso to 400 and got my shutter speed up to 1/250 and the results were much better. I almost run out of range as I got to +19 on the plus side. As for the remote, I can either use the AF button on the back or the remote shutter release. I think I will wait for a sunny day and do it again at iso 100 if I have enough light to see if it makes any difference.
Nascar ­ Nut
Joined Feb 2004
Apr 04, 2014 12:57 |  #7
hollis_f wrote in post #16808895 (external link)
Yes, that is what you do.
Lbsimon
Gallery: 19 photos
Apr 04, 2014 12:58 |  #8
How much a spread do you get from a test to a test? Just a couple of notches? Or is something in the 5-10 step range?
Nascar ­ Nut
Joined Feb 2004
Apr 04, 2014 13:02 |  #9
Lbsimon wrote in post #16809761 (external link)
I did it 4 times with the higher shutter speed and I was either +4 or +5 on the low end and +19 or +20 on the high end.
TeamSpeed
01010100 01010011
Gallery: 116 photos
Joined May 2002
Apr 04, 2014 13:02 |  #10
I still think the ol' carpet trick is the best. Throw a quarter out in front of you some distance, enough that the center AF is a bit smaller than the quarter, then take a One Shot focused image, look at the carpet fiber, if the carpet around the quarter isn't in focus adjust, and try again. It takes a few tries, but at some point the carpet will be completely clear around the quarter.
hollis_f
Apr 04, 2014 13:24 |  #11
Nascar Nut wrote in post #16809760 (external link)
Yes, so it was me that was confused. My excuse is I've never tried DotTune
Lbsimon
Gallery: 19 photos
Apr 04, 2014 14:24 |  #12
Nascar Nut wrote in post #16809771 (external link)
Please be more specific. Do you mean to say that, let's say, at 400 mm you did the MA four times, and you got the results of +4, +5, +19, +20? Or is it that at 100 mm you got either +4 or +5, and and 400 mm end you got +19 or +20? If the latter, you did everything correctly, there is not much of a difference within 1 point spread. If the former - it is complete screw up.
Lbsimon
Gallery: 19 photos
Apr 04, 2014 14:27 |  #13
TeamSpeed wrote in post #16809773 (external link)
It should work, of course, but the beauty of the DotTune method is that one does not have to take any shots to do the MA.
TeamSpeed
01010100 01010011
Gallery: 116 photos
Joined May 2002
Apr 04, 2014 14:37 |  #14
Lbsimon wrote in post #16809981 (external link)
The beauty of doing it my way is that you can do it anywhere on the fly (like on a sideline right before the kickoff) and taking a few test shot either during the tuning, or after to test your tune, is a wash. ;)
It is always good to know a few different ways, because in some situations, one might be better than another.
GregDunn
Joined Mar 2013
Apr 04, 2014 14:55 |  #15
I do both. MA with DotTune and then grab some test shots with a real-world target to see whether it truly hit the sweet spot. So far, I've been very happy with the agreement between them (as long as I use lighting with the same color temperature).
Canon 1Dx | 5D3 | 7D2 | 6D | 70-200L f/2.8IS | 70-200L f/4 | 24-70L f/2.8 | 24-105L f/4IS | 100-400L f/4.5-5.6IS | 17-55 f/2.8IS | 50 f/1.8 | 28-105 f/3.5-4.5 | 4x Godox AD360
5,358 views & 0 likes for this thread, 8 members have posted to it.
1039 guests, 107 members online
