I decided to test my 10D which is a month old I printed the ruler from Bob Atkins site ( http://www.photo.net/learn/focustest/
) on a 8 x 10 white paper. I used the 50mm at f1.8 and placed the white chart at 45 degrees leaning toward the camera and had the camera 6 ft. and level with the chart and made 6 shots using AF single spot exactly like Atkins showed. I was so pleased that in every shot both of the rulers on the chart was razor sharp from left to right. MY problem is on Atkins site the results show the center only as being in fucos & the left & right sides was not but in my case the entire chart was real sharp. I did a futher test from 2 ft with the same results so I am wondering is mine OK or not. Thanking all Jim Johnston
