Thread started 07 Apr 2014 (Monday) 17:20
Yongnuo YN-622C problem
mdaddyrabbit
Apr 07, 2014 17:20 |  #1
Equipment:
2- YN622C
1- Youngnuo YN-565 flash
1- Canon 60D camera
When using my flash with the triggers off camera of course, I like to run the flash in manual mode and set my control to 1/2 but when I focus my camera it sets the flash back to 1/64. What am I doing wrong?
Website (external link)
CANON
Nonnit
Gallery: 22 photos
Joined Oct 2012
Apr 07, 2014 17:27 |  #2
One thing I found about the YN-622c when I was having some kind of problems, make sure it is all the way in on the hot shoe, it sometimes needs the final push.
Nonnit
5DMKIII // 70-200mm f2.8 L II // 35mm f2.0 IS // 50mm f1.4 // 85mm f1.8 // 100mm f2.8 Macro // 135mm f2.0 L // stuff
Film: https://www.flickr.com​/photos/souloffilm/ (external link)
Film: https://www.instagram.​com/souloffilm/ (external link)
Digital: http://nonnitryggva.is (external link) //
CliveyBoy
R.I.P.      He will be missed
Joined Nov 2005
Apr 07, 2014 17:29 |  #3
Are you setting M levels on-flash? Don't. Use the camera's flash control menu.
The 622C as transmitter carries the last-set values, which the camera adopts on power-up. The on-flash setting is ignored. The basic concept is that the 622C provides a radio communication between camera menus and flashes. The on-camera 622C is seen as a Master flash, whose job it is to communicate commands to remote flashes.
BTW each 622C may have its own values which will be enforced when it is used as a transmitter.
Clive, and Great G/D Abbie
50D; 580EXII, 430EXII, 550EX, YN685EX; YN-622C II, YN622C-TX and YN560-TX controllers TOYUG II v5.10 YN622 System Guide (external link)
I tried retiring, but gave it up - it's a dead end
Mesmer
Gallery: 101 photos
Apr 07, 2014 17:29 |  #4
Are you setting the power (1/2) in the camera's menu or physically on the flash?
InstaGram (external link) Flickr (external link) | 5DmkIII | Samyang 24 1.4 | 35 2.0is | 100L 2.8 Macro | 16-35L F4IS | 24-105L | 70-200L 2.8 II | 300L 4.0is | E640 | Speedlites
mdaddyrabbit
Apr 07, 2014 17:36 |  #5
I set the power on the flash.
CANON
Mesmer
Gallery: 101 photos
Apr 07, 2014 17:43 as a reply to  @ mdaddyrabbit's post |  #6
Try setting the power on from the 60D's External Flash control menu.
Mesmer
Gallery: 101 photos
Apr 07, 2014 17:45 as a reply to  @ Mesmer's post |  #7
Like CliveyBoy said, use the in camera menu. Here's a video. (external link)
mdaddyrabbit
Apr 07, 2014 18:03 |  #8
Thanks guys, that solved my issue.....learned something new today.
CANON
Mesmer
Gallery: 101 photos
Apr 07, 2014 18:05 as a reply to  @ mdaddyrabbit's post |  #9
Glad you got it sorted out. Now you won't have to worry about running over to the flash every time you want to change settings. It's much more convenient to do it front he camera. Especially when you start adding more flashes.
EOS_JD
Apr 10, 2014 14:24 |  #10
wrong thread
All My Gear
5D MkIII & 5D MKII + Grips | 24-70 f2.8L IS | 24-105 f4L IS | 70-200 f2.8L IS MkII | 50 f/1.4 | 85 f1.8 | 100 f2.8 | 1.4x MkII | Tamron 17-35 f2.8-4
1,902 views & 0 likes for this thread, 5 members have posted to it.
1511 guests, 131 members online
