Hello, bought Tamron 24-70 VC to replace 24-70 2.8L and 24-105 4L IS. But found that 70 mm setting is very very unsharp ... Returned to shop tried + 2 lenses, all of them were very weak on 70 mm. Even closing apertures won't helped. Images are blurry.
I don't know why everyone compares it to 24-70 2.8L II, but Tamron even stand close to 24-70 2.8L I ... Yes on 24 mm Tamron is sharper, but 70 mm is the FL where I use it alot.
Below are few samples of corners (center is a bit better, but not so much). Tried it on 5D3 and 6D, results are same.
Shop says there is two more other Tamron lenses. How do I need to check them before exchange one to other?
| HTTP response: NOT FOUND | MIME changed to 'image/jpeg' |
