So it turns out I imported into lightroom from aperture and I guess Lightroom messed it up because I did it again and it now shows the correct lens. It's def a lighroom glitch
https://www.flickr.com …219@N03/13746485813/meta/![]()
Apr 09, 2014 17:08 | #1 So it turns out I imported into lightroom from aperture and I guess Lightroom messed it up because I did it again and it now shows the correct lens. It's def a lighroom glitch
Apr 09, 2014 17:27 | #2 Help would be much appreciated
Milutiche Senior Member More info | Apr 09, 2014 17:39 | #3 when I look at lens model it says 50mm but focal length 85, what happens when you view the exif of the RAW file? www.actionimages.net.nz
I'll check when I get home on Lightroom and aperture.
Apr 09, 2014 18:13 | #5 I downloaded your photo from Flickr. Here is the embedded Exif: Image hosted by forum (682129) © MakisM1 [SHARE LINK] THIS IS A LOW QUALITY PREVIEW. Please log in to see the good quality stuff. Gerry
Apr 09, 2014 18:25 | #6 MakisM1 wrote in post #16822295 I downloaded your photo from Flickr. Here is the embedded Exif: Hosted photo: posted by MakisM1 in ./showthread.php?p=16822295&i=i40902402 forum: Canon Digital Cameras Yes that's all correct except for the lens model it says the 50mm 1.4. The problem is that it says focal length 85mm but the lens is a 50mm which is impossible
Apr 09, 2014 18:47 | #7 I see no lens model in the data. Am I missing something? Gerry
If you click on the link I posted that's what it shows
sbgagne Member 142 posts Joined Apr 2011 Location: Largo, FL More info | Apr 09, 2014 19:25 | #9 I am thinking flickr might be misreading the exif. I downloaded the photo in original size and did not see any lens info either. Image hosted by forum (682131) © sbgagne [SHARE LINK] THIS IS A LOW QUALITY PREVIEW. Please log in to see the good quality stuff.
Apr 09, 2014 19:32 | #10 What brand is the 85 mm lens? If its not Canon, you will get all sorts of strange exif data
It's the canon 85, if you click the link it shows the canon 50 1.4
Milutiche Senior Member More info | Apr 09, 2014 19:59 | #12 I'm 99% certain it wont be a camera fault, just a little glitch in the Matrix at Flickrs end www.actionimages.net.nz
Apr 09, 2014 21:15 | #13 Who cares what Flickr says. We are telling you what the Exif shows. Flickr strips the Exif unless you download the photo... Gerry
apersson850 Cream of the Crop More info | Open the image in Canon's Digital Photo Professional and see what it says there instead. Anders
runninmann what the heck do I know? More info | Apr 10, 2014 10:04 | #15 giballi wrote in post #16822284 I'll check when I get home on Lightroom and aperture. On flickr, Everything looks right Exocet for the lens model, do you know what would cause that? Flickr. Is it the camera? No, it's Flickr. Does it mean something is wrong w it? No, it's Flickr. Flickr
| Latest registered member is Niagara Wedding Photographer 1106 guests, 164 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
