Thread started 10 Apr 2014 (Thursday) 10:11
Aperture and light gathering abilities
CanonVsNikon
Joined Jan 2013
Apr 10, 2014 10:11 |  #1
Is it a true statement that a shot at any set aperture from any lens has the same light gathering abilities?
So a 50mm shot at 2.8 vs a 200mm shot at same 2.8 will gather the same light?
But isn't aperture (f-stop) a ratio of the focal length? 200mm/2.8 and 50mm/2.8?
jra
Apr 10, 2014 10:16 |  #2
Yes....for all intents and purposes, that's true and so is the second part of your question. Aperture is a ratio of focal length. The longer the focal length, the physically larger the aperture must be to gather the same amount of light.....so f2.8 on a 400mm lens is physically larger than f2.8 on a 50mm lens although they will both provide the same exposure settings.
gonzogolf
dumb remark memorialized
Gallery: 263 photos
Apr 10, 2014 10:29 |  #3
CanonVsNikon wrote in post #16823622 (external link)
Yes, the bold part answers your own question. The actual opening of the 200 mm lens is much greater than the one from the 50.
CanonVsNikon
Joined Jan 2013
Apr 10, 2014 11:38 |  #4
gonzogolf wrote in post #16823671 (external link)
Than why do they gather the same amount of light?
Not being argumentative, just trying to understand.
bps
Apr 10, 2014 12:16 |  #5
Actually, this is a pretty good question! My hypothesis: you're gathering the same amount of light/luminance from a distance that's further away, so you have to have a bigger opening to capture it.
Bryan
My Gear List
SkipD
Joined Dec 2002
Apr 10, 2014 12:23 |  #6
CanonVsNikon wrote in post #16823835 (external link)
The term "gather the same amount of light" is inappropriate.
Different focal length lenses, all set to the same f-stop, put the same light intensity on the film/sensor but that does not mean that they all actually collect the same number of photons.
Skip Douglas
Fernando
Apr 10, 2014 12:23 |  #7
bps wrote in post #16823920 (external link)
Bryan
Sort of.
The source isn't necessarily farther away, it's simply a smaller part of the "overall" frame.
Fuji convert - Ping me if you have any Fuji gear or legacy glass you're moving.
20droger
Apr 10, 2014 12:50 as a reply to  @ CanonVsNikon's post |  #8
Trying not to get too technical, the f/stop is, as you say, a ratio of the focal length. This ratio is the relative aperture of the lens and describes the physical aperture of the lens. For example, a 50mm lens at a relative aperture of f/2.8 has a phyisical aperture of 50/2.8 = 17.86mm, and a 200mm lens at a relative aperture of f/2.8 has a physical aperture of 200/2.8 = 71.43mm. For the same f/2.8 relative aperture, the 200mm lens has a physical aperture four times that of the 50mm lens (speaking in terms of aperture diameters).
Okay, if an f/2.8 200mm lens has an aperture diameter four times that of an f/2.8 50mm lens, why do they both admit the same amount of light?
This is because a lens' aperture is an area phenomenon, and the area captured by a lens—its angle of view— is determined by a lens' focal length and the size of the sensor/film.
Assuming the same sensor, when pointed at a blank, evenly lit sky, a 50mm lens sees 16× as much sky as a 200mm lens. The sky radiates a given amount of light per square meter. The 50mm lens therefore gathers 16× as much light as the 200mm lens. This means that to pass the same amount of light through the lens, so as to have the same effect on the film or sensor, the 200mm lens must have an aperture that is 16× the area (4 times the diameter) than the aperture of the 50mm lens. This is the relative aperture, measured in f/stops, and does exactly that (as shown above).
20droger
Apr 10, 2014 13:03 as a reply to  @ 20droger's post |  #9
Incidentally, it is because aperture is an area phenomenon that the relative apertures are what they are: 1.0; 1.4; 2.0; 2.8; 4.0; 5.6; 8.0; 11; 16; 22; 32; 45; 64; 90; and 128. The ratio between each value is (approximately) the square root of 2, but the light gathered by each value is 2× the light gathered by the next value.
xchangx
Apr 10, 2014 13:19 |  #10
Not knowing anything about the 3rd question, I have found out that not all lenses let in the same amount of light at the same aperture.
I have a 400 2.8 AF-ED II and had a loaner 400 2.8 VR while mine was getting repaired. Realized at a HS football game (same stadium, same body a week later) the settings I had the week before was under exposing.
After a little bit of research, come to find out that the VR in the lens actually caused the lens to lose some light. Something about glass surface/air.
If you look at cinema lenses, they are measured in T-Stops which is the light measurements.
Nikon D4s / 2x D3s / D3 / 17-35 2.8 / 70-200 2.8 / 600 f4
Freelance sports photographer for Getty Images Sports, Entertainment and News
Freelance sports photographer for Sports Illustrated
My Images with Getty (external link)
My Sportsshooter Page (external link)
My Website (external link)
CanonVsNikon
Joined Jan 2013
Apr 10, 2014 13:23 |  #11
20droger wrote in post #16824009 (external link)
Excellent explanation. I get it now.
archer1960
Gallery: 6 photos
Apr 10, 2014 13:30 |  #12
xchangx wrote in post #16824076 (external link)
Yes, that is true. f/stops don't take into account the transmittance (essentially the transparency) of the lens elements like T-stops do. The numbers will generally be close to each other, but the T-stop will always be a larger number (lower light transmission) than an f-stop for the same physical lens.
Gripped 7D, gripped, full-spectrum modfied T1i (500D), SX50HS, A2E film body, Tamzooka (150-600), Tamron 90mm/2.8 VC (ver 2), Tamron 18-270 VC, Canon FD 100 f/4.0 macro, Canon 24-105 f/4L,Canon EF 200 f/2.8LII, Canon 85 f/1.8, Tamron Adaptall 2 90mmf/2.5 Macro, Tokina 11-16, Canon EX-430 flash, Vivitar DF-383 flash, Astro-Tech AT6RC and Celestron NexStar 102 GT telescopes, various other semi-crappy manual lenses and stuff.
sjones
Apr 10, 2014 13:53 as a reply to  @ archer1960's post |  #13
All I know is that when I use my Sekonic handheld doodad to take a reading using that white bulb, the device gives me the proper exposure without asking for any information about what focal length I’m using.
July 2019-July 2020 (external link)
Windsun33
Joined Mar 2012
Apr 10, 2014 14:09 |  #14
The F-stop refers to the amount of light, not the size of the lens opening. The ratio you speak of is derived ("reverse engineered", so to speak) from that. f1 would be that the film or sensor gets the same amount of light as the scene reflects.
My first real camera was a Canon F1. That was a long time ago.
archer1960
Gallery: 6 photos
Apr 10, 2014 14:40 |  #15
Windsun33 wrote in post #16824200 (external link)
Nope, it's the ratio of the focal length to the aperture. If it was your method, you could never have a lens with an f-stop less than 1.0, or the lens would be gathering more light than the scene reflects, which is obviously impossible. And lenses with f/stops less than 1.0 do actually exist.
5,622 views & 0 likes for this thread
Latest registered member is DTPhotography
764 guests, 203 members online
