Thread started 10 Feb 2006 (Friday) 19:39
monitor calibration
rosco1971
Gallery: 25 photos
Feb 10, 2006 19:39 |  #1
Does your monitor need to be calibrated even if you get prints done from a lab?....second....what calibration do you recomend?.....adobe gamma or colorvision spyder?
Canon EOS R,CANON 5D, EF17-40MM f4L,EF85MM F1.8 , Sigma 50MM F1.4 , 70-200MM F2.8, RF35MM F1.8, EF100MM F2.8 USM L.,kenko pro 300 1.4 teleconverter
http://rossano1971.dev​iantart.com/ (external link)
TxLerman
Feb 10, 2006 20:15 |  #2
The short answer is yes! My monitor needs to be calibrated regardless of where I print the pictures. If I didn't calibrate the monitor, than the only place where my pictures would look right is on the same monitor. I use the Spyder2PRO. Works great!
subtle_spectre
Feb 10, 2006 20:19 |  #3
The actual colorimeters are always preferable. I got the Spyder2PRO from BH for like 149.00
Scott
Vista owner...and user  :p _______________
Gear
www.scottcphotography.​com (external link)
jfrancho
Feb 10, 2006 20:21 |  #4
Visual calibration is better than none, but hardware calibration is better. If you want to be able to soft proof, then you must calibrate your monitor. The ONLY time I'd say it isn't important to is if you do absolutely no editing to your images before getting them printed, and even then you won't be able to quantify the quality of the print service since you have no color reference.
990 views & 0 likes for this thread, 4 members have posted to it.
monitor calibration
2456 guests, 105 members online
