Thread started 16 Apr 2014 (Wednesday) 04:48
Changing background colour of studio shots
sancho1983
Apr 16, 2014 04:48 |  #1
Looking to change the background colour of a few shots I have taken. I don't mind the background colour, but I'd like to play about and see what other effects I can get from it.
This is as example of the sort of pic I mean
IMAGE: https://farm4.staticflickr.com/3783/13880247804_bb409bbc8b.jpg
IMAGE LINK: https://flic.kr/p/n9xU​6j  (external link) No more pictures!! (external link) by the sancho (external link), on Flickr
Someone in another thread said to use masks and then hue/saturation - I'm not incredibly sure on what that means :)
Could somebody link to, or give a brief outline of what steps I need to follow please.
I use Lightroom for all of my edits, but I also have Photoshop - am guessing I will need to use that.
Thanks in advance
Instagram (external link)
Https://bgsweddings.co​.uk (external link)
Northwoods ­ Bill
Joined Jun 2012
Apr 16, 2014 07:43 |  #2
Here is how I would do it:
1) Use the quick selection tool to select the girl, when working around the hair watch for areas where the gray shows through and be careful no to select the gray. (You will clean it up in step 2)
2) Use the refine edge button to finish your hair selection. You will need to adjust the sliders in the refine edge dialog to select the hair to the best of your ability - A You Tube video may help here.
3) At the bottom of refine edge choose output to New Layer with Mask. This should put a new layer in above the layer you were working on. Also it will turn off the layer you were working from.
4) Turn the layer you were working from back on and use levels, hue / saturation and brightness / contrast to adjust the background in the original layer. Because of the mask in the other layer your adjustments will only effect the background. I would recommend writing down the changes you make so you can carry them through to other images.
I could not figure out how to download a high enough res copy of your image to be able to edit it. If you want to send me a full res I will edit it and post back a Photoshop File with the edits so you can see what was done.
Bill R
Web:https://www.flickr.com​/photos/whitebirch/ (external link)
sancho1983
Apr 16, 2014 08:27 |  #3
Thanks for that.
Fall down at step 1...
Using the quick selection tool it seems to jump all over the place and selects the background too. I'll keep trying though.
How would be a good way to send a file?
sancho1983
Apr 16, 2014 08:35 |  #4
Ok, so I tried the magnetic lasso tool to make the selection instead.
Hair is stupid...
IMAGE: http://i.imgur.com/Fny01Xl.jpg
kirkt
Apr 16, 2014 09:09 |  #5
Now you see why people looking to change or drop out the background use a background with a strong, non-skin toned color (like green or blue) - the ability to isolate the background and create a mask in this manner is called chromakeying, or using a "green screen". If your background is not a saturated color, but instead is somewhat neutral, then there is no "chroma" upon which to key. Typically, you want to pick a background that will be in stark contrast to the subject - most caucasian skin tones are red so the red channel of the image will be very light in the areas where skin and light hair live. If the background is green or blue, then the background will be dark in the red channel - this creates good contrast between the subject and the background and permits the red channel (the grayscale rendering of the red channel) to be used as the starting point to create the mask you need to separate the subject from the background.
You could try using the neutral background and lighting it with a gelled, flagged strobe to color the background and create this contrast, if you intend to key the background in post.
kirk
Kirk
sancho1983
Apr 16, 2014 09:52 |  #6
kirkt wrote in post #16837942 (external link)
kirk
I tried to use gels the other day to change the background colour with limited success. This was the same background as the other photo but with a gel.
IMAGE: https://farm8.staticflickr.com/7199/13722665525_c4808750f4_c.jpg
IMAGE LINK: https://flic.kr/p/mUCf​nt  (external link) Elton (external link) by the sancho (external link), on Flickr
kirkt
Apr 16, 2014 10:20 |  #7
Turn the flash power down on the background and see if that gives you more saturation.
kirk
Kirk
kirkt
Apr 16, 2014 10:35 |  #8
Ha! Love it.
IMAGE: https://photography-on-the.net/forum/images/hostedphotos_lq/2014/04/3/LQ_682727.jpg
Image hosted by forum (682727) © kirkt [SHARE LINK]
Kirk
sancho1983
Apr 16, 2014 11:25 |  #9
Hehe.
How did you get the flare from the light to go over him as well?
kirkt
Apr 16, 2014 12:30 |  #10
I used the Knoll Light Factory PS plug in.
Kirk
Kirk
nathancarter
Gallery: 32 photos
Apr 16, 2014 14:37 |  #11
sancho1983 wrote in post #16837839 (external link)
Thanks for that.
Bill's instructions in Post #2 were pretty good.
The Quick Selection tool isn't really that quick. It's relatively quick but definitely not a one-click instantaneous trick. You have to constantly vary the size of the pen cursor based on the size of your subject - but for a headshot, you can probably get by if you make it about 1/3 the size of the head. Do it in little sections, and don't be afraid to hit Undo to back up a step.
Then you have to use Refine Edge to clean up, especially around hair. Again, it's kinda tricky and takes some practice.
Quick Selection is usually better than the lasso, sometimes better than the pen... I'm terrible at the pen so it's always better than the pen for me.
As for the color:
I like to add a new color layer, set it to an appropriate blend mode (Multiply usually works for me), and put the selection mask onto the color layer.
Northwoods ­ Bill
Joined Jun 2012
Apr 17, 2014 05:47 |  #12
Sorry, guess I should have been a little clearer, Nathancarter is correct you will spend some time with this technique to get your selection correct. You also might want to be sure Auto-Enhance is checked, it will slow things down a bit but it will allow the software to assist with the selection process.
Also, the further you stray from the original color the harder it is to hide the edits. I had shot some a while back with a white paper and I was looking for a darker gray than what you wound up with. The problem was with the size of the space I was shooting with I couldn't get far enough from the BG to control light spill. Anyway, I used the technique I described above and shifted the BG to the darker gray I had been going for originally.
If you want to send the file shoot me a PM and we will make arrangements.
Bill R
king.
Joined Oct 2013
Apr 17, 2014 10:52 |  #13
Just a quick edit with the quick selection tool. If you're grabbing background, turn down your brush size. Also use the feather brush within the dialog box and brush right around the head.
IMAGE: http://i62.tinypic.com/24ewfo7.jpg
5Dmk3 with a couple red rings
Website (external link)
sancho1983
Apr 17, 2014 15:39 |  #14
Thanks.
That edit looks good king. I'm away for a couple of days but I'll send you a pm when I'm back northwoods bill
PhotosGuy
Cream of the Crop, R.I.P.
Joined Feb 2004
Apr 19, 2014 09:26 |  #15
See post #8. Maybe #s 3 & 5, too: For those needing help making selections in Photoshop
5,201 views & 0 likes for this thread, 10 members have posted to it.
1065 guests, 104 members online
